10-17-2006, 08:40 AM | #1 |
Member#: 67669
Vehicle:2005 2.5 Hybrid WRX evoIII 16G |
Wideband sensor placement
I have searched and researched the info on this and am now more confused than before.
I am thinking about purchasing StreetTuner. I need to install a wideband 02 sensor in order to use the software correctly (and not blow my car up). I have a buschur 3" tbe with a hi-flow cat installed in the downpipe. There are NO bungs installed on this exhaust other than the one for the stock rear 02 sensor. I have the stock rear 02 sensor installed there. I don't want to install/weld any other bungs on my exhaust. Can I install a wideband 02 sensor in the stock rear 02 sensor bung? Will I get correct AFR readings? When I had my car protuned, the tuner was using a wideband sensor that was placed in the tailpipe. Also, if I unscrew the rear stock 02 sensor should I just zip-tie the whole assembly up under the car (protecting the sensor from the elements) or can I just remove the sensor completely since I am using the cobb AP? I have read that even though the AP disables the codes that get thrown if the rear 02 sensor is removed, the ECU still uses inputs from the rear 02 sensor for fuel trims? summary: Can I install a wideband 02 sensor in the rear 02 sensor bung? Will removing my stock rear 02 sensor mess up my idle/fuel trims? any input is appreciated.
10-17-2006, 08:45 AM | #2 |
Member#: 80541
Vehicle:2004 WRX WRB |
if you're going to the expense and trouble of getting a wide band, you should do it right and put a bung before your cat. it's more accurate. my local exhaust shop did it for 15 bucks.
10-17-2006, 08:59 AM | #3 |
Member#: 67669
Well I have read that the wideband 02 sensors dont like the turbulence/heat that installing right after the turbo has. Plus why did the protuner use the tailpipe location if it isn't accurate?
10-17-2006, 10:12 AM | #4 |
Member#: 6070
South East
Vehicle:2015 STi Dark Gray Metallic |
I'm not sure about that. The sensors do like heat, that is why they have heaters, but I'm no expert. The top of the downpipe after the turbo is a convenient location. You definitly should install it somewhere where water cannot settle (condenstation) on the probe if you leave it in, and install it before any cats.
10-17-2006, 10:23 AM | #5 |
Member#: 92281
General rule of thumb is you want the o2 12-18 inches away from the turbo. This is because exhaust gas temps can exceed the capability of the sensor.
10-17-2006, 10:30 AM | #6 |
Member#: 67669
problem is my hi-flow cat is about 12 inches from the turbo.
I guess I can't use Streetuner because I am not going to replace my exhaust system just to install a wideband 02 sensor!! guess I'll just have to have my car protuned every time I change/add something to it. I wonder how they get accurate readings from their 02 sensors they put in the tailpipe |
10-17-2006, 02:08 PM | #7 |
Big Ron
Super Moderator Member#: 18062
You can put it very close to the mouth of the downpipe. 4" from the flange is what most manufacturers use....take a look at the Cobb downpipe and see where it's wideband O2 bung is.
Tuners can get away with it as they know the "lag" in wideband A/F ratio response and what it means in their tuning. It's perfectly acceptable to use a tailpipe unit for a pro....for you....not so much. |
10-17-2006, 02:14 PM | #8 | |
Member#: 6070
South East
10-17-2006, 02:17 PM | #9 | |
Member#: 112842
Vehicle:2001 Impreza 2.5 RS Blue |
10-17-2006, 02:36 PM | #10 |
Member#: 67669
I guess I will need to find a shop that can weld a bung on stainless steel. At least it appears that the innovate LC-1 comes with a bung. Oh wait - innovate changed their LC-1 communications protocol and now it doesn't work with StreetTuner!!
There sure are a lot of "gotchas" in the quest to tune my own car Last edited by rebos123; 10-17-2006 at 02:37 PM. Reason: fixed vendor's name |
10-17-2006, 03:47 PM | #11 |
Member#: 114947
Vehicle:2002 WRX ReD |
Why can't he just replace the 02 sensor on the mid pipe with a bosch wideband 02 sensor?
10-17-2006, 03:54 PM | #12 |
Member#: 128215
10-17-2006, 04:01 PM | #13 |
Member#: 114947
10-17-2006, 05:42 PM | #14 |
Member#: 94070
South East
Vehicle:05 LGT PSM |
You should get a bung put in somewhere in the same vicinity as your stock 02 sensor.
I had an extra bung welded in for $30, I had mine place on the oposite side of the DP than my OEm 02 sensor and a couple inches higher so both sesnsors do not touch inside the pipe. Works like a charm. Jay-R |
10-17-2006, 07:49 PM | #15 |
Member#: 98645
NESIC
Vehicle:2002 WRX Wagon PSM |
i have mine about 8" from the turbo. and don't worry about the protocol change. there wasn't any change. someone just had their LC-1 setup wrong. My LC-1 is less than a month old and works perfect with my streettuner.
10-17-2006, 08:20 PM | #16 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
10-17-2006, 08:25 PM | #17 |
Member#: 70285
Vehicle:2011 JCW Mini Midnight Black/Red roof |
mine is about 6-8" away from the flange on the turbo, has been working fine for months now, every wrx/sti should come with this gauge stock!
10-17-2006, 08:25 PM | #18 |
Member#: 88322
Vehicle:2009 BMW 135i |
Do it right, weld in a bung.
At full throttle the lag even at the bottom of the downpipe isn't that bad. Like less than the speed of the logger you are using. It's only bad on idle and cruise, but at those points you should be using the factory front O2. |
10-17-2006, 08:53 PM | #19 |
Member#: 97642
SWIC
Vehicle:2002 Wrx Sedan MBP |
What about the sensors that have a narrowband output also. Could you replace the existing o2 and wire that into your ecu?
I am going to be installing the plx m300 soon. Here is a link http://www.plxdevices.com/M-Series_productinfo.htm Click the more info link under key feature #f:Replace your stock Narrowband sensor Anyone tried this? |
01-05-2010, 09:37 PM | #20 | |
Member#: 96267
Vehicle:'06 20G-XT'd STI CGM & NT03+M |
01-05-2010, 11:17 PM | #21 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
I have the innovate LC-1 with bung welded 3" behind the mouth of the downpipe. The wideband O2 sensor is throwing the code 8 (it's toast), 9 months later.
I'm replacing the sensor, let's see how long the second one lasts.. |
01-06-2010, 10:08 AM | #22 |
Member#: 70395
Did you provide a heatsink for the sensor like it describes in the manual?
01-06-2010, 11:51 AM | #23 |
Member#: 46135
No.
I've read on the innovate forums about the heatsink and several of the members installing the heatsink, together with a new sensor. I did not read about them posting a year later yet, that the sensor is still good. To me, the need for a heatsink suggests that there's too much heat, which means that the bung should be further down. Further down is the converter... Also, in many treads on NASIOC, the suggestion of putting a bung immediately after the mouth of the downpipe comes up, so I guess it's a good thing that the heat sink came up, so people know they have to use it. The heat sink is made available by innovate. |
01-06-2010, 12:07 PM | #24 |
Member#: 70395
You can also make your own. They describe how to do it in the manual.
01-06-2010, 06:46 PM | #25 |
Member#: 96448
Vehicle:02 WRX VF34 |
any idea why DP manufacturers put the bung so close to the turbo?
An Important Note on WideBand A/F Sensor Placement | Jon [in CT] | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 04-10-2010 07:58 AM |
wideband sensor placement???? | shadowmd | Electrical & Lighting | 5 | 10-30-2009 09:29 AM |
Wideband O2 sensor placement? | Superorb | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 35 | 02-12-2007 09:08 AM |
WIdeband Probe placement?? | boost4life | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 02-21-2006 01:43 PM |
Wideband o2 sensor placement, tuning experts please help! | Richard Sierra | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 03-12-2004 10:28 AM |
