10-29-2009, 07:35 AM | #1 |
Member#: 193222
Vehicle:05 Wrx 1.5xtr 6spd 2.5 hybrid 367whp/363wtq |
wideband sensor placement????
ok, i've searched but have got mixed results. i recently purchased an aem wideband gauge. today i am dropping off my dp to have the bung welded to my catless invidia dp. now the question i have is, where should i have them weld the bung? i've heard both cases (close to the turbo, and not close) i just need a clear answer. where should this thing go....
thanks and sorry if it's a newbish question, i just don't want to burn up this sensor nor i do i want it to read in-accurately. edit....just found some people saying install it 24"-36" away from the turbo. Does this sound right?
10-29-2009, 05:13 PM | #2 | |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
On the early turbo legacies the O2 bung is right after the turbo, about 6"-7". I've been running my WB there for a while and haven't had any problems. I'd say 24" is probably a good number to shoot for. |
10-29-2009, 05:22 PM | #3 |
Member#: 85008
Vehicle:03 wrx blue |
most of the setups have i have seen are on top of the bell mouth for the turbo inches away from the turbo..... been doing like that for years don't have problems unless there is a bad tune on them
10-30-2009, 07:19 AM | #4 |
Member#: 193222
yea, after talking to Rick from IAG, i had them weld the bung about 6" from the turbo (on top of the bellmouth).
10-30-2009, 08:32 AM | #5 |
Member#: 175401
Vehicle:2018 Focus ST White |
I run mine about 12" from the turbo. I've had it there for almost a year with no problems. Another thing to note, make sure that the bung is welded somewhere between the 10 and 2 o'clock position on the DP. If it's below this, there is a chance of condensation building up on the sensor and causing problems.
10-30-2009, 09:29 AM | #6 |
Member#: 193222
cool, thanks
An Important Note on WideBand A/F Sensor Placement | Jon [in CT] | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 04-10-2010 07:58 AM |
Wideband sensor placement | rebos123 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 40 | 03-12-2010 05:09 PM |
Wideband O2 sensor placement? | Superorb | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 35 | 02-12-2007 09:08 AM |
WIdeband Probe placement?? | boost4life | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 02-21-2006 01:43 PM |
Wideband o2 sensor placement, tuning experts please help! | Richard Sierra | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 03-12-2004 10:28 AM |
