08-22-2005, 05:24 PM | #1 |
Member#: 40736
Vehicle:2005 WRX STI Aspen White |
How to remove A-pillar? (for hardwiring radar detector)
I am about to hard wire my Escort 8500 and I am going to be running wires through the a pillar... How do I remove it? Just pull it?
Anyone that has hardwired a radar detector which is the best way to tap wires... I was going to do it from the fuse box, but the wiring harness that I got already has an inline fuse as well... THEN I started reading how-to's and people are just tapping the wires from the auto dimming mirror/compass... which I also have.... Not really sure which is the best reliable way? Thanks, -Nigel
08-22-2005, 06:15 PM | #2 |
Member#: 31719
NWIC
pretty much just grab and pull. start at the top.
08-22-2005, 06:33 PM | #3 | |
Member#: 43004
Vehicle:2004 WRX STi PSM |
After you get the three white clips unhooked, start pulling upward and towards you, in order to get the hooked bottom part of the a-pillar from out of the dash. Pic of mine for reference. |
08-22-2005, 07:58 PM | #4 |
Member#: 40736
Awesome! Thanks for the how to and the pic!
Just want to make sure that if I am running wires inside the a-pillar there is no chance of them getting cut or anything like what when putting the a-pillar back... Thanks again! -Nigel |
08-22-2005, 08:45 PM | #5 |
Member#: 37617
Vehicle:2007 |
Not if you put them back properly. When you take it off you'll see that there are already one or two wires run. Just bundle your new wires together with those and you'll be fine.
How to Remove Caliper Pins for Cleaning/Greasing | kyoung05 | Brakes, Steering & Suspension | 1 | 07-18-2008 02:43 PM |
How to remove center console for 06 WRX? | Daemos | Interior & Exterior Modification | 5 | 05-16-2007 10:44 PM |
How to remove clip ring for HKS SSQV? | Cusson | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-13-2007 06:01 PM |
How to remove B-pillar? | njskatchmo | Interior & Exterior Modification | 6 | 12-10-2005 12:34 AM |
how to remove side molding for side repeater? | etam | Legacy Forum | 3 | 09-25-2001 10:27 PM |
