Tire & Wheel Forum sponsored by The Tire Rack |
07-07-2005, 01:10 AM | #1 |
Member#: 60493
TXIC
Vehicle:2008 STI WRB |
Best Tire/Wheel measurements for wagon
I'm looking into getting a set of new rims and tires for my 02 WRX wagon and since ive heard of issues with rubbing on the fenders i was wondering what would be the best balence of rim size/offset and tire size to keep agressive look yet some decent ride comfort and prevent road rashing.
07-07-2005, 07:58 AM | #2 |
Member#: 86939
Vehicle:2006 GTI |
07-07-2005, 09:15 PM | #3 |
Member#: 6598
Vehicle:2017 Golf R Limestone Grey |
That article is only for 48 offset tires and is very true.
Get wheels with an offset of 53 and run 225s. 04 STis work nice, many of the SSRs can be had in the 50+ offset range too. It is that easy. No rubbing. |
07-07-2005, 09:26 PM | #4 |
Member#: 16318
Vehicle:2002 WRX Franknwagen Grime over Sedona Red |
^^^motion seconded...with caveats.
I personally run Prodrive P1 (ET53), with Michelin PS(just ordering PS2s), 225x45/17, with no significant rubbing. I phrase it that way because I have seen a couple of rub marks in the fender wells presumably resulting from RallyX exuberance; no problems, and no rubbing in normal use. There are a number of threads buried in this forum discussing just how far people have pushed the limits of <wheel size / offset / tire size> on wagons that might give you additional info...or at least opinions One thing to be aware of: different makes/models of tires with the same nominal size can vary significantly in actual total width, and this can be a critical issue when you start pushing the limits of wheel/tire combos. |
07-08-2005, 01:14 AM | #5 |
Member#: 81016
SCIC
Vehicle:2005 lgt ltd regal blue |
i've got 18x8 volks +50 offset with 225x40/18 on my wagon. lowered just a bit. no rubbing at all. the ride may be a little rough for what you want.
Similar Threads | ||||
best tire wheel combo for 2007 sti stock height | SHAG SCOOB | Tire & Wheel | 10 | 01-18-2010 06:43 PM |
18" wheel/tire track setup for wagon? | REXMASS | Tire & Wheel | 1 | 06-08-2007 01:38 PM |
Measurements for wagon front sway bar? | wylie | Brakes, Steering & Suspension | 14 | 09-15-2005 11:10 PM |
best rota set up for wagon???? | daphunkie12 | Tire & Wheel | 4 | 10-31-2004 01:04 PM |
max tire/wheel size for sedan and wagon | wantasti | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 01-31-2002 05:05 PM |
