05-23-2010, 06:20 PM | #1 |
Member#: 219426
Vehicle:2004 Subaru WRX WRB Stage II |
WRX Up pipe Temp Sensor Fix?
I read in Unabombers Manifesto that there is a fix for the WRX temp sensor. I bought an Up-pipe from an '05 STI and it doesn't have the port for the WRX temp sensor. I read that with a 2.2 KOhm 1/2 watt resistor I can trick the sensor, I assume its as simple as wiring it in to by-pass the actual sensor. I can't find a write up or anything so if anyone can direct me to one, thanks!
05-23-2010, 06:22 PM | #2 |
Member#: 122043
Vehicle:n/a n/a n/a |
its a o2/temp sensor~ and all you do is find the plug on the CAR side and put in the resistor from termianl #1 to terminal #2 and you are done well maybe some elct. tape to keep the crap out sir.,
05-23-2010, 06:41 PM | #3 |
Member#: 170013
Vehicle:2006 WRX VF39'd PDX Tuned |
Yeah you won't need the sensor because there's no cat in the UP now. Just put the resitor in the harness. Kinda like using a paper clip or piece of wire to use as a jumper. And as was suggested, use some tape to hold everything together, and keep anyhing else out of the harness.
05-23-2010, 06:45 PM | #4 |
Member#: 122043
or even better find/buy a rubber cap and slide it over the open harness and then tape the bottom open portion. just get the appropriate size
05-23-2010, 06:47 PM | #5 |
Member#: 219426
Alright cool, I just wasn't sure if I had to splice into the wire or if there was a harness like you guys had mentioned.
05-23-2010, 10:19 PM | #6 |
Member#: 200288
BAIC
Vehicle:2002 Impreza WRX World Rally Blue |
No splicing, just plug it in and you're set
05-23-2010, 10:25 PM | #7 |
Member#: 219426
Does the sensor unplug or do i just mount it somewhere (instead of letting it hang) and then plug the resistor in with it?
05-23-2010, 10:38 PM | #8 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
When you unplug the EGT gauge, you will be left with a socket on the car - plug the resistor in, wrap it with something to seal it up, and you are good to go. (the socket is held in place by a bracket already, so nothing will be "hanging")
Up pipe with cel fix | wrxty | Engine/Power/Exhaust | 0 | 05-26-2008 01:39 PM |
FS: Gutted up pipe w/CEL Fix | 01G_WRX_02 | NESIC Private Classifieds | 2 | 09-03-2007 11:44 PM |
FS: Gutted up pipe w/CEL Fix | 01G_WRX_02 | Engine/Power/Exhaust | 1 | 08-29-2007 09:06 AM |
FS in CNJ: Impreza L stock wheels 14 inchers & Stock WRX up-pipe w/ sensor` | mxpunk | Tri-State Area Private Classifieds | 2 | 05-06-2007 08:01 PM |
Wanted: up pipe temp sensor, or Bung Plug... yeah dont laugh | ErikAnderson | North West Impreza Club Forum -- NWIC | 10 | 10-09-2003 04:14 PM |
