01-12-2007, 11:07 AM | #1 |
Member#: 92969
Vehicle:2013 Kia Soul(sorry) White |
Should the I buy a car based on the transmission?
Okay, after less than a year with my '06 2.5i, Im selling it to get another WRX. The problem is, I kind of worry about the transmission. My last WRX was getting somewhat hard to shift between first and second when I traded it in at 75000 miles. That one was a 2002 model. Now I've heard that they did a little work on the five-speed for the 2004 and up model. Should I go for a 2004 instead of another 02-03?
01-12-2007, 11:12 AM | #2 |
Member#: 99289
None of the upgrades, until 06, addressed the synchros. Just gear width.
01-12-2007, 11:19 AM | #3 |
Member#: 109426
South East
Vehicle:97 OUTBACK mud brown |
try using a heavier shift knob
01-12-2007, 11:58 AM | #4 |
Member#: 75931
SCIC
Vehicle:2005 hmmm STI? Clark Tuned! |
not true the gears are stronger in the 04-05 model...
01-12-2007, 11:58 AM | #5 |
Member#: 92969
01-12-2007, 12:00 PM | #6 | |
Member#: 89387
SWIC
Vehicle:2005 RS White |
01-12-2007, 12:06 PM | #7 |
Member#: 92969
A 240 what?
Does that have anything to do with a WRX transmission? Last edited by sweetrex; 01-12-2007 at 12:13 PM. |
01-12-2007, 12:10 PM | #8 |
Member#: 11808
Change the transmission oil to something recomended by other WRX owners and keep what you have.
01-12-2007, 12:13 PM | #9 |
Member#: 92969
My current car is a 2.5i, and no amount of oil in the transmission is going to make it perform like a WRX. Thats why I'm looking for a new WRX.
01-12-2007, 12:28 PM | #10 |
Member#: 80663
SWIC
Vehicle:2005 STi |
The '04 does have stronger gears, but your grinding was very likely the synchros. If what lastresort says is true, then you may still have those issues with an '04. That being said, if your old WRX was your first manual tranny, you may be able to get more life out of a new one.
It really depends on power level and driving style. If you are good with a clutch now, and won't be going more than stage 2, an '02+ WRX with new synchros should be fine. Edit: A lot of the tranny issues that the early WRX had were due to bad driving and/or heavy modding. I don't think it was a bad tranny in and of itself, but the fact is most WRX owners like to mod, and most Subarus in general live a hard life...so Subaru has to make them really beefy to keep the loyal customers around. If subarus were driven like hondas, they'd prolly be the most reliable car on the road...but they get beat, and thus are in the top 3. If hondas were driven like subarus, they'd prolly drop down a lot. Last edited by shemoves; 01-12-2007 at 12:36 PM. |
01-12-2007, 12:30 PM | #11 |
Member#: 99289
01-12-2007, 12:52 PM | #12 |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
I thought the 05 tranny got dual cone synchros for 1st and 2nd gear?
Or maybe it was just first gear. |
01-12-2007, 01:18 PM | #13 |
Member#: 116897
NESIC
Vehicle:'07 328xi Jet Black |
try uncle scotty's cocktail
01-12-2007, 01:28 PM | #14 |
Member#: 117247
Vehicle:2000 2.5rs coupe White |
01-12-2007, 01:42 PM | #15 |
Member#: 99068
Vehicle:05 Wrx Blue |
c'mon this is nasioc, no one actually reads the thread, this thread was handled very poorly for the most part. Seems like half the people didn't even read/understand the first post.......
My question is why did you end up going with a N/A Impreza in the first place? Didn't you test drive it? didn't you realize you would not be content with the power? Was your first wrx used? Get yourself a brand new wrx and drive it like you love it, and your transmission will feel fine. But do not buy urself a used 04 because only god knows what how it has been driven, and it is a fact that these trannys (even the so called stronger ones) are still very easy to break. So if you can afford a new wrx tr or somthing go for it. |
01-12-2007, 01:53 PM | #16 | |
Member#: 46392
Vehicle:2004 WRX Black |
His question was if the 04 tranny was improved at all from the 02-03's. Gear width may have changed, but syncros remained the same. His problems with shifting difficulties was most likely was due to the syncros, NOT the gears or their width, so it could happen in 02, 03, or 04 since the syncros are the same. Uncle Scotty's cocktail is a mix of tranny fluids that often helps the grinding and shifting difficulties people have with these transmissions. So his recommendation is a good one, if you get a used WRX and have shifting difficulties, try using the cocktail. |
01-12-2007, 02:07 PM | #17 |
Member#: 114182
Vehicle:2003 toyota corolla RIP wrx, damn u bambi! |
I own an 06 with oficially 12k on it. Transmission and clutch are fine. Tires are gone though and the brakes have already been replaced. I was iffy about buying the 5 MT. But I'm surprised how strong it is. I drive hard; but I dont do redline clutch drops. My only mistake was shifting from 3rd back down to 2nd instead of 4th...twice. I literally felt like I was going to go through the windshield. I say buy it. SUBARU forever in my book.
01-12-2007, 02:48 PM | #18 |
Member#: 99289
01-12-2007, 03:31 PM | #19 |
Member#: 92969
So I need to step up to an 05 WRX to get the better synchros?
01-12-2007, 03:39 PM | #20 |
Member#: 99068
01-12-2007, 03:47 PM | #21 |
Member#: 92969
Is it possible to put an STi transmission behind the WRX 2.0 liter? Would the mounting bolts line up?
01-12-2007, 03:50 PM | #22 |
Member#: 99289
You're really going to have to start searching now. The answer is yes, it's been done. In fact, there are guides. But you don't get the auto DCCD action.
01-12-2007, 03:55 PM | #23 |
Member#: 125978
NESIC
Vehicle:2002 WRX Wagon Silver |
Not to mention that the tranny swap ends up costing somewhere north of $3500 -- I think upgrading the gears is cheaper.
From some of the threads I've seen, even the '02 "weak" transmission is generally OK if the car is kept stock, it's when you start adding power mods that the thing starts to have issues. |
01-13-2007, 12:38 AM | #24 |
Member#: 127779
E. Canada
Vehicle:2002 WRX wagon blue |
I think the best and cheapest solution is to learn how to properly double clutch and rev-match when the tranny's cold to help reduce any stress...which should be done on any manual tranny in my opinion. But more to the point, is holding out a little longer and saving up for an STI an option for you?
01-13-2007, 01:01 AM | #25 |
Member#: 112024
NWIC
Vehicle:03 WRX 6sp wgn '12HondaFit, C Bronson |
I know I've read that even the 03 had a change over the 02 tranny making it better. You should do a search on it. I just turned 70k on my 03 and have no tranny issues what so ever, still on the stock clutch, and the car puts out 245 whp and 233wtq. I just don't do any clutch drops or drive it like a dumbass.
Mazda Working on Small Roadster Model Based on the Mazda2 | AVANTI R5 | Non-Subaru News & Rumors | 17 | 08-05-2009 07:51 AM |
Toyota planning new compact sports car based on iQ | AVANTI R5 | Non-Subaru News & Rumors | 11 | 06-09-2009 02:47 AM |
I'm having evil thoughts about this car...Try to guess it based on the dyno | varmint007 | Off-Topic | 52 | 06-05-2009 05:12 PM |
Car Shopping on the Offensive: 8 Aggressive Buying Tactics - Feature | AVANTI R5 | Non-Subaru News & Rumors | 29 | 02-01-2009 12:05 PM |
Need a site that can find cars based on "criteria" | -=C=- | Off-Topic | 0 | 06-10-2005 12:52 PM |
