04-27-2007, 04:26 PM | #51 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Just an update, FWIW...
The problem is not solved. Phil is convinced the problem is with the harness connections. After performing his recommended fix attempt, I am not convinced of that. This has happened twice in the last 2 months. It is SO RANDOM. I truly don't believe this will ever be fixed, which blows since I intend to keep my beloved bugeye until it is falling apart at the seams.
04-28-2007, 11:26 AM | #52 | |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
When dealing with electronics nothing is for certain however. It might be worth sending the Hydra and harness to Hydra EMS as they might be able to notice something on the test bench. Why is it that you have all the problems? I think your bugeye might be cursed Thanks, Phil www.elementtuning.com |
04-28-2007, 12:00 PM | #53 |
Member#: 8512
South East
If you dig back into your brain Phil you will recall that I DID send it back to Hydra EMS NA for reflash and bench testing. Andrew ran it on the bench overnight according to him.
Page 2 of this thread. |
04-29-2007, 10:23 PM | #54 |
Member#: 112422
hey,,wat year your car?..i just ordered the hydra for my 2004 rs with turbo kit and sti shortblock..how do i kno if this will happen to my car? or is it a different situation?
04-29-2007, 11:18 PM | #55 |
Member#: 8512
South East
I highly doubt it will happen. This is a bizarre freak thing.
04-30-2007, 11:52 AM | #56 | |
Member#: 54918
05-21-2007, 10:16 PM | #57 |
Member#: 145296
thats happened to me only once, sitting at a red light but have had no other issues since then.
Hopefully I have no issues with stalling again,with my Hydra. |
05-21-2007, 10:25 PM | #58 |
Member#: 12654
Vehicle:02 WRX Sdn, 2.5L Element Tuning GT65r/hdrs |
I bought one of the 1st Hydras & had a problem with it not picking up vehicle speed ... sent it back to Hydra to check out & reflash. They ended up just replacing the board to solve the speed problem. I had it back a little over a week later due to shipping across the country.
01-26-2008, 07:52 AM | #59 |
Member#: 8512
South East
Still fighting this, dammit.
Replaced crank and cam position sensors. No love. 50% chance it's Hydra related, 50% not. |
01-26-2008, 10:00 PM | #60 |
Member#: 69461
South East
Vehicle:2004 WRB/Sti 11.41 @ 123mph |
can you try another local Hydra in your vehicle or.. switich to a utec or stock ecu and see if the problem still occurs, this is what i do when i believe i have a hydra issue, switich to know good ones..
01-26-2008, 10:52 PM | #61 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
Use Deoxit on the pins. Its expensive but might solve the issue.
C |
01-27-2008, 06:23 PM | #62 |
Member#: 8512
South East
Ordered some DeOxit
I will probably try my OEM ECU as well, but that's more of a pain in the butt. I have no front O2 sensor installed, no evap emissions solenoid, would have to disconnect my WB02 sensor since it won't be powered and heated by the OEM ECU... etc. |
02-13-2008, 07:41 PM | #63 |
Member#: 87446
NWIC
Vehicle:2005 STI 3 second start club |
I had this same thing happen to me 4 times on a 2 hour drive home Saturday after picking my car up from the shop. They had the hydra in and out of the car, rearranged some vac lines, worked on the fuel system for other issues.
When I got home I found one of the ports on the intake manifold was open. I capped this off and haven't had any problems since. Granted thats only been 4 days. Vac leak caused maybe? I know what you mean about the .3 second shut off while cruising at 75 on the freeway being freaky. I was in really congested traffic on a section of freeway with no shoulders through seattle.... |
02-14-2008, 01:00 PM | #64 |
Member#: 8512
South East
Worth a shot. I've been meaning to do an induction leak test anyway.
05-27-2008, 04:06 PM | #65 |
Member#: 87446
NWIC
jblaine - did you ever get any further with this problem?
After my post in Feb the car would do it about once a month until about a week ago it started doing it every day and now it was twice today.... The only difference I notice is mine only does it while cruising and usually always on the freeway. Obviously it's time to start trying to fix it - now I just need to figure out where to start. |
05-27-2008, 04:27 PM | #66 |
Member#: 8512
South East
Zero progress. It still happens to me totally randomly. It's been a few weeks now since the last instance.
Sadly, I've pretty much just given up on ever figuring it out. |
05-28-2008, 03:14 PM | #67 |
Member#: 54918
I know these older units (nemesis 2.0) are out of warranty but the only things ever determined on the older Nemesis 2.0 to fail causing this symptom was the 5 volt rail due to it over heating. The reason the car dies is because the signal from the crank sensor is lost which is run off of the 5v rail. I know Hydra had mentioned pasting the heat sinks again or replacing the 5 volt rail (I'm not sure this part is still available since these units are a few years old now).
Since these are out of warranty you may want to try opening up the case and pulling the floor carpet back to see if it's heat related or maybe even using a PC fan. It seems so random and inconsistent that heat may be the culprit. I know if the unit can't be fixed Hydra usually offers a huge discount towards the purchase of a newer unit. I know in Jeff's case they couldn't get the Hydra to act up on the test bench....go figure. Thanks, Phil www.elementtuning.com |
05-31-2008, 12:22 PM | #68 |
Member#: 108051
AKIC
Vehicle:2005 WRX STi WRB |
Did you ever try replacing your ignition switch I got my money on that being the issue here. This happened to my civic all the time and sometimes when you would start it it would start then die out. sometime while driving also.
I got a issue with my older 2.17 box Seems to go into 2 step randomlyand my 2 step is unplugged because it doesn't seem to be working. |
11-10-2009, 05:51 PM | #69 | |
Member#: 8512
South East
This stopped for many months. And now is back again. I've run many times with the carpet back. It doesn't seem to make any difference. Also, the electrical has gone out before (as described) after the car has been running only 1 minute -- back out of driveway, shift to 1st, drive 20ft, die. I suppose anything is worth a shot Maybe I'll track down some thermal paste and open up the box. |
11-10-2009, 05:53 PM | #70 | |
Member#: 8512
South East
11-11-2009, 03:28 PM | #71 |
Member#: 8512
South East
After grinding down a spare allen wrench to make a 'security'-head wrench, I took the ECU case apart.
It wasn't clear to me which was the 5V rail of the 2 rails. I cleaned then re-pasted the one that was loose enough to pull off easily (using OCZ Freeze). The other seemed very well pasted, so I left it alone. ECU back in. Car runs still, so that's good. We'll see.... |
11-11-2009, 05:06 PM | #72 |
Member#: 87653
South East
Vehicle:97 Supra / 17 GTR 16 Z06 / 07 STI / 05 Evo |
Good luck man. I can only imagine how frustrating that could be.
11-18-2009, 08:07 AM | #73 |
Member#: 8512
South East
01-30-2010, 10:14 PM | #74 |
Member#: 8512
South East
Three times since the last post. Once a month ago, and twice in the last 2 days.
I don't recall what the situation was a month ago, but the most recent 2: * Cold start of engine, drove for 1 mile, failed at ~15mph after turning a corner * Car driven hard for 10 minutes, failed at 60mph driving straight on an interstate |
02-01-2010, 12:11 PM | #75 |
Member#: 54918
You must have a failing 5 volt rail in there is all I can think of but the randomness of it is strange. Wishing it's going to fix itself isn't working so it might be time to retire it (since it's a few years old) and pay for an upgrade (new circuit board) since the box is long out of warranty.
Car died today, advice plz.. If your tranny dies will the engine start? | SP33Daddict | Normally Aspirated Powertrain | 18 | 01-16-2009 01:16 AM |
Hydra: Car died while cruising. Will not start again. | BiggSean | Other Engine Management | 17 | 03-18-2008 10:53 AM |
Car dies when trying to idle / dying car | VideoGameWrx | Commercial ECU Reflashes | 8 | 01-14-2008 12:25 PM |
Hydra: Car won't stay running | entropy138 | Other Engine Management | 5 | 12-03-2007 10:33 AM |
Hydra: Car won't stay running after install | 03scubaru | Other Engine Management | 11 | 07-24-2006 04:38 PM |
