09-30-2003, 04:08 PM | #1 |
Member#: 6752
machining flywheel - change clutch engagement point?
subj. says it all...
I think I remember someone saying years ago that machining a flywheel can change the engagement point in a subee hydraulic clutch...because the hyd. clutch is designed to meet the flywheel at a certain point, and if its machined...the meeting point will be closer to the engine, and screw it up. I kinda remember that maybe the flywheel could be shimmed or something...but anyways, I think I remember my flywheel being machined by the previous owner when he did the clutch. So I'm thinking it shouldn't be done again at any rate. Leaving me to get a used flywheel or a new stock flywheel or a lightweight flywheel....I don't know. Decisions...I hate them. Thanks Micum _________________
09-30-2003, 09:33 PM | #2 |
Member#: 30160
Vehicle:9900 2.5rs rbp,srp |
if t was machined once then you need another flywheel. when i needed my clutch done my tech said i needed a flywheel because subaru states the flywheel should not be resurfaced. he had told me it is good for one resurfacing but it isnt recommend. so i bought a light alum fidanza for less then a stock unit. works great on myrs. hope this helps
10-01-2003, 03:49 AM | #3 |
Member#: 6752
Thanks...thats what I was looking for. Now I just have to see if Adam had the flywheel resurfaced ever....hmm.
Or maybe just get an exedy... thanks Micum |
Clutch engagement point change with altitude | xS2k | Transmission (AT/MT) & Driveline | 6 | 01-03-2006 04:51 AM |
Clutch engagement point changing (a bit long) | ej25power | Transmission (AT/MT) & Driveline | 3 | 12-28-2005 04:43 PM |
Ever-changing clutch engagment point | PA-Brat | Newbies & FAQs | 8 | 04-11-2004 02:06 AM |
clutch engagement point | aphex twin | Transmission (AT/MT) & Driveline | 1 | 11-27-2001 11:29 AM |
Clutch Engagement Point Change Momentary, is this normal? | H5N1 | Normally Aspirated Powertrain | 5 | 06-08-2001 02:18 PM |
