05-23-2004, 12:43 AM | #1 |
Member#: 32535
Vehicle:2009 Nissan 370Z Monterey Blue |
Boost gauge shows no vacuum/what gives?
I just noticed tonight that there's no vacuum occuring, according to the boost gauge. I've got 2 boost gauges(had the OEM gauge that I never bothered to disconnect) and it's not the gauges, since both are showing the same thing. Even at idle, gauges sit at equal pressure. Anyone have any idea what is occuring?
05-23-2004, 01:03 AM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Where are the gauges tapped into? The proper connection point is any direct manifold tap, usually it's done from the hose to the factory bypass valve on the intercooler because it's readily accessible.
If you use the hose to the wastegate instead the result will be what you are seeing, no vacuum will be indicated and also the boost readings will never go above wastegate pressure. |
05-23-2004, 04:48 PM | #3 |
Member#: 32535
Never mind, I found the problem. The boost sensitive switch I've been using for my CO2 sprayer had a leak, and I took it off to fix the problem.
prosport boost gauge not reading vacuum | dirtbikeridr12 | Electrical & Lighting | 4 | 10-23-2009 06:22 PM |
CEL with no Code? what gives | elsanto | Commercial ECU Reflashes | 8 | 05-30-2006 09:01 AM |
what vacuum level does your stock boost gauge show at idle | rocketwrx | Newbies & FAQs | 7 | 02-06-2006 09:45 AM |
Car has no guts-what gives? | LowUFO | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 25 | 03-24-2005 05:53 PM |
UTEC ? - Blinking cell, Datalog shows no knock.. what gives? | LargeOrangeFont | Engine Management & Tuning | 7 | 10-03-2003 03:43 PM |
