11-05-2011, 07:13 PM | #1 |
Member#: 7082
Vehicle:2002 WRX 2013 BRZ |
Dealer service says exhaust valves tight $4500 to repair
Is a valve job necessary? Wouldn't a valve adjustment be the first step?
Does this sound right? Dealer says exhaust valves are tight, $4500 valve job to fix. Price includes new exhaust valves, valve seats, valve guides, valve guide seals, and gaskets. 2002 WRX, manufacture date, March, 2001, 145,000 miles, original owner, no mods, all stock, well maintained. Car runs great except for a check engine light that has come on three times in the last 5000 miles. Code P0304 cylinder 4 misfire. Valves last adjusted at 102,000 miles, for preventive maintenance, by the same dealer or at least I paid for them to be adjusted. The dealer performed a leakdown test recently when diagnosing the check engine light to determine that a valve job is now necessary, at $4500. They didn't provide me the leakdown test numbers. What would you do?
11-05-2011, 07:35 PM | #2 |
Member#: 40424
Vehicle:05 STi |
You can't adjust the valve without taking the head off. The 02s have shims so you need to change the shims to adjust the lash; the newer models just have buckets with different thickness. Your lash isn't causing your CEL. Check your coil pack and replace the spark plug before dropping 4.5k.
11-05-2011, 08:05 PM | #3 |
Member#: 293647
Vehicle:2003 WRX black |
sounds like BS, if your valve are too tight they need loosed up, not replaced. what's your cyl compression? tight valves can cause low compression. Go somewhere else for a second opinion.
11-05-2011, 09:55 PM | #4 |
Member#: 216556
Vehicle:2017 Impreza Limited DGM |
If it's going to cost 4,500 dollars, get a new engine which should be less $$
11-05-2011, 09:59 PM | #5 |
Member#: 159682
Vehicle:1995 WRX 2015 F150 |
Find another dealer. What's happened is that the valves have worn into the seats tightening up the clearance. On an 02 all you need to do is adjust the valve clearances with thinner shims. There is a dealer only special tool that lets you replace the shims without head or cam removal. It's about a 2 hour job and shouldn't cost more than a few hundred.
11-05-2011, 11:42 PM | #6 |
Member#: 200216
It's going to take a little more then 2 hours to take the valve covers off and properly check all the valve clearance and to swap out shims even with the dealer tool. Then hope the dealer even has shims in stock. If not they'll have to order them. Go to a different dealership.
11-05-2011, 11:48 PM | #7 | ||
Vehicle:OK buy Nates beans westcoastroasting.com |
talk about a HUGE rip off Quote:
________________________________________ post up the dealers name so we can boycott the ******** |
11-06-2011, 01:21 AM | #8 |
Member#: 33868
Vehicle:2003 wrx srp |
Are you sure he didn't say the #4 exhaust valve was burned? A leakdown test, numbers and where the air was going would result in a pretty good diagnosis.
11-06-2011, 02:28 AM | #9 |
Member#: 160799
Vehicle:O2 WRX WRB |
Whatever the case, that's entirely too much money for a valve job. Take it to an independant shop. F*** the dealership.
11-06-2011, 07:26 AM | #10 |
Member#: 92114
Vehicle:03 WRX (NAVY Camo) in"Special Ed." Run Group |
Go to another dealer /shop.
If you get the same diagnosis, just spring for an engine rebuild with the mileage that you have. |
11-06-2011, 09:03 AM | #11 |
Member#: 268354
Vehicle:02 WRX 05 LGT Slow Automatics |
No way, dealer or subaru specialist shop only. Half these independent shops scratch their heads at anything subaru. I wouldnt trust them doing a job like that.
11-06-2011, 09:07 AM | #12 |
Member#: 131347
Vehicle:2007 Legacy 2.5i SE |
Plus independent shops won't have the special tools that they will need and chances are, they will improvise and **** something up. A dealer or a Subaru specialty shop.
11-06-2011, 10:07 AM | #13 |
Member#: 265122
SCIC
Vehicle:2004 WRX Java Black Pearl |
$4500 is a rip off for a valve job. For that price you could pretty much replace the engine. Definitely shop around, find another Subaru dealer nearby, more than likely this shop is hurting for business and trying to take you for a ride, I used to see it all the time when I worked for dealers.
11-06-2011, 07:15 PM | #14 | |
Member#: 7082
I will request a valve adjustment from another dealer. |
11-06-2011, 11:33 PM | #15 |
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
worth a shot, maybe throw some Sea Foam through the intake manifold to remove some of the carbon build up. Slight chance the carbon is creating the problem (small, but plausible).
Stephen www.iaperformance.com |
11-11-2011, 03:26 PM | #16 |
Member#: 7082
The dealer agreed to a lower price for the valve job repair and I let them proceed. I went and took a look at the condition of the exhaust valves and cylinder heads at the dealer service dept.
Both cylinder heads were cracked at the spark plug like so many are and the exhaust valve faces were rounded so shims wouldn't solve the problem. The dealer diagnosis was correct. The price is just expensive. Since they are now ordering new heads, why not get a new short block I thought. Even though they said compression on the good cylinder head was was 95% and they didn't recommend a new short block. I had them order a new short block. Maybe I can get another 150,000 miles on this car. Was this a stupid decision? Fair game. I now have a good used short block for sale. |
11-11-2011, 03:28 PM | #17 |
Member#: 159682
So they got you hook line and sinker.
11-11-2011, 03:32 PM | #18 |
Member#: 33868
A short block would not include cylinder heads. Did they say why the #4 exhaust valve burned?
This dealer mechanic thought cracks from the spark plug hole to the valve seat is not ok. Is that the consensus on this board? Where is this dealer located if you don't mind my asking. |
11-11-2011, 04:47 PM | #19 |
11-11-2011, 09:20 PM | #20 | ||
Member#: 7082
Thank you.
I thought you might find this interesting. 2011 U.S. Government test on engine wear from high ethanol levels. See PDF page 28 for the good stuff. http://www.nrel.gov/docs/fy12osti/52909.pdf |
11-11-2011, 09:58 PM | #21 | |
most of the early 2.0 wrx's heads have been cracked for a long time....no problem you LET yourself get assraped you invited an assraping |
11-11-2011, 10:57 PM | #22 | |
Member#: 3409
Vehicle:98 My FMIC Is bigger than yours. |
Check your PMs. |
11-12-2011, 01:41 AM | #23 |
Member#: 243261
TXIC
Vehicle:2004 WRX Java black pearl |
11-12-2011, 11:16 AM | #24 |
Member#: 33868
It occured to me that a short block and two heads = 1 new engine Is that what they are selling you?
how much for the 145,000 short block? |
11-12-2011, 11:21 AM | #25 |
Member#: 7082
See PM
Similar Threads | ||||
Dealer performed this service, was it necessary? Also, where to get service manual? | awns729 | Service & Maintenance | 19 | 06-25-2010 12:26 PM |
Help to locate a decent dealer service department in Atlanta | fpa1974 | South East Region Forum | 7 | 07-11-2002 11:49 PM |
Dealer Says My Aftermarket Intake is to blame.... | AllWheelsDriven | North West Impreza Club Forum -- NWIC | 24 | 06-18-2002 08:03 PM |
Dealer says my aftermarket intake is to blame | AllWheelsDriven | Normally Aspirated Powertrain | 11 | 06-16-2002 06:01 PM |
turbo back exhaust and dealer service? | spike | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 12-05-2001 09:22 PM |
