03-15-2008, 11:34 AM | #1 |
Member#: 142868
Vehicle:2014 BRZ LIMITED Satin White Pearl |
SMC Kit-Windsheild Washer Bottle
Just curious where you guys mounted the small bottle for the washer fluid,
I have a perrin catch can by the battery so that spot isnt going to work. Can I just leave it out or Do i have to keep it in? Pics would be great
03-15-2008, 02:19 PM | #2 |
Member#: 151694
NWIC
think of the tank size you could run, if you swapped out your spare tire and replaced it with a tank. plus its weight reduction!
you could relocate your battery, too. many options available, its really just up to you. where do YOU want to run your bottle? |
03-15-2008, 02:44 PM | #3 |
Member#: 142868
Well mine is actually already installed, And im happy with my meth tank, i dont like the smaller tank they provide for windsheild washer fluid...Is anyone out there running the smc under the hood setup that just didnt use the tank for washer fluid?
03-16-2008, 11:16 AM | #4 |
Member#: 142868
Anyone, Just want to make sure before removing the tank for the actual washer fluid, It looks like there just one wire for the pump and one line that runs right up to the hood, Im assuming i cant just remove it but I want to make sure
03-16-2008, 02:41 PM | #5 |
Member#: 129832
Vehicle:2005 STI GT4094r |
For my kit i just drilled a hole in the bottom of the exsisting windshield washer bottle and use that. Not the wisest choice but you'll never know i even got meth injection. I never used my windshield washer fluid so it was a small sacrifice for me.
03-16-2008, 02:46 PM | #6 |
Member#: 142868
Are you using the SMC kit?
99 OBS rear windsheild washer hose queston | grafton | Service & Maintenance | 1 | 01-25-2009 01:42 AM |
washer bottle, stock bpv, grounding kit | Trevor723 | Engine/Power/Exhaust | 6 | 04-28-2007 11:41 AM |
4L Exalto washer bottle + 12v pump kit? | AcquaCow | Water/Methanol Injection, Nitrous & Intercooler Cooling | 5 | 03-22-2007 02:41 PM |
Pump on windsheild washer bottle | boysetsfire | Normally Aspirated with bolt-on Forced Induction Powertrain | 12 | 02-26-2004 09:47 PM |
will a legacy wagon washer bottle? | pitbul09 | Legacy Forum | 5 | 12-30-2002 10:27 PM |
