12-19-2006, 12:56 PM | #1 |
Vendor Sales Rating: (50)
Member#: 36596
Vehicle:2009 135i Alpine White |
Pre-Order Pricing without the delay
Man it's been a while since we posted a thread here so lets make this a good one. Now through December 31st we've got a select # of deals...all in stock ready to ship.
* The MadDad(TM) Velocity V2 Header/Uppipe. This was on pre-order many many months ago for $449.95 and many folks waited 4-5 months to get theirs, now through the end of the month grab a Velocity V2 Header/Uppipe for just $449.95 (plus shipping) with no wait. While this is similiar to other brands offering what looks to be the same you'll find two things that are pure MadDad(TM) specific...the 45mm velocity stack uppipe is a MadDad(TM) exclusive(48mm used on competing setups) as is the pre-fitted 1/8" NPT EGT bung built right into the manifold making installation of your EGT gauge/probe a piece of cake. You'd pay between $60-90 to have a shop put an EGT bung in your manifold and it will never be as clean as what you'll get in our header. A plug for the factory uppipe EGT bung is included as as well as a complete highest quality metal gasket set. *NOTE* - the sick deals below are all with the new MadDad(TM) Essentials Bellmouth downpipe...WHY is this downpipe discounted so heavily? It's normally $259.95. The reason is on this first production run the lower mount bracket was left off. We have this bracket and it is inlcuded with the downpipe but needs to be welded on at time of install...or better yet C clamp it on as one local customer did with no PITA factor at all. You won't ever get a deal like this again...in stock inventory only. Downpipe also includes MadDad 5-layer metal downpipe gasket(normall $20). This is perhaps the best catless bellmouth out there. *Bonus for the STi owner - the upper mount bracket for the Essentials Bellmouth is STi specific...meaning it bolts right up. Most downpipe upper brackets(if even included) are designed for the WRX owner. THIS DOWNPIPE FITS ALL WRX AND STI'S. WRX owners don't need to use the upper bracket, just use the lower(as is typical on most downpipes anyway). * Borla Hush Catback + 3" Flange Adapter + MadDad(TM) Essentials Catless Bellmouth Downpipe = $699.95 (plus shipping) - do the math people this is silly. *Same deal with a Borla STi exhaust just $719 INSTOCK INVENTORY ONLY - WE ONLY HAVE A FEW HUSH AND STI catbacks left to combine together on this deal. * MadDad(TM) Essentials Catless Bellmouth Downpipe - $175 (plus freight) Includes free 5-layer metal downpipe gasket. In stock inventory only...roughly 20 available...when they are gone you will never see this price again. * MadDad Whisper 3" Catback with Essentials Catless Bellmouth - $799.95 (plus shipping). Only 5 combos available through end of the month. Will repost pics of the uppipe/header and Essential Downpipe in a bit along with a few other tidbits. R. |
12-19-2006, 09:41 PM | #5 |
Member#: 36596
Fist off, I forgot to mention how you get the special prices.
For the the Velocity Uppipe/Header and the Essentials Bellmouth. The parts are up on the website at their special individual prices. For the Turboback combos that include the Essentials downpipe please put both items in the shopping cart(catback and downpipe) and put "HOHOHO" in the Customer Notes field. We'll take care of the rest. Our shopping cart system DOES NOT charge your CC..it just securely gathers the data so don't worry about the price calculated. The product pricing will be adjust as listed here. CasopoliS - boxed and labeled and track # sent(on invoice). I had one coated set on hand so your luck no delays at all....Coatings usually add 10 days turnaround before shipping. Uppipe EGT plug and manifold EGT plug are included. Don't mind the shape of the box it's been back and forth to and from the coater so it been around, but everything in it is in good order(I opened it to pack the EGT plugs). Phat04WRX - $555 - use HOHOHO silverscooby02 - there are no special deals on Whisper catbacks alone. Price will as it's calculated on the cart....649.95. Shipping to Canada runs about $25. - Rich Last edited by Daddy's SCP; 12-19-2006 at 09:47 PM. |
12-19-2006, 09:47 PM | #6 |
Member#: 36596
Some supporting pics:
Velocity V2 Uppipe/Header - first small insert shows the EGT in the manifold itself..close to the exhaust port where you'll get the most accurate results(hot). No similiar header has this. The second small insert shows the velocity stack in the uppipe. This uppipe is a 45mm...not the 48mm offered elsewhere. 45mm is still big....48mm in our mind was too big. This was a change we made for the V2 design and it's not offered anywhere else. Here is the close up of the cast bellmouth of the Essentials Catless Bellmouth. R. |
12-19-2006, 11:14 PM | #7 | |
Member Sales Rating: (3)
Member#: 115079
Thanks again for offering everyone these great prices. Last edited by CasopoliS; 12-19-2006 at 11:19 PM. |
12-19-2006, 11:28 PM | #8 |
Member Sales Rating: (8)
Member#: 105404
NESIC
Vehicle:2006 FPGreenSTI SOLD 04 GMC 2500HD Duramax CC |
GO RICH!
Bump for this stuff its a steal! Still loving the original Essentials downpipe on my sti, the downpipe definately helps make some serious consistent power on my sti! |
12-22-2006, 09:47 AM | #10 |
Member#: 36596
Forgot to post some other specials.
Free metal gaskets and stud set with either the T304 Flex uppipe or the ScoobySport two-piece solid uppipe. What does that mean. That means you can get one of the nicest flex uppipes, the best metal gaskets around, and the corrrect size(and length) studs for just $139.95, or you can get the THE best solid uppipe available anywhere...the ScoobySportNA(the Hayward&Scott folks). Most people don't realize that this uppipe is a two piece. It's a deep double slip jointed design that gives the flow characteristics of a solid with the flange stress relief of a flex...pretty slick...$249.95 with gaskets and studs. Remember, put HOHOHO in the Customer Notes section at the bottom of the checkout form. Pics of the T304 flex |
12-24-2006, 11:01 AM | #16 |
Member#: 36596
Last post for a few days:
We have a couple of customers with the header on their 06 WRX and they report fitment is just fine. Haven't had anyone with an 06 STi that I know of yet...but I don't think 06 STi fitment is any different than 06 WRX, but we report when I know for sure. I do know there are some folks with the "other brands" that have this style header on an 06 STi without the MadDad modifications(etg bung 45mm uppipe vs. 48mm) and there arn't any issues. Outside of the built in EGT bung on the manifold..it is the same as several other brands(built by the same factory). whitson01 - your STi had a catless uppipe so I'd probably opt to put the money elsewhere but if I was looking to juice every last pony I'd got with the ScoobySport rather than the Flex...but again money is probably better spent elsewhere in your case. Happy Holiday's gang. Hope Santa brings you an extra 50hp and a steering wheel for your Xbox 360(on my list) , happy driving..... Rich |
12-26-2006, 05:33 PM | #20 |
Member Sales Rating: (6)
Member#: 81116
NESIC
Vehicle:2017 WRX STi Ice Silver |
Bump for a great vendor and for an incredible bellmouth downpipe. I'm running the essentials bellmouth with the essentials halfback mated up to an sti axleback... Great sound and power gains.
I'd recommend the essentials bellmouth to everyone looking to upgrade. The design was well thought out and makes soooo much sense. Unlike most downpipes, this one does not rub up against the a/c hose... so no more rotten burnt rubber smell. FTW. Rich, I'll try and get out there sometime soon. I've been very busy lately, haven't forgotten about the heatshield though. ..::Chris::.. |
12-28-2006, 01:09 PM | #22 |
Member#: 36596
WRXtasy05 - no worry, we'll hook up sometime after the new year. I know this is a nutso time of year for everyone(me mostly ).
CasopoliS - Glad you like them. For everyone else that might be looking to order a set coated, there is about an extra 10 day(business days) turnaround before they will ship to you since we get them coated to order. Still time to grab a killer downpipe at a killer price. R. |
01-03-2007, 02:09 AM | #23 |
Member#: 35020
VIC
Vehicle:02 WRX - Stage WTF 04 WRX Wide Wagon - Stg 3 |
Pm sent about some stuff!
01-06-2007, 10:25 PM | #24 |
Member Sales Rating: (10)
Member#: 14531
SCIC
Vehicle:02' Stage4 wrb WRX 06' Mazdaspeed6, 85' AE86 |
I received my header 2 days ago. Thanks for the quick shipping, I might place another order soon. This time I gotta make sure the wife isn't home when the package comes in!
Similar Threads | ||||
Racecomp Engineering pre-order-Updated pricing and product list | dalesmotorsport | VIC Vendor Classifieds | 2 | 12-14-2009 01:17 PM |
Tesla motors raises prices for pre-order customers | elirentz | Non-Subaru News & Rumors | 42 | 07-15-2009 10:36 AM |
GB pricing without the GB, TXS/Invidia/RSR/Tanabe/Espelir/Walbro and more!! | CVR Motorsports | Engine/Power/Exhaust | 31 | 09-02-2005 06:56 PM |
New Falkens - Pricing and Pre-Order | KC | Motorsports | 72 | 02-10-2005 10:55 AM |
