03-21-2012, 11:43 PM | #1 |
Member#: 311373
Vehicle:2009 impreza 2.5i dark grey metallic |
ej253 strength?
does any one know how much hp and/or tq can a my08+ engine case take?
and does anyone know if a brian crower stroker kit for a ej257 will work on a ej253?
03-22-2012, 03:13 AM | #2 |
Member#: 271928
Vehicle:2014 WRX Limited Crystal Black Silica |
Not sure about the stroker kit (probably not) but I wouldn't assume it could handle nearly as much as 255/7 since its an open deck. Don't take my word though
03-23-2012, 01:27 AM | #3 |
Member#: 311373
is the ej255/257 a closed deck or semi-closed deck? cuz the pick of the ej257 short block on iag performance's website looks like its semi-closed.
03-23-2012, 10:06 AM | #4 | |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
EJ257 is a semi-closed deck block. To the OP, that stroker kit is LARGE investment to use with a EJ253 block. You could buy a EJ257 for the price of that kit alone. YOu will have to over bore the cylinders and you will need to modify the heads to properly utilize the kit. simple answer dont waste money doing this on a EJ253. If you want a higher CR play with HG thickness. |
03-23-2012, 04:51 PM | #5 | |
Member#: 165749
03-24-2012, 12:38 AM | #6 |
Member#: 311373
i dont remeber asking about compression. im planing on using my stock cr of 10:1 and the stock 99.5mm bore. i just want a longer stroke. its a n/a build by the way
12-09-2012, 12:53 AM | #7 |
Member#: 187834
Vehicle:06 2.5i impreza Red |
better head suds does the trick. People seem to forget that previous wrx's had open decks and boosted. A better than stock head gaskets and ARP head bolts sholud do the trick nicely in a N/A applicationg. Qhy not just get a bore over and have your block bored instead of buying this kit.
+.40 should do you nicely. Next is either get a repsected shop to build it or buy a built short block..best thing to do. overbores require retuning etc. and parts sometimes don't work well with new set up PITA if you ask me. what you can do is just purchase 100mm and have the mspec'd to that to limit down time instead of figuring where your cylinder maybe. |
12-09-2012, 09:05 AM | #8 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
+.40 what? Millimeters? So he can get custom 99.9mm pistons made instead of just using the commonly available 100mm ones? And how would that be a substitute for a stroker? |
12-09-2012, 12:26 PM | #9 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
IIRC, you also have to have the block machined for the larger stroke, so the rod journals don't hit the inside of the block halves....
~Josh~ |
12-09-2012, 12:43 PM | #10 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Lets just answer the OP's question.
1. 253's have been in boosted applications up around 400hp, but you aren't looking to make that type of power. It should be fine as your cylinder pressures aren't going to be as high as a heavily boosted motor. 2. The stroker kit would work, provided any case modifications were performed if they are needed for clearance. 3. A stoker kit designed for an EJ257 is going to need custom rods and/or pistons to work correctly. Stock pistons likely wont work based on pin heights. Jay |
12-09-2012, 01:59 PM | #11 |
Member#: 120
AKIC
The BC stroker kit includes pistons (with bore and CR determined by the buyer), which is why (IMO) sticking with the stock bore and CR seems silly.
12-09-2012, 05:02 PM | #12 |
Member#: 5218
Ahh....I see. I'm not familiar with the BC kits, and thought they were crank only deals.
OP can keep the stock bore for simplicity I guess..... Jay |
12-10-2012, 05:28 PM | #13 |
Member#: 311373
if i was going to bore it over i would do the 102mm bore with the sleeves but then i would have the cost of machine work and sleeves on top of the stroker kit. i looked at the gains of just boring it over and the gains of just stroking the engine and the additional stroke had the largest gains in displacement. i know $3500 is alot for maybe a gain of 20hp but some guys spend $1500 on exhaust and an intake and maybe see 5-10hp if there lucky. i think the stroker kit along with cams, custom exhaust(including header), modded stock intake, and tune could yeild a 50-60hp increase at peak and a 30-40hp increase across the power band. i was thinking of boosting after i built the engine or maybe a nitrous wet kit but i would rather keep it n/a cuz its my daily driver that i want to run 87 octane in since i already have a 720hp turbo ford lightning thats uses plenty of high octane already. im sorry for the poor grammer english was my worst subject in school.
12-10-2012, 07:25 PM | #14 |
Member#: 124254
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
You're going to put in a $3500 stroker kit, plus cams and headers, but want to stick with 87? That's... odd, considering the stock tune.
12-11-2012, 08:20 AM | #15 | |
Member#: 5218
Based on this information, I think you would be a fool to spend the money. Wanna go fast? Grab the other set of keys.... Wanna carve some corners? Take the Impreza and work on the suspension. It's that simple.
Jay Quote:
Similar Threads | ||||
Turboing a MY05 EJ253 SOHC | JonzFaSTi | Normally Aspirated with bolt-on Forced Induction Powertrain | 35 | 09-08-2006 10:43 PM |
FS: EJ253 SOHC 2.5RS Engine | subenick | Private 'For Sale' Classifieds | 1 | 05-06-2006 07:19 PM |
FS: 1999 RS 2.5 EJ253 Engine Parting Out -- Testing the waters | GinoEJ253two | SCIC Private Classifieds | 2 | 04-23-2006 09:36 PM |
Phase 2 EJ253 | Lachlan | Private 'For Sale' Classifieds | 4 | 02-23-2006 10:18 PM |
EJ25D vs. EJ253?? | Hawk296 | Normally Aspirated Powertrain | 7 | 01-02-2003 11:46 PM |
