07-18-2013, 05:35 PM | #1 |
Vendor Sales Rating: (6)
Member#: 202399
Vehicle:2002 Impreza Outback |
2006 STI COMPLETE PART OUT, 63K Miles!
Hey NASIOC Community! We got another Subaru to Part out for you. Vehicle Info: 2006 Subaru Impreza WRX STI 63K Miles OBP Obsidian Black Pearl STK# SU0037 Everything that was still good on this car is for sale. Body cuts are also available upon request. If you don't see something listed that you need, feel free to ask and I will get you the information. Parts Already Sold: Front Seats Rear Seat All Door Cards with switches Trunk Carpet Turbo Intercooler Brembos 6 Speed Trans EXTERIOR RH Grille - $45 Center Grille w/emblem - $50 Hood Scoop (ask for photos) - $75 RH Side View Mirror - $50 LH Front Ext Door Handle w/ Lock Cyl - $30 RH OEM Tail Light - $125 LH OEM Tail Light - $125 OEM Roof Vane Spoiler - $150 LH Side Skirt (has crack) - $50 RH Side Skirt - $75 Hood Scoop Splitter Only - $50 LH Front Bumper Vent - $15 Misc. Exterior Hardware - $20 Factory Cat Back Exhaust - $75 Exhaust Hanger Set - $25 17" Spare Wheel & Tire - $50 INTERIOR Speedo Bezel - $15 Column Bezel - $10 LH A-Pillar Gray Trim - $20 Misc Interior Hardware - $15 Blue Main Carpet - $100 Interior Door Handle Set W/O Bezels - $40 DBW Acc Pedal - $50 Steering Wheel w/o Bag - $75 Passenger Dash Air Bag w/o Cover - $50 Clock w/ Bezel - $35 Glove Box - $50 Int Rear View Mirror w/Homelink, Compass, Autodim - $75 Spare Tire Board Cover - $25 I/C Spray Tank - $50 Brake/Clutch Pedal Assembly - $ 6 Disc AM/FM Radio - $100 Set Of 4 Speakers - $50 Main Dash Harness - $ Headlight Level Adjust Switch - $20 I/C Spray Switch - $20 Owners Manual - $25 STEERING/SUSPENSION/DRIVETRAIN Intermediate Shaft - $50 Steering Column w/Ignition Switch - $ Drive Shaft - $100 Rear Diff - $425 Frt RH Axle - $150 Frt LH Axle - $150 Rear RH Axle - $150 Rear LH Axle - $150 Rear T-Shape Frame - $75 Rear Suspension Frame - $100 Rear RH Knuckle Assm - $125 Rear LH Knuckle Assm - $125 Front RH Knuckle Assm - $125 Front LH Knuckle Assm - $125 Frt RH Lower Control Arm - $150 Frt LH Lower Control Arm - $150 LH Trailing Arm - $40 RH Trailing Arm - $40 Front Sway Bar w/Links & Brackets - $50 Rear Sway Bar w/Links & Brackets - $50 Frt RH Strut Assm - $100 Frt LH Strut Assm - $100 Rear RH Strut Assm - $100 Rear LH Strut Assm - $100 Steering Rack w/T-Rods - $250 ENGINE Shortblock Only - $1000 Both Heads Available Upon Request - $ Harmonic Balancer - $40 Air Cleaner "Resonator" Only - $25 02-07 K&N Short Ram Intake - $175 Pair Of Side Feed Fuel Rails - $75 Yellow Side Feeds - $125 Fuel Pump - $100 LH & RH Exhaust Manifolds - $ Bare Intake Manifold - $ Throttle Body - $100 RH Inner Timing Cover - $10 RH Intake Cam Gear/Sprkt - $50 RH Exhaust Cam Gear/Sprkt - $75 TGV Pair - $200 LH Intake Cam Gear/Sprkt - $50 OEM Catless Uppipe - $65 Front Exhaust Pipe/Crossover (manifold to manifold) - $50 OEM Turbo Inlet - $75 Brake Booster w/ Master Cyl - $80 ABS Pump/Mod - $100 Alternator - $50 Coils - $40 a piece Main Engine Harness - $200 Coolant Res - $50 RH 7 Blade Fan Assm - $75 Warranty Information: Everything that is good on our cars are for sale. Please don't hesitate to ask.* Please keep in mind we may not always have the lowest prices but we try our best to price our parts as fair as possible according to condition and miles on the car. If you think something is priced too high, don't hesitate to bring it to my attention. Everyone makes mistakes sometimes. All of our parts carry a 90 day parts warranty and we really do care about not selling junk parts. If for whatever reason you have a problem with the part I will do everything I can to make sure you are happy with your purchase. We have the car dismantled and have pictures of most of the parts. If you would like to see a picture of the part you are interested please just ask and I will post it up for you with a price. Please ask any questions you may have, I will try to keep up with the PM's and thread posts... Thanks!! Isaac Click HERE to view our Online Policy. Oak Leaf Auto Salvage
__________________
[SIZE="3"][CENTER][COLOR="Red"]** To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ** To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ** To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ** Or you can always call us at @ 715-362-9445 [/COLOR][/SIZE] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] Last edited by oakleaf; 07-22-2013 at 10:56 AM. |
07-19-2013, 04:23 PM | #3 |
Member#: 202399
got it
__________________
[SIZE="3"][CENTER][COLOR="Red"]** To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ** To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ** To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ** Or you can always call us at @ 715-362-9445 [/COLOR][/SIZE] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] |
07-31-2013, 05:15 PM | #5 |
Member#: 202399
Hey,
We actually try keeping the springs with the full strut assembly unless the struts are no good :/ If we had a bunch in inventory I would be more than happy to separate for you but they do tend to sell as an assembly pretty quick. If there is anything else you need though please feel free to let me know. Thanks
__________________
08-09-2013, 02:47 PM | #7 |
Member#: 202399
__________________
08-10-2013, 09:06 AM | #9 |
Member#: 202399
Hey just a heads up, I tried sending you a PM and you have selected to not receive PM's
Anyway we only have the short block from this car. The heads have been sold. Thanks!! Josh
__________________
