02-04-2007, 01:15 AM | #1 |
Member#: 104418
VIC
Vehicle:2002 braless WRX In a blue skirt |
Recurring power loss to stock stereo and clock
This winter I've had recurring power loss to my 02 wrx's stereo and stock digital clock display as if a resettable fuse has blown. The power loss occurs after I've been driving 20 - 30 minutes and I'm suspicious it's heat related because it will reset after the car has sat, turned off, for at least 15 minutes. After that it will power out in only 5 - 10 minutes. It's been winter so I'm running the heat at about mid heat setting and #2 or #3 fan setting. At first I thought it was a stereo problem but once it went off when I hadn't been playing the stereo at all. I lose the stereo display and audio and clock display. I don't lose my clock setting or stereo/CD setting when it comes back on later.
Any ideas? At least can someone give me a link to a wiring diagram that can help me trace back to a resettable fuse of some type.?
02-04-2007, 02:47 AM | #2 |
Member#: 124104
South East
Vehicle:2006 Impreza WRX Wag Black |
dood im a nood check the sticky and do a search for the wiring diagram
02-05-2007, 12:52 AM | #3 |
Member#: 104418
VIC
Hey "nood" why don't you search for me if it's so easy. Or at least point out the sticky that would answer my question. I've searched the depths of my cluneal folds for a general wrx wiring diagram thread - first on the audio section where I also posted my problem because I thought it was the stereo. Now I'm posting here to seek the help of some of the intellect out there that might be able to point me in the right direction now that I realize it's not the stereo.
If someone has the schematic for the stereo and clock power supply so I can follow it back I'd appreciate it. C'mon, I just know there's gotta be more helpful guys/gals out there than "nood". |
FS TX - plug and play wiring to add amp(s) to stock stereo | Eezyal | Interior/Dressup/Audio & Security | 1 | 01-09-2009 10:43 AM |
Power output of stock stereo?Direct speaker replacement options? | MaestroB | Car Audio, Video & Security | 8 | 10-01-2006 02:18 PM |
Power Loss at 3.5K and 4.5K | STiMULi | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 08-09-2006 04:46 PM |
balancing the clutch and throttle for minimal power loss time between 1st and 2nd | asbWRX04 | Newbies & FAQs | 30 | 05-20-2004 12:44 AM |
Need guage pod to hold stereo in clock location | Kegger | Interior & Exterior Modification | 4 | 04-17-2004 12:28 PM |
