Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-14-2014, 08:47 AM   #126
AWDfreak
Member#: 126280
2014 XV Crosstrek
Originally Posted by RallyDrivR13 View Post
so anyone know the model code for the 2015 STI ??
VA applies to 2015-???? model years WRX and WRX STI 4-door sedans. Fourth and fifth characters in WRX and WRX STI vehicle identification numbers confirms this.
AWDfreak is offline   Reply With Quote
Old 07-15-2014, 03:05 AM   #127
maximo61170
Member#: 388853
I've tried to research but I guess I'm not too good at it.
But I have a 2014 STi wagon and I know my code, from my vin, is GR8. But the breakdowns I see don't make sense.
The GR is the 08-14 hatch. Cool.
But I've been seeing GRB where the B represents an STi.
Also I've seen that the 8 represents a 3.0L engine but I know my car has 2.5.
Probably doesn't matter too much but any clarification would be cool. Thanks.
maximo61170 is offline   Reply With Quote
Old 11-06-2016, 04:57 PM   #128
deej101
Member#: 457741
Default what is GDD in the VIN number of a STI 9 convertion?
VIN : JF1GDDKE57G065553
I've searched everywhere what stands for GDD?? GDA and GDB exists...Could somebody explain this please?
deej101 is offline   Reply With Quote
Old 09-26-2017, 01:14 PM   #129
anarekist
Member#: 468117
2017 WRX
DMG
needs an update.
i think VAG applies to 15+ WRX
and VAB applies to 15+ STI
anarekist is offline   Reply With Quote
Old 10-06-2017, 10:52 PM   #130
Scuubz
Member#: 474274
2008 WRX Wagon
Hold on now. Does this not differentiate between WRX and STi for USDM cars? My VIN says GH7, initial chart indicates 7 as STi 2.5. I just have an 08 WRX wagon.
Scuubz is offline   Reply With Quote
Old 10-19-2017, 06:56 AM   #131
Jpilch16
Member#: 476311
Default my99
Usdm 99 legacy brighton also has the phase 2 ej22
Originally Posted by stimpy View Post
A lot of people throw around GC8, BC/BF, GGA, GDB, etc, but often times people don't really know what they mean. These are chassis/engine combinations for various model codes of Subarus. Some of these terms are being used interchangably, when they must be uniquely identified.
When referring to a chassis alone, you use the first two characters of the model code.
1993-2001 Impreza Chassis:
Sedan: GC
Coupe: GM
Wagon: GF
2002 - 2007 Impreza Chassis:
Sedan: GD
Wagon: GG
2007 - 20013 Impreza Chassis:
Sedan: GE
Hatch: GH
Widebody hatch: GR
Widebody sedan: GV
1990-1994 Legacy Chassis:
Sedan: BC
Wagon: BF
(Yes, the C and F indicate the same chassis as Imprezas)
1995-1999 Legacy Chassis:
Sedan: BD
Outback Wagon: BG (Raised roof)
Wagon: BK
2000+ Legacy Chassis:
Sedan: BE
Wagon: BH
Forester Chassis:
1998-2002: SF
2003-2008: SG
2008-2013: SH
SVX Chassis:
1992-1997: CX
The third character refers to the engine that particular chassis was equipped with from the factory. The engine code itself implies engine size, configuration, and other things like radiator type and crossmember used.
Due to some confusion on the VIN versus the applied model code, the table has been revised to show Model Codes and VINs.
Applied Model Codes:
1.8L (NA-Impreza): 5 (ie: GC5 is a 1.8L Impreza Sedan)
2.0L (pre-MY01 WRX): 8 (ie: GC8 is a 2.0L Impreza WRX Sedan)
2.0L (MY01+ WRX): A (ie: GGA is a 2.0L Impreza WRX Wagon)
2.0L (MY02+ WRX STi): B (ie: GDB is a 2.0L Impreza WRX STi Sedan)
2.2L (NA): C (ie: GFC is a 2.2L Impreza Wagon)
2.5L (NA-Impreza): E (ie: GME is a 2.5L Impreza Coupe)
2.5L (NA-Legacy): 6 (ie: BE6 is a 2.5L Legacy Sedan)
2.5L (XT): 6 (ie: SG6 is a 2.5L Forester XT)
2.5L (STi): 6 (ie: GD6 is a 2.5L Impreza WRX STi Sedan)
3.0L (H6): 9 (ie: BE9 is a 3.0L Legacy Sedan)
VIN Chassis Codes:
1.8L: 2 (ie: GC2 is a 1.8L Impreza Sedan)
2.0L: 2 (ie: GD2 is a 2.0L Impreza WRX Sedan)
2.2L: 4 (ie: GF4 is a 2.2L Impreza Wagon)
2.5L (NA and XT): 6 (ie: GM6 is a 2.5L Impreza Coupe)
2.5L (STi): 7 (ie: GD7 is a 2.5L Impreza WRX STi Sedan)
3.0L (H6): 8 (ie: BH8 Is a 3.0L Legacy Wagon)
3.3L (H6): 3 (ie: CX3 is a 3.3L SVX)
Some of this information is trivial, but in some cases being specific will ensure the correct answer to your question.
Specific model code indication required:
If you are requesting fitment of a radiator into a GFA, there are two things to consider: GF indicates pre-MY02 Impreza chassis, while A indicates it is a 2.0L turbo engine. For a vendor to simply reply saying that, yes, they have a GC8 radiator ( when it is really a GC4/6 radiator) does NOT mean it will apply to your application. It does means it will fit the GC/GF chassis, however. Since you have a turbo engine (A), it means you probably do not want a radiator designed for a naturally aspirated engine (6).
Specific model code indication not required:
If you ask if a STi V6 drivetrain will fit into a GC8 chassis, then of course it will. That is the exact car the engine is in. However, if you are asking if it will fit into a GC/GF chassis (or maybe just GF4 specifically), then your question is less ambiguous as to what you are trying to do. However, it is obvious to see what is being asked.
-Jon
Jpilch16 is offline   Reply With Quote
Old 12-24-2018, 11:18 PM   #132
marbintorres
Member#: 495280
my vin is :SF5-018862
car is a JDM SF5 forester
i am not sure what the engine is. but im sure it is a turbo engine.
but it says in the plate: EJ20GDX1NY
marbintorres is offline   Reply With Quote
Old 02-16-2019, 07:06 PM   #133
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
WRX = V
Sedan = A
2015-2017 = A-C
2018-2019 = D-E
WRX sedan = VA
WRX sedan STI = VAB
WRX sedan S4 = VAG
Example WRX STI 2016 = VAB-B
WRX automatic = CVT
WRX 6-speed = Type TY75
WRX STI 6-speed = Type TY85
WRX 2.0 litre FA engine
WRX STI 2.0 litre EJ engine (Japan, other countries)
WRX STI 2.5 liter EJ engine (Australia, Europe, North America)
All are turbo and AWD
Levorg
V = WRX based/shared platform
M = Wagon
4 = FB 1.6 litre
G = FA 2.0 litre
VM4/VMG
Both are turbo, CVT, and AWD
Old 04-06-2019, 09:48 PM   #134
ANTONIO1986
Member#: 500060
Angry 2013 wrx roughness issue
Hello I'm new here I bought a 2013 wrx and started to have some idle problems so I checked my ap for roughness and it showed all cylinders and the worst one was cylinder 1 with a high 21 count I checked compression and performed a leak down and past changed all plugs and coils replaced maf and checked for leaks at the dealership it showed that they replaced the engine harness at one point plz help could it be an injector problem or ground
ANTONIO1986 is offline   Reply With Quote
Old 06-21-2020, 04:44 PM   #135
Numbah1
Member#: 515794
Wow, ive been here for an hr and this the best thing ive seen so far
Numbah1 is offline   Reply With Quote
Old 09-06-2021, 05:39 AM   #136
shaneob
Member#: 526425
Default 2014 Subaru forester dash lights up
2014 Subaru XT 2.0, changed spring clock and angle sensor with battery connected. now nothing works.
AT Heat light, ABS, Tranny stuck 1st gear, Coolant blue\red flashing, engine check light. RPM m***65279;eter doesnt work, AC doesnt work***65279;
suggestions for fix and troubleshooting.
shaneob is offline   Reply With Quote
Old 09-06-2021, 06:53 AM   #137
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Start going through your fuses. Probably popped something.
snow_bound26 is offline   Reply With Quote
2009 Legacy/Outback Model Codes and Colors Jon [in CT] News & Rumors 86 05-14-2008 09:56 PM
piston slap: and what does it mean to you? WRXwannbe Normally Aspirated Powertrain 16 02-02-2006 05:48 PM
p1086 cel will it cause this (read)? and what does it mean suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-09-2002 02:31 PM
H-R-W-XYZ....ratings..what do they REALLY mean? GooseMan Brakes, Steering & Suspension 9 02-08-2002 02:25 PM
whats the different types of computer controled air/fuel devices and what they do? v6scoobie Technical Forum Archive 1 09-09-2000 05:38 PM
