Tire & Wheel Forum sponsored by The Tire Rack |
05-11-2013, 01:19 AM | #2426 |
Member#: 353711
International
Vehicle:2002 WRX Wagon Silver |
Shagon wagon
[quote=rosedaleny806;39779748]thats a very width and offset. you wont need to roll or anything. especially at stock suspension
How about 225/40R18 S.Drives 18X7.5 ET45? still stock suspension
05-11-2013, 08:16 AM | #2427 |
Member#: 337691
Vehicle:2007 WRX BLACK |
just ordered a set of wheels, so looking for some opinions on the set up im working on, maybe some advice on doing something a lil different
year: 07 model: wrx tr wheel model: xxr 527 wheel size: 18x8.75 +35 tire model: federal 595 tire size: 255/35/18 suspension: megan street series coilovers alignment: N/A fender mods: roll+pull all around this is the set up i would like to have, just looking for any opinions or advice before i order tires, thanks in advance |
05-11-2013, 08:19 AM | #2428 |
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
Why do people order wheels BEFORE asking for advice here? I don't get it.
05-11-2013, 09:08 AM | #2429 |
Member#: 353711
International
asking first
05-11-2013, 12:06 PM | #2430 | ||
Member#: 97135
NWIC
this isn't a picture thread or picture forum. Quote:
you'll still need to roll and most likely pull. |
05-12-2013, 04:20 AM | #2431 |
Member#: 353711
International
Does wheel width effect what offset you should run? Meaning, if I run a 7.5 with et 48 and want to go to a 8.5 should the offset change as well to keep from rubbing the strut? I have a wagon which already has limitations but want to run a larger wheel (both wider and taller). My plan is to run to a 225/40R18 (or 17) as long as I don't have to have neg camber or fender pull. If anyone running a bugeye wagon has some input it or does/don'ts it would be greatly appreciated.
05-12-2013, 10:11 AM | #2432 |
Member#: 237565
Vehicle:I haz 06 WRB Wagon |
Yes. In general, a wider wheel will require a lower offset. However, an 18x8.5 +48 will fit under a wagon with 225/40/18s with little issue. I ran a 235/35/18 (a little bit short sidewall, but wider tire) on an 18x8.5 +48 on my wagon and only had to roll the fenders because I was dropped at least 2" below stock. I ran -1.5* of negative camber up front and the rear was natural camber from lowering the car.
05-12-2013, 07:31 PM | #2433 |
Member#: 328250
NWIC
Vehicle:2006 STi Blue |
Alright I came across a really good deal so I'm just looking for some feed back and advice on my summer wheels I wanted to get. Tires and wheel fitment hasn't been my strongest subject
Year: 2004 model: WRX WAGON Wheel model: BBS rs replicas Wheel size: 17x10 +20 Tire Model: N/A Tire Size : N/A Suspension: Eibach lowering springs (2 inches) alignment: Eibach camber bolts (uninstalled) fender mods: plan on a roll and pull I would assume I need a roll and pull, and I would install the camber bolts, what size tires would you guys recommend? Would I have to stretch the tires? I was hoping to avoid stretching. Thanks in advance Last edited by Derek23; 05-12-2013 at 07:39 PM. |
05-12-2013, 07:50 PM | #2434 |
Member#: 237565
You'll need a lot more work than is worth it, unless you're getting those wheels for free. Especially if you're new to the fitment game. If you want to avoid stretching tires, you're going to have to run a 245 or 255 which will not fit under a wagon without flares, especially with that offset.
05-12-2013, 08:11 PM | #2435 |
Member#: 328250
NWIC
What work would I need? I've read a couple people saying 17x10 wasnt too hard to fit. I pretty much am getting them for free through a straight trade. If it is a must I would do a minor stretch i guess
05-12-2013, 08:15 PM | #2436 |
Member#: 124254
NESIC
Was this person talking about a wagon? Because wagons have far less room for wide wheels.
05-12-2013, 08:19 PM | #2437 |
Member#: 328250
NWIC
its true they have less clearance but I've talked to people with 17x10s on their wagons
05-12-2013, 08:23 PM | #2438 | ||
Member#: 237565
05-12-2013, 08:37 PM | #2439 |
Member#: 328250
NWIC
Thanks for the info flat4LGT! The camber bolts might get the job done I had them at 2.5 degrees before on a previous set up! Is stretching tires a must?
05-12-2013, 08:41 PM | #2440 |
Member#: 237565
Pretty much. What it does is slant the sidewall so it clears the fender even if the wheels themselves poke past the fender. If the sidewall is squared up, it will rub as the suspension compresses, since the fenders curve in.
Like so: If the sidewall was squared, the fenders wouldn't clear the tire. |
05-12-2013, 08:54 PM | #2441 |
Member#: 328250
NWIC
Ahh, I get it now. Thanks that was a good explanation
05-13-2013, 01:09 AM | #2442 |
Member#: 97135
NWIC
05-13-2013, 09:22 AM | #2443 |
Member#: 202070
South East
Vehicle:2012 WRX GR LSB/Gold 2002 WRX GDB PSM |
18x9.5 +20 235/40/18 |
05-13-2013, 11:09 AM | #2444 |
Member#: 97135
NWIC
05-13-2013, 11:10 AM | #2445 |
Member#: 202070
South East
so you cant post pictures to show fitment on a fitment thread...sounds legit. stop being all sandy vag, you dont like the pics move on, thats all.
05-13-2013, 11:35 AM | #2446 | |
Member#: 97135
NWIC
Like I said. You have 2 previous posts already with pictures. This is not a "stance" thread, this isn't a "meaty" thread, it's a technical assistance thread. Yes, pictures for reference are GREAT and encouraged, but this isn't the place to whore out pictures of your car. |
05-13-2013, 11:38 AM | #2447 |
Member#: 202070
South East
whoring out would be me posting every few posts, bc if you want me to "whore" out i can defiantly whore it out. yes this is a technical assistance thread, but without pictures noone will notice ****, i lowered my car more so anyone with a 11+wrx or 08+ sti can see how the set up is. like i said you dont like the pictures i post for ASSISTANCE in this thread you can go cry to someone who cares, bc i sure as hell dont
05-13-2013, 11:41 AM | #2448 |
Member#: 268918
Vehicle:2006 WRX STi World Rally Blue |
^ Agreed to an extent. No need to keep posting up pictures.
05-13-2013, 11:49 AM | #2449 | |
Member#: 237565
I posted a picture yesterday to demonstrate what stretching tires and negative camber does to allow proper fitment, not to show off my fitment. 18x9.5 +38 with 235/35/18 tires on BC BR coilovers running -2.7* F/-2.9* R camber and all 4 corners rolled and pulled for those that care. |
05-13-2013, 11:51 AM | #2450 |
Member#: 202070
South East
i explained what suspension i was on a few days/last week when i posted in here for the first time. i explained my suspensions set up, my body mods that i had to do and thats it.
ill explain again... rear fender rolled, fronts stock, BC type BR coilovers and natural camber from lowering still no adjustements to that but soon enough |
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
