05-10-2012, 12:19 PM | #4901 | |
Member#: 241216
Vehicle:2000 Outback 2013 SWP BRZ |
I don't know who to suggest for an e-tuner.. I went with Ron at PhatBotti, but so far I'm very unimpressed. His emails are always short, he seems to gloss over details (one of which is my name, ha), and it seems very impersonal. For the amount I paid, I expected better customer communication. His grammar and spelling is very unprofessional.. I know that's nit-picky, but I have my own expectations for how a business should be run. We'll see how well his tune does... I'm expecting 300 at the wheels reliably. Only time will tell though.
05-10-2012, 02:20 PM | #4902 | |
Member#: 270699
Vehicle:2005 WRX Wagon OBP |
05-10-2012, 03:28 PM | #4903 |
Member#: 306892
Vehicle:2006 wrx flat black |
Anyone in town good at painting rims I need mine redone
05-10-2012, 03:47 PM | #4904 | |
Member#: 203783
Vehicle:2005 LGT |
haha yup that was me that had the toggle switch for the flash blocks, i grabbed my switch from radio shack. it happened to be a DPDT switch so i could turn on 12v to the flash blocks at the same time. |
05-10-2012, 03:56 PM | #4905 | |
Member#: 241216
Eric, was that switch a direct drop in, or did you have to modify one of the hole covers? |
05-10-2012, 08:30 PM | #4906 |
Member#: 319020
Vehicle:15 STI 04 Fozzy XT |
Anyone have a set of good heads for a EJ20..? I have a spark plug that may not come out without a fight.
05-10-2012, 10:36 PM | #4907 |
Member#: 203783
Vehicle:2005 LGT |
I modified one of the hole covers, just drilled a hole in it, it was pretty simple. and if i wanted to replace it the covers are pretty cheap.
05-11-2012, 06:04 AM | #4908 | |
Member#: 241216
Sam at K&M Northfield Dodge Body Shop will hook you up.. Just tell him Travis sent you.
05-14-2012, 06:02 AM | #4909 | |
Member#: 156634
Vehicle:2000 Fozzy S White / Grey Met |
I have a pair of DOHC Ej25 heads. Fresh surfaces / pressure tested / inspected/ new seals / reshim'ed to spec. It would need to drill / tap for the turbo oil needs. Easy task. EJ20 heads should be no prob to find if not. |
05-14-2012, 10:25 AM | #4910 |
Member#: 319020
[quote="rallyknight13"]
Did LENGER Racing look at this one? I have a pair of DOHC Ej25 heads. Fresh surfaces / pressure tested / inspected/ new seals / reshim'ed to spec. It would need to drill / tap for the turbo oil needs. Easy task. EJ20 heads should be no prob to find if not.[/QUOTE Talked to Ryan at Lenger Friday about it, he is was sending me a quote Friday but I have been having email problems at work. Really want to get started on the Saabaru..... |
05-14-2012, 10:30 AM | #4911 |
Member#: 46277
Vehicle:H1 Viper LP640 FGT |
05-17-2012, 02:31 PM | #4912 | |
Member#: 241216
05-17-2012, 03:31 PM | #4913 | |
Member#: 166290
Vehicle:04 EJ207 GT30R 6MT SRR Widebody Wagon |
05-17-2012, 08:34 PM | #4914 | |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
05-18-2012, 08:47 AM | #4915 |
Member#: 57287
Vehicle:2002 Bugeye STi MY07 WRB FXT |
Rob,
Hey you planning on doing any AutoX the weekend of June 2-3? I am heading down to Grissom with Mike Aumick for the 2 Day event. Details: South Bend Region - Grissom Aeroplex AutoX |
05-19-2012, 07:30 PM | #4916 |
Member#: 241216
Anyone have good luck getting Windows 7 to communicate with the AEM UEGO gauge, and the BFM Wideband Cable? My computer keeps failing the install. I really need to be able to get this thing up and going to continue with my tune.
Edit: After more reading, it looks like BFM supplied me with a Chinese cable. I've downloaded all sorts of drivers, and all of them list the same thing, which is what Prolific says will happen if you try to use their drivers with a Chinese cable. I think I'll be buying the cable you said you bought on RomRaider Rob, the one with the FTDI chipset. That blows.. BFM is horrible it seems. I won't ever recommend that company to anyone. Last edited by Travisty; 05-19-2012 at 09:04 PM. |
05-19-2012, 09:56 PM | #4917 |
Member#: 203783
Vehicle:2005 LGT |
Have you contacted BFM at all? Hes a pretty friendly and helpful guy.
05-19-2012, 09:58 PM | #4918 |
Member#: 241216
Just sent him an email. I also just ordered the cable that Rob said worked for him. It should be here mid-late next week.
05-19-2012, 10:22 PM | #4919 |
Member#: 203783
Vehicle:2005 LGT |
The tactrix brand cable? that should work no problem, its too bad the cheap version didn't work for ya.
BTW here are the drivers etc that i am using with windows 7 FTDI drivers: 2.6.2.0 Romraider v0.5.3 Beta RC9 ECU Flash Version 1.41.2483 Everything has to run as admin and in win xp sp 3 compatibility mode. Might not help but i thought i would let you know what i am running successfully. Does the chip inside the cable say FTDI on it? mine does, and its a $12 vag com one. |
05-20-2012, 07:16 AM | #4920 | |
Member#: 149262
Did rallyx at S Lyon yesterday. Very dusty. But really fun. Detroits scca has a two day event next weekend at MSU. Thatll be fun. Where's your new car? |
05-20-2012, 11:47 AM | #4921 | |
Member#: 57287
I wish i could race next weekend but I am on Call. So I need to stay a bit more local to Kzoo. |
05-20-2012, 08:32 PM | #4922 | |
Member#: 241216
I've given up trying the VAG-COM cable, it's not worth it. The more experience I get with cheap chinese cables, the more I think that's the kind of VAG-COM I got, and that's why my cable doesn't work, yet everyone elses does. |
05-20-2012, 10:03 PM | #4923 |
Member#: 149262
I went through 3 USB to serial cable before I hit the right one.
05-21-2012, 10:17 PM | #4924 |
Member#: 317890
Vehicle:04 sti |
so like i said im new to the forum was wondering if there was any like weekly get togethers in the area would like to meet some other scooby owners
05-21-2012, 11:36 PM | #4925 |
Member#: 203783
Vehicle:2005 LGT |
There used to be a weekly meet at sonic on friday nights, but im not sure if they still meet. Check the Grand Rapids Import Network group on facebook not all subies but there are a few.
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? | Scooby do | Mid West Subaru Owners Club Forum -- MWSOC | 19 | 05-25-2012 02:09 PM |
Good alignment shops in the Grand Rapids/Muskegon areas? | Paradenu | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 12-08-2006 01:20 PM |
Anyone close to Grand Rapids going to the Ojibwe ProRally? | penjaja | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 08-13-2002 01:55 AM |
Grand Rapids | metroplanner | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 06-15-2001 05:00 AM |
Grand Rapids MI Autocross | Scooby do | General Forum Archive | 0 | 09-27-2000 03:26 PM |
