12-06-2013, 04:55 PM | #3051 |
Member#: 22923
International
Vehicle:2002 EJ207 V8 1.5xtr TWIN-SCROLL Black Bugeye |
^^I only had to do it a single time myself. No issues. I wouldn't hesitate a second time provided it was still within specs. I'm not a pro-mechanic though and leave those type decisions to my pro-sponsor-shop.
12-06-2013, 05:01 PM | #3052 |
Member#: 276443
TXIC
Vehicle:2005 2.1 stroker WRX OBP |
well my current tuner and my engine builder both recommended that it be resurfaced.
12-07-2013, 04:10 AM | #3053 |
some old guy
Moderator Member#: 112225
AKIC
Vehicle:1985 78 HP of Rage! Blue |
12-07-2013, 05:55 PM | #3054 |
Member#: 354354
Deleted for wrong thread
12-07-2013, 06:45 PM | #3055 |
Member#: 276443
TXIC
Well i finally fixed my cold start issue!
Tgv deletes have always given me a problem. I copied over the Jdm ecu warmup tables from a 05 as they do not have tgv valves and it fixed my issue! Started as if i had tgvs when i first got the car. Ugh so relieved. |
12-09-2013, 12:46 AM | #3056 |
some old guy
AKIC
Did all 4 corners this weekend... I hate working on suspension. (Dirty, frozen bolts, things under pressure)
12-09-2013, 01:22 AM | #3057 |
Member#: 374973
Installed new rear shocks today(what a bear!)
Replaced my thermostat, which seemed to alleviate some of my warm up issues. Also replaced my throttle cable and set up the linkage a little different to allow full throttle and return to idle. Then did some low speed carb tuning(idle speed/low idle mixture) Seems to be running much better now, have to see how it acts when temps plummet again. Now the to do list is figure out why my rad fan doesn't work... |
12-09-2013, 01:25 AM | #3058 |
some old guy
AKIC
I think I have an extra fan if you need to test it.
12-09-2013, 03:00 AM | #3059 |
Member#: 290921
AKIC
Vehicle:2010 Impreza WRX prm WR Blue |
12-09-2013, 04:19 AM | #3060 |
Member#: 291227
AKIC
Vehicle:2002 WRX PSM |
Oh damn that turbo
12-09-2013, 01:00 PM | #3061 |
Member#: 354354
Yesterday I changed my oil and put on some LAMIN-X yellow film over my fogs. Not as yellow as I was hoping so ill probably get some bright yellow 9006 bulbs somewhere. Anyone have suggestions?
12-09-2013, 02:01 PM | #3062 | |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
Today I dropped off my car at CCA. Will take pics when I pick up. |
12-09-2013, 07:55 PM | #3063 |
Member#: 276443
TXIC
Well since the motor was built. Got worse with speed density. About 1yr
Good now! |
12-09-2013, 11:38 PM | #3064 |
Member#: 100607
AKIC
Vehicle:2019 STI-His 14 XT-Hers |
12-09-2013, 11:52 PM | #3065 |
Member#: 290921
AKIC
Congrats what was up with it just needed a new bulb
12-09-2013, 11:55 PM | #3066 |
Member#: 100607
AKIC
Yeah, seems good to go now. The outgoing bulb did have some discoloring so I hope its nothing else like the ballasts.
12-10-2013, 12:00 AM | #3067 |
Member#: 290921
AKIC
Ya I'm going to end up gouging with the 4300k instead of the 6000k
12-10-2013, 12:05 AM | #3068 |
Member#: 32993
AKIC
Vehicle:vf39 Best trap 110 Best ET 12.51 Dale tuned |
I've got new capsules(5000k) and some new 90 degree connectors, the new capsules should match the heat range of the RI light bar on the front
12-10-2013, 12:12 AM | #3069 |
Member#: 290921
AKIC
12-10-2013, 12:17 AM | #3070 |
Member#: 100607
AKIC
I did a little research before I purchased and tried to get the "most useful", which turns out to be the around 4300ish. I got 5000k because I didn't want the hint of yellow that is put out by some 4300k.
12-10-2013, 12:33 AM | #3071 |
Member#: 290921
AKIC
Ya I know what ya mean I ended up getting the 4300k for the fogs and they look really good so I thought I'd match the low beams as well high beams not sure what I want to do maybe LED
12-10-2013, 02:09 AM | #3072 |
Member#: 227288
AKIC
Vehicle:2006 MCS JCW Pepper White |
Had it towed to it's final resting place.
Let the part out begin! |
12-10-2013, 02:35 AM | #3073 |
Member#: 290921
AKIC
12-10-2013, 02:53 AM | #3074 |
Member#: 185030
AKIC
Vehicle:2016 FXT Satin White Pearl |
12-10-2013, 09:35 AM | #3075 |
Member#: 227288
AKIC
