08-05-2010, 08:22 PM | #51 |
Member#: 98798
NESIC
Vehicle:04 impreza STI Black |
damp a rag with a rubbing alcohol gently rub it off then was off with water or air dry then wax the spot.
08-06-2010, 10:52 AM | #52 |
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
....it makes me wonder sometimes where some folks get their information.
OP, I'm not suprised clay didn't work. Yes, while clay does help remove many types of bonded contaminants on the surface of your paint, the issue you describe is much more extreme. I agree with Krauser in his one point that clay isn't the magical device some folks seem to think it is. There are heavier cuts available for more serious contaminant removal but if you're trying to take off blobs of sap that have been baked onto your paintwork, I don't think you will have much success with those either. If heat, IPA, bug & tar remover and some of the other suggestions are not working (assuming you're being patient and doing it right), I would start thinking about enlisting the services of a good, experienced detailer. ....or at least get their advice on the matter before screwing it up even more. ....clay can help remove contaminants like overspray, rail/brake dust, industrial fallout, sap, honeydew, etc. What it doesn't do is act like make up and simply cover things up. The residue you see after claying a panel is mostly from the lubricant and some traces of the clay as it slowly breaks down. Both of which are easily wiped or washed away. Even when a user doesn't use enough lube and the clay catches the paint leaving transfer of the product, it is still realtively easy to wipe off with a detailer or to wash away. Any residue left after the process is not intended to remain on the paint as a "cover up". |
08-06-2010, 12:03 PM | #53 |
Member#: 153751
South East
Vehicle:2002 Mazda Miata The Darkness |
I'll take some photos today and post them of the sap.....it might be easier to show you rather than tell.
I've used alcohol goo gone bug and tar remover clay bar it just turned the sap white so not its more obvious lol |
08-06-2010, 10:08 PM | #54 |
Member#: 227747
NWIC
Vehicle:2006 STI (BW S363) SGM |
....clay can help remove contaminants like overspray, rail/brake dust, industrial fallout, sap, honeydew, etc. What it doesn't do is act like make up and simply cover things up. The residue you see after claying a panel is mostly from the lubricant and some traces of the clay as it slowly breaks down. Both of which are easily wiped or washed away. Even when a user doesn't use enough lube and the clay catches the paint leaving transfer of the product, it is still realtively easy to wipe off with a detailer or to wash away. Any residue left after the process is not intended to remain on the paint as a "cover up".[/quote]
ok so what your saying is that it takes it off clean and leaves no residue on the paint correct? so wouldnt it be logical that he could just take a putty knife and some lube and take the sap off that way? Ya no thats just dumb saying it doesnt leave anything on the paint whats the point of the clay then? and why does the area that you clayed feel like it has been waxed? Im just saying people give the clay bar WAY to much credit if you know how to detail cars right that **** is rarely used. |
08-06-2010, 10:48 PM | #55 | |
Member#: 220259
Vehicle:09 2.5i SSM |
The clay bar is rarely used because that's how often it's supposed to be used. You don't use it every time you wash your car. If anything, it's not given enough credit with all of the myths surrounding it and whatnot. |
08-07-2010, 12:15 AM | #56 | ||||||
Member#: 25187
Here are a few links to help explain the product and process: Clay - the can do tool by Kevin Ferrell Detailing Clay & Pre-wax Cleaning by David Bynon Do I need to wash my car after I use detailing clay to clay the paint? by Mike Phillips Tips and Tricks for using detailing clay by Mike Phillips Applying Auto Detail Clay by Anthony Oroso How often do I need to clay my car? by Mike Phillips How to Use Auto Detailing Clay by Autogeek Last edited by Kean; 08-07-2010 at 12:27 AM. Reason: added links |
08-07-2010, 03:37 PM | #57 |
Member#: 153751
South East
This is my hood after Turtle wax bug and tar remover, Goo Gone, Alcohol, claybar.
washed and waxed after each product and let it sit for a day before trying another. looks worse, should have just left them as the darker spots lol....**** ouch, that one is the worse...touch up paint time lol might be coming off? this pine stuff is a real bitch Last edited by krauser2; 08-07-2010 at 03:37 PM. Reason: double post |
08-07-2010, 05:32 PM | #58 |
Member#: 25187
....unfortunately, I believe what you're seeing there is mostly damage to the paint as a result of the sap being left to dwell (not so much the contaminant itself). You may be able to use a compound/polish to help improve the appearance of those blemishes but I highly doubt you will remove them completely. Short of a repaint, you can try some off the shelf products like Meguiars Ultimate Compound and Scratch-X/Swirl-X to follow up, but it may be better to seek the services of a professional or a fellow member near you with a polisher and products who would be willing to help. What you don't want to do is over-correct something that may not be entirely correctable. ....there is a point where you need to realize that messing it it further will compromise the paint to the point where it is unsalvageable.
08-07-2010, 05:39 PM | #59 |
Member#: 153751
South East
^^^agree totally
I would like to see what a body shop can do / quote |
08-07-2010, 05:53 PM | #60 |
Member#: 219513
Vehicle:2006 STI WRB |
I didn't read all the other pages of posts, but judging by the pictures what you have tried didn't work. I own a logging company, and by FAR the best thing to take off pine pitch is penut butter. Something about the peanut oil breaks down the pitch/sap. Figured i'd let you guys in on that little secret..like I said not sure if its been said or not yet. I'm currently cutting pine and I take a penut butter bath everynight after work LOL.
08-08-2010, 02:54 PM | #61 |
Member#: 234624
RMIC
Vehicle:2017 WRX WRB |
haha some of these responsesare hilarious! i would just go to the local auto paint store and get a clay bar. works wonders out here in evergreen colorado
08-08-2010, 03:08 PM | #62 |
Member#: 153751
South East
dude read the posts used claybar already I used all the stated products for these results...clay bar is not some magical device. Its a cool concept but ultimately some elbow grease will do the same thing |
08-08-2010, 03:17 PM | #63 |
Member#: 25187
08-08-2010, 05:01 PM | #64 |
Member#: 153751
South East
+1 |
08-10-2010, 10:28 AM | #65 |
Member#: 116398
Vehicle:08 STI OBP Tuned By Agile |
ive never had problems removing sap with aggressive clay, as some seem to say clay doesnt work well with sap removal. If done heavy sap removal from pine tree with it. never had any that it wouldnt remove.
More to the pictures posted though. I do agree with kean, that is damage to the clear/paint. it needs re-sprayed. |
08-10-2010, 11:02 AM | #66 |
Member#: 153751
South East
^ agree, the damage is done. I'll do what I can, not sure I want to drop the flow on that kind of job.
I;ve got primer, sand paper, WRB paint from subaru and clear coat, I'm going to see what I can do. |
08-10-2010, 11:19 AM | #67 |
Member#: 143802
Vehicle:2007 Imp 2.5i 5M Wgn Crystal Gray |
I'd try Murphy's Oil Soap to get the sap off, or Turtle Zip wax. Murphy's works on things that noting else will touch, and I have an old car with dull paint that paint got splashed on it, and after trying every other cleaner and solvent to try to remove it, the Zip Wax was the best, though a lot of the splashed paint was already gone, but it looked like the Zip would have made it easy, as fast as it removed what was left, that nothing else was getting it all.
08-10-2010, 12:09 PM | #68 |
Member#: 25187
I would honestly try to use a compound and polish on one of the spots first to see if the results would be something you could live with. Meguiars Ultimate Compound is an excellent product that works well by hand or DA. When using by hand, you will need to follow up with a lighter polish since the UC will tend to leave fine micro-marring. Meguiars Scratch-X 2.0 or Swirl-X should help with that (the latter being the lightest of the three and will finish the best). However, as I said before, there is a point where you will need to realize “this is as good as it’s going to get”. I would try that approach first before re-painting.
08-10-2010, 02:42 PM | #69 | |
Member#: 116398
08-10-2010, 03:05 PM | #70 |
Member#: 153751
South East
I've got scratch x and a polishing compound and 2K grit paper.
I'll try a couple things today and see what happens. I know it will never be completely gone, but close enough is fine by me. |
08-10-2010, 03:49 PM | #71 |
Member#: 143802
since turpentine comes from trees, maybe it will dissolve the the sap even if it baked on, though maybe a different type of tree.
08-10-2010, 06:11 PM | #72 | |
Member#: 25187
08-11-2010, 01:33 PM | #73 |
Member#: 89868
Vehicle:2005 Saab 9-2x Arctic Silver |
I used to park under redwood trees which dripped sap like crazy.
I also tried bug and sap remover, but it just didn't do anything--particularly for the old, dried in sap drops. The only thing I tried that really worked was Mr. Fantastick (that brand specifically) and lots of elbow grease. You'll want to be careful in light of your paint job, but it really did work. Of course, if you're paints already FUBAR then there's nothing you can do. |
08-18-2010, 03:03 AM | #74 |
Member#: 252005
BAIC
Vehicle:2004 STI Java Black |
2500 grit wet sand then rubbing compound then wax works well, first try the mothers mag aluminum polish might do the job.
09-30-2010, 01:25 PM | #75 |
Member#: 101713
RMIC
Vehicle:2001 F-150 Work Truck White |
Dang, I came into this thread hoping to find a panacea for the same problem (long baked-in sap), but apparently this is as difficult as it seems. I guess I'm going to try the peanut butter method now... what have I got to lose?
