02-05-2006, 08:12 PM | #1 |
Member#: 44581
BAIC
Vehicle:3 Boxers 2 AWD 3 turbo 1 6cyl & a 13BT |
STi Defi Genome Gauge Install questions
Where do the STi Defi Genome Gauges install? There is the boost, oil temperature, and oil pressure. I assume the boost installs similar to the subaru omori gauge, the vacuum line going to the bypass valve. What about the oil press, and temp? Does the oil press use one of the galley plugs on top of the block? Does the temp use the sensor/drain plug that the subaru omori gauge pack uses?
02-09-2006, 10:00 PM | #2 |
Member#: 44581
BAIC
anyone?
02-09-2006, 10:51 PM | #3 | |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
good choices for those sensors you are questioning. why would you want wires underneath the car? |
02-09-2006, 11:17 PM | #4 |
Member#: 44581
BAIC
All the Subaru omori oil temp gauges install in the oil drain plug. You ziptie the wires to the crossmember up through to the firewall. It's the "oem way" to do it, it's pretty accurate this way aswell since the sensor is reading from oil that is semi-stationary. I was just wondering if the STi Defi gauges used the same plug. But can't find any info on where the two oil sensors are tapped.
02-10-2006, 04:35 PM | #5 |
Member#: 70285
Vehicle:2011 JCW Mini Midnight Black/Red roof |
i have these gauges, and theres a sandwich adapter where both temp and pressure sensor go into.
02-10-2006, 10:04 PM | #6 |
Member#: 44581
BAIC
Ah, okay, that comes with the kit I assume? Do you have any pics?
05-16-2006, 02:58 PM | #7 |
Member#: 85035
Vehicle:2017 Forester XT KTM 690 Duke |
I would also like to know where to plug the power cord into. I have the Subaru oem gauges and thought it was the same plug behind the radio unit but it doesnt fit. Not sure if this plug is for the STi and I have to cut and splice the wires. Anybody here with answers?
05-16-2006, 04:42 PM | #8 |
Member#: 70285
I have these exact gauges, and theres a sandwich adapter for the oil gauges.
05-17-2006, 12:07 AM | #9 | |
Member#: 89757
International
Vehicle:2004 Impreza STI Black & dirty |
http://forums.nasioc.com/forums/showthread.php?t=988917 |
05-17-2006, 12:43 AM | #10 |
Member#: 85035
I have the sandwich adpater, no problem there, my question is where do I plug the power cord into? Or do I have to splice the wires?
Similar Threads | ||||
JDM Subaru Impreza WRX STi Defi Genome Gauges | b7g | Interior/Dressup/Audio & Security | 11 | 03-28-2008 05:19 PM |
quick defi egt gauge install question | Otaku64 | Electrical & Lighting | 4 | 05-20-2007 09:23 PM |
FS:WA: JDM STI/Defi/GeNome Boost Gauge ( green lights) | dscoobydoo | Interior/Dressup/Audio & Security | 7 | 05-02-2007 03:54 PM |
Defi Gauge Install Question... | STi300 | Interior & Exterior Modification | 0 | 05-01-2005 10:24 PM |
STi/Defi Genome Triple Gauge Pod | fatcatwrx | Interior & Exterior Modification | 14 | 06-30-2003 02:43 AM |
