03-24-2010, 04:50 PM | #1 |
Member#: 82989
SWIC
Vehicle:2002 WRX Hybrid EJ257 |
Anyone else have major problems adjusting JDM projectors?
I'm referring to the Bugeye JDM projectors. Seriously, these have got to have the poorest design ever for adjusting. First problem being the socket adjustments are PLASTIC and easily strip. I ended up over turning mine a little bit and could not get them to turn anymore because the plastic adjustment was already stripped! I had to drill a small hole so I could stick something through it to get leverage to turn them. Am I doing something wrong here? Has anyone else had this issue?
03-24-2010, 08:05 PM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
yew
ann NOT adjust them enough to make them not blind oncomming traffic |
03-24-2010, 09:53 PM | #3 |
Member#: 144821
Vehicle:1994 LS1 Miata 2015 white WRX |
The only right way to do this is to open up the housings and flip the cutoff shields.
03-24-2010, 10:34 PM | #4 |
Member#: 139853
Vehicle:2002 wrx....its tsxy silver |
having taken these lamps apart...you can't just flip shields. Either find the knock off lhd shields on evilbay and ope for the best, or retrofit proper projectors in them
03-25-2010, 02:46 PM | #5 |
Member#: 106225
Vehicle:02 WRX STied PSM 03 L, 05 GT Legacy Wagons |
Flipping the shields only works on the Hawkeye and newer projectors.
03-26-2010, 09:06 AM | #6 |
Member#: 27874
NESIC
Vehicle:2002 WRX V7 EJ207 DOM1.5 6MT 360 whp |
I ajusted mine yester day. 8mm gear rench worked great. The ajuster nuts are not in a good place and it was a pain to keep the rench on the ajuster when turning it, but it worked.
03-27-2010, 10:42 AM | #7 | |
Member#: 139076
Vehicle:2002 stg2 wagon 03 suzuki sv650s |
this is also an issue on normal usdm lights. subaru decided to use metal gear teeth on a plastic gear. not cool. if you have to, you can use a small wrench or pair of pilers to turn the plastic nut, basically bypass the 8mm section. that is just there to provide you with a decent angle to attach a socket. oh btw, youre blinding everyone with those jdms. |
Anyone else having major HP envy? | RebelINS | General Community | 22 | 01-05-2003 12:03 PM |
Anyone else have a problem with EGR? | HRE | giulio | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 02-09-2002 08:03 PM |
Can't log in until I post something. Anyone else having this problem? | Red-Imp | General Forum Archive | 7 | 07-12-2000 12:31 AM |
Anyone else having this problem? | Jeff 2.5RS | General Forum Archive | 18 | 06-19-2000 05:02 PM |
