04-06-2003, 12:12 PM | #1 |
Member#: 2971
quick defi egt gauge install question
i don't want to be stuck when i am installing it...are there any tools i need or special conversion adapters for the probe or anything else i may need to order before i take the car apart? also, i am guessing welding is required, correct?
thank you, -salvatore
04-06-2003, 04:36 PM | #2 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
you dont have to weld it. Just drill a hole in the place you want to mount it then tap the hole. And then screw in the egt sensor.
o and one other thing, does defi include the egt probe with the gauge or do you have to buy one at a local shop? |
04-07-2003, 12:36 AM | #3 |
Member#: 23570
NESIC
Vehicle:2002 WRX Sedona Red Pearl |
defi include the sender
05-18-2007, 12:15 PM | #4 |
Member#: 145585
Vehicle:2002 S202 10.8@128 Yellow |
I just got a Defi EGT. Where is the best place to mount the probe?
05-20-2007, 09:23 PM | #5 |
Member#: 39879
South East
Vehicle:2008 Infiniti G37S Graphite # 73 FS |
Probe
Mine is mounted in the Driver's side header. Read the gauge FAQ at the top of E & L , it is a very informative read and enjoyable.
Here is something else good to read |
07 Sti coolant line leak from defi egt gauge install. | ChronicPoe | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 08-16-2009 11:40 PM |
Defi EGT Gauge install HELP??????? | smac | Electrical & Lighting | 11 | 09-20-2006 10:43 AM |
defi EGT guage install question on STI | BoostdBoxer | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 18 | 01-05-2005 02:50 PM |
EGT gauge install questions | qoncept | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 02-23-2004 02:58 PM |
EGT gauge install question. | flyingace | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 10-28-2002 11:43 PM |
