Brakes & Suspension Forum sponsored by The Tire Rack |
12-26-2007, 12:25 AM | #1 |
Member#: 76497
NWIC
Vehicle:2006 Impreza WRB |
Chassis question - STi chassis different?
Is there anything structurally different on the STi other than cosmetic? Are there any factory mods, is it stiffer, heavier, lighter??? OR, are all the shells the same?
12-26-2007, 12:55 AM | #2 |
Member#: 98961
Vehicle:2003 WRX Black |
It's different. Rear wheel opennings are pre-rolled (the sheet metal lip isn't there). The U brace has additional bolt holes and body mounts. There's a brace that connects the control arm mount points to the subframe. Holes aren't even there on the WRX. The spec-c's have re-enforced strut towers in the front. I've read that they used more spot welds on the STI chassis too.
On the 08's there's supposed to be more high strength steel. I'd love to get an STI chasses I could stick my drivetrain in. Don't want drive by wire but, would love to have an STI chassis. |
12-26-2007, 10:21 PM | #3 | |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
As far as the '04-'07 STI- I know for sure they have an extra fender brace from the factory to improve chassis stiffness. |
12-26-2007, 10:37 PM | #4 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
04 STi does not have pre-rolled fenders.
02-07 WRX also has those fender braces, but the 07 STi got a beefier one than that POS stamped steel piece on the earlier cars. there's a couple of braces that are different. As far as I know the chassis is the same, everything that is different is just stuff that can be bolted on. |
12-26-2007, 10:42 PM | #5 | |
Member#: 98961
I'm sorry you're confused speedy. Car body's aren't constructed from the same kind of steel throughout. Some parts are mild steel and some are made of "high strength steel" which is stronger for the same thickness but, more expensive.
http://www.autoweek.com/apps/pbcs.dl...3013/1024/FREE Quote:
This brace that ties the suspension together on two sides, that one can be bolted in? I thought the holes were missing on the WRX? The jack point brace, not that pretty red one. Last edited by MasterKwan; 12-26-2007 at 10:51 PM. |
12-26-2007, 11:39 PM | #6 | |
Member#: 93646
For the record that's the much prettier stamped brace. The one on my 04 STi is just a plate welded to a tube with crushed ends. |
12-27-2007, 08:31 AM | #7 |
Member#: 78952
Vehicle:2005 WRX CGM |
We talking about the B2 bomber looking jack point brace? If so I'm pretty sure my 05 WRX has that on it from the factory. I can try and take a look today or something to verify.
12-27-2007, 08:56 AM | #8 |
Member#: 98961
Yes that one. My 03 doesn't and there's no captive bolts to mount one. All I have is the mini-jack point plate.
12-27-2007, 11:57 AM | #9 |
Member#: 126442
Vehicle:My car is slower than your car |
It CAN be bolted in...but you'd have to bolt in the newer/STi crossmember too.
12-27-2007, 12:08 PM | #10 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
my 06 wrx also has that piece.
also, the sti never got that alu fender brace (cowl stay) that is just a opt piece from STI. the 06-07 did get a different cowl stay, but it still sucks. Shane |
12-27-2007, 01:09 PM | #11 |
Member#: 98961
I figured I'd have to swap the subframe. So basically it sounds like the later WRX and STI's got the upgraded subframe. Perhaps the same time they got the upgraded rack mounts? At least the WRX's are easier to come by (assuming I want to mess with it).
01-01-2008, 12:57 PM | #12 |
Member#: 76497
NWIC
Very good info, thanks for all the replies.
01-01-2008, 04:19 PM | #13 |
Member#: 73422
SWIC
Vehicle:04 STi JVP |
01-01-2008, 05:30 PM | #14 |
Member#: 24038
South East
http://www.engineersedge.com/manufac...s_strength.htm
Well, maybe you should have looked it up before you posted! The benefit would be in crash tests, etc. Not necessarily chassis stiffness. |
01-01-2008, 05:36 PM | #15 |
Member#: 24038
South East
double post
01-01-2008, 05:36 PM | #16 | |
Member#: 24038
South East
Depends of course on what steel they are using, but most likely, it is of the same stiffness. |
01-01-2008, 06:46 PM | #17 |
Member#: 98961
I never said anything about stiffness. I said it was stronger. Stiffness of thin sheet metal parts in a unibody structure is controlled more by it's shape and how it's welded rather than absolute strength. High strength steels let you make a car lighter because you can use thinner sheet metal for the same strength or it lets you make the car stronger if you use the same thickness as the mild steel it's replacing.
Kind of pointless arguing about it. Clearly Subaru and other car companies think using more high strength steel in their performance flag-ship brings something to the performance party. I trust real engineers who actually build cars for something like this. I saw an interesting show about the "Fit" the other day (Best Motoring's VTEC Club). They specifically mentioned using different strength sheet metal in critical sections to improve chassis rigidity as well as 3d structures including a large cross sectional area in the sills to make the whole chassis stiffer. |
01-01-2008, 07:40 PM | #18 | |
Member#: 24038
South East
Speedy was talking about using it to increase STIFFNESS (as the OP had asked). You told him he was wrong. He wasn't wrong, again, he directed his post specifically at stiffness. Last edited by REX8; 01-01-2008 at 07:53 PM. |
01-01-2008, 08:27 PM | #19 | ||
Member#: 98961
Speedy's saying using high strength steel makes no sense.
You can read into his post whatever you want. It was a throwaway and he hasn't been back. I'm convinced that subaru uses the HS steel to improve the chassis stiffness but, I'm not an automotive engineer so, I'm not pretending to have all the answers here. The FIT uses HS steel to increase chassis rigidity, that I know. It doesn't seem far fetched to assume that subaru does too. http://www.autoblog.com/2007/10/24/t...wrx-sti-debut/ Quote:
FS: STI chassis brace and Cusco v2 blue chassis brace, perrin rear sway bar | imprzya | Suspension/Brakes/Handling | 8 | 05-08-2007 09:46 PM |
chassis question | 1st time subaru | Interior & Exterior Modification | 1 | 02-16-2005 11:11 AM |
GD springs on GC chassis question. | mykrrrr | Brakes, Steering & Suspension | 1 | 06-17-2003 11:20 PM |
karting chassis question | wes | Motorsports | 2 | 01-19-2003 02:24 AM |
Impreza WRX chassi question. | WRX-games | General Community | 2 | 12-24-2002 08:57 AM |
