01-02-2010, 06:15 AM | #1 |
Member#: 60082
Vehicle:2004 Forester STI Silver |
Long term chassis wear and damage of the GC8 chassis? Weak points?
Well I bring this up because I'm curious if there have been any experiences by any motorsports folks here where there have been fatigue and damage through long term use of the car at an elevated level.
Accelerated wear is the norm of course, but I'm kind of curious if there are any specific weak points to the chassis. I do drive a Forester, different vehicle, but it uses the GC8 chassis as the base and is essentially a wagon form of that chassis. I've been doing auto-x and rally-x for 3 years now, and the Forester has transitioned from bone stock to a pretty competent tool. It is of course in a continuous evolution. The suspension has become decently firm at around 30% above STI rates. This stiffness level very blatantly shows off the natural flex in the chassis. I have been running a 4-point rear strut tower brace for a while now that has quite significantly stiffened up the back end. Fender cowl bracing on the front is a future addition. I'm contemplating some additional bracing where needed, but these two areas seem to be the most significant with most other parts a bit more subtle. My main concern is that I may eventually cause real damage to the chassis and actually get cracking and tearing somewhere. I'm curious if any key areas have shown up for anyone else running setups beyond mine, key things I should be looking for, key bracing I should be using. By key, I mean bracing that actually does something useful. I don't want to toss something on and not have any perceivable difference. Even something as common as the front strut tower brace is questionable as a large number of people have said it has a pretty minimal effect. Under chassis bracing is another big one where people really don't state real perceivable differences. An internal cage would be an obvious suggestion, but this is a daily driver too, so it's not something I ever intend to do. It is neither a track car so I will never partake in any motorsports that require a cage in the first place. I just want to end up with something durable enough to where I don't have to care. I'm not really stressing the chassis greatly. It's not like I'm doing stage rallies with it and jumping the thing, but at the same time, even just driving around on rough roads, doing rally-x, and going over rough terrain in the winter does work the chassis a bit, at least above anything it would experience at stock trim.
01-03-2010, 12:20 AM | #2 |
Member#: 13815
SCIC
Vehicle:02 GCRally prepped 277TQ 281HP 19PSI |
if you don't wanna do a cage, you can always stitch weld the unibody and then put all of the interior back in. That will strengthen your chassis a ton. And caging a dailly driver isn't that bad at all. I drive my rally car daily, it just takes an extra minute to get in and out. You can also build a cage to fit all of your interior back in as well. But definitely look into stitch welding the chassis if you are set at not putting in a cage.
01-03-2010, 09:38 AM | #3 | |
Member#: 78952
Vehicle:2005 WRX CGM |
01-03-2010, 02:54 PM | #4 |
Member#: 143149
Vehicle:2006 gmc envoy stealth |
Does stitch welding require the cleaning of the insulation along every seam?
01-03-2010, 03:23 PM | #5 |
Member#: 22345
NESIC
Vehicle:2003 RSX black |
what about the b-pillar or roof? wouldnt those still be there if a cage werent? wouldnt the cage be less likely to collapse in on you and hit you in the head? and arent the chassis less likely to have a 1/2" of padding on them that cage tubes near you are required to have?
01-03-2010, 11:08 PM | #6 |
Member#: 102091
Vehicle:1994 1.8l Impreza L Open Class Build w/110hp |
Can we get a Sticky in this forum to explain why smacking your head on well designed collapsible plastics is safer than thin solid tubing?
01-03-2010, 11:17 PM | #7 |
Member#: 102091
To the OP... Your car will be fine - for sure!
I own a shell that was used to close performance rally stages. It's a '97 4-door GC. It has jumped and bumped its way through thousands of kilometers of abuse. Some of the stage closing times were compeditive course times... It survived just fine. I used it as a track car for a couple year after I bought it. Sure it flexed a bit when I put it on jack stands, it had faigued, but it is fine - it is safe. They are tough shells, if something goes wrong you'll know. The issue with stage rally cars - as you mentioned - is the jumping and bumping at very high speeds. That and the fact that most drivers don't slow down when they have a "minor" problem. |
01-04-2010, 03:28 AM | #8 |
Member#: 60082
I'm just concerned because chassis flex is a noticeable aspect, and the creaking and twisting has me wondering if there may be future issues if I don't make an effort to address them.
It's good to hear that you've had positive experiences with your sedan despite heavy abuse. |
01-04-2010, 08:58 AM | #9 | |
Member#: 123330
Vehicle:16 ZoomZoom CeX-3 15 ZoomZoom3-Regina |
A good friend of mine made a funny statement when he was discouraging a fellow enthusiast about caging his daily and why the padding wouldn't be any more helpful: Get a steel tube from home depot, wrap it with the padding, and have someone whack you over the head with it really hard. Tell me how it feels if you wake up. |
01-04-2010, 05:43 PM | #10 | |
Member#: 98961
Vehicle:2003 WRX Black |
http://www.summitracing.com/parts/KI...1/?image=large I used padding like this on any bar I might come into contact with. So more dangerous? probably. Is that reason enough not to do it? Depends on how lucky you feel. If driving at the track wasn't dangerous, I probably wouldn't be doing it. Last edited by MasterKwan; 01-04-2010 at 05:50 PM. |
01-04-2010, 06:15 PM | #11 |
Member#: 70011
NESIC
Don't let this turn into another thread about how driving with a cage is super sketchy without a helmet bla bla bla ... lets talk about ways to improce the GC chassis besides a full blown cage.
I was thinking about welding a X brace in the rear of my GC to support the rear strut towers. What are the other major weak points that could be addressed. I know the fenders are one, and I did notice a significant difference after I install my braces in that area. Especially mid turn at high speeds (sweepers), the car felt much more planted under sustained cornering loads and less floaty. |
01-04-2010, 06:49 PM | #12 |
Member#: 98961
The problem with stitch welding is that it's hard to do without totally disassembling the car, stripping off the undercoating and working on a rotisserie. Another issue is that you completely compromise the rust proofing when you stitch weld because anything you weld on, the sheet metal behind the weld (in the sills for instance) the paint is blown off. When I had the cage installed in my civic, all the metal behind the welds started rusting almost instantly. The stuff I could get at wasn't a problem. The sheet metal inside box sections though, there wasn't much I could do.
How about a weld in 4-6pt in the back? Tied into the sills and the strut towers with a harness bar? Re-enforce the rear chassis, still safe on the street but, will protect you if you have a harness and roll the car over? |
01-05-2010, 12:14 AM | #13 |
Member#: 13815
SCIC
I understand tearing down the car to the bone. You could also either Rhino line the inside and bottom of the chassis, or use the roll on Herculiner for protection.
01-05-2010, 09:11 AM | #14 |
Member#: 98961
You understand that there are sections of the car you can't get at right? Like inside the sills? Those box sections under the doors? I ended up filling my sills with 2-part polyurethane foam to stop it from rusting. Stiffened the chassis too.
Most of the time when you stitch weld, they recommend getting the cage in place first because enough welding can actually tweek the alignment of the chassis. I like the idea of stitch welding. In practice, it just hasn't been that easy to do. |
01-07-2010, 01:39 PM | #15 |
Member#: 70011
NESIC
^^ yea I've heard a lot about how stich welding before putting a roll cage into a car can potentially warp the chassis. Is this just a myth or is it a sevear issue, if its not too much of a problem I would definitley consider doing some limited seam welding on my chassis, has anyone do any seam welding without a roll cage?
01-07-2010, 03:40 PM | #16 |
Member#: 13815
SCIC
I don't know how warped stitch welding can cause on the chassis. But when i have seen it done, it was done in sections and each stitch was spaced 3 to 4 inches apart. Sections I talk about would be like the right rear then the left front then some on the floor board then the right front then the left rear quarter and so on and so on. Same therory as welding different parts of the cage to prevent warping. So if done right there should be very little warping if any. And you could always take the car to a frame shop to see if it has moved, and if it has you can bring it back to specs.
01-07-2010, 03:51 PM | #17 |
Member#: 102091
Stitch welding is evil devil's spawn! Warped my shell like a drunken bannana! Just kidding.
Seriously, if it's a DD vehicle and you don't want to repaint everywhere that you've stitched, don't stich weld. Frame horns and wheelwells forward of the firewall are easy enough to do, but IMO, not worth it. Just think of chassis flex as an active part of your suspension. If you stiffen one area too much, the other areas will suffer. Like upgrading just your swaybars - go too stiff and it's of no benefit. |
01-07-2010, 04:33 PM | #18 |
Member#: 30909
NESIC
Vehicle:RA East Open Class Champs 07-08-09 |
verging on Analysis Paralysis here....
for a DD or rallyx vehicle, stitch welding is overkill, the tradeoffs (esp rust issues) are just not worth the price. our old GC rally car rusted like sheet around the stitch welds, and no amount of galvanizing spray or undercoating ever slowed down the evil oxidation much. so beat the crap out of your car as is, enjoy it to the max, and when it's too creaky or you keep breaking windshields, sell it on craigslist to somebody out of state this is why they say NEVER buy a used car from a rally guy |
long term E85 use and results | subynation | Newbies & FAQs | 2 | 01-13-2010 06:10 PM |
Fundie kids wearing "Islam is of the Devil" shirts cause stir | Wagon Of Fury | Off-Topic | 49 | 08-26-2009 09:39 PM |
2008 WRX STI Long-Term Road Test Update: Fun in the snow, but more technical troubles | CARandDRIVER | NASIOC Official News, Articles and Polls | 65 | 03-04-2009 05:53 PM |
uneven tire wear and damage to tranny/diff | taxi-1 | Tire & Wheel | 4 | 10-18-2006 11:39 PM |
jacking points for the front and back of the STi | maengelito | STi Forum Archive | 2 | 08-29-2003 02:22 PM |
