Old 08-26-2012, 01:43 PM   #1
xhector2013x
Member#: 314589
2001 L W/ej251
Impreza GC8 n/a 2.5 head help
So im gunna be buying an 01 rs today or tomorrow, the guy bought it as a project and turns out the SOHC he swaped has some noise in the bottom end, but hes including a 2.5 DOHC for me to swap he is including a DOHC ecu with the car but no harness. so the question is can i just swap the SOHC heads onto the DOHC block and run the same SOHC ecu and wiring harness?
xhector2013x is offline   Reply With Quote
Old 08-26-2012, 02:02 PM   #2
EmanLives
Member#: 291036
Dark Bug
it's not that simple, they're completely different engines.
sorry that just the short answer.
EmanLives is offline   Reply With Quote
Old 08-26-2012, 03:50 PM   #3
GrundleJuice
Member#: 165749
I think this has been done before. have you searched the forum?
Old 08-27-2012, 08:23 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
It is that simple. Your compression ratio will be slightly lower but not significantly. I know a shop that buys dohc turbo motors from Europe and swaps the shortblocks into all types of NA 25's and they run great.
The next question is what kind of condition is the dohc ej25 in?
geronimo81 is offline   Reply With Quote
Old 08-28-2012, 09:09 PM   #5
DerekNichols
Member#: 322942
yes you can swap 2.5 sohc heads on a 2.5dohc block. make sure you use the Dual headgasket, as there thicker. The dohc pistons come past the deck a bit and need the extra clearence inthe gasket. Thats the main thing! your intake from your sohc 2.5 will fit on the dual block with sohc heads.
Only other thing is there is a lil bracket above the water pump that differs from dohc to
sohc. Other than that, Its a very simple swap.
Pull the heads off that Dohc and when you have just the block, check for knocks the best you can. Listen+ Feel, every piston at/and before tdc. and also at/and before Bdc
DerekNichols is offline   Reply With Quote
Old 08-30-2012, 03:18 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Contrary to popular belief, there were in fact phase II DOHC Ej25s made. When you get the heads off, post a picture of the tops of the pistons. Then we'll tell you which head gaskets to use on reassembly.
Old 08-31-2012, 05:15 PM   #7
xhector2013x
Member#: 314589
2001 L W/ej251
its in pretty good condition from what i can see
Old 08-31-2012, 05:19 PM   #8
xhector2013x
Member#: 314589
2001 L W/ej251
ill post a picture of both motors
Old 08-31-2012, 05:43 PM   #9
xhector2013x
Member#: 314589
2001 L W/ej251
im clueless as to how to upload pics on here so here i made a photobucket and i have the images there. i think you can find out which is which
http://s1251.photobucket.com/albums/hh553/xhector2013x/
Old 08-31-2012, 05:46 PM   #10
xhector2013x
Member#: 314589
2001 L W/ej251
ill pull the heads tomorow and post the picture, i worked on that car enough for today
Old 09-01-2012, 08:35 AM   #11
RaceTSI
Member#: 330860
I have an 02 2.5 forester engine in my 97. the 2.2 in it crank walked leaving the bottom end useless. I swapped over my heads to the 2.5 motor and used the 2.5 motor head gaskets being the bore for the 2.2 is slightly smaller.
I used the stock SOHC harness, manifold, exhaust (same heads it came with), etc. The only thing I changed was the bottom end, and the head gaskets. Everything else can be swapped over. I do run premium now as it is higher compression. supposedly like 10.9:1? Its faster than a friends RS and my car is slightly heavier.
main thing is make sure the head gaskets are the same bore.
RaceTSI is offline   Reply With Quote
Old 09-01-2012, 12:19 PM   #12
xhector2013x
Member#: 314589
2001 L W/ej251
yeah i was imagining that thats what i was going to have to do, so would this be the same procedure for a 2.5 head?
Old 09-01-2012, 09:36 PM   #13
xhector2013x
Member#: 314589
2001 L W/ej251
Old 09-03-2012, 12:36 PM   #14
xhector2013x
Member#: 314589
2001 L W/ej251
yup everything bolted up and iv got compression , iv got a picture in my photobucket
