12-15-2006, 04:59 PM | #1 |
Member#: 102673
NESIC
Vehicle:2000 Legacy GT LTD Black |
CEL: P0133 O2 Sensor Slow Response (Bank 1 Sensor 1)
P0133 o2 Sensor Slow Response (Bank 1 Sensor 1)
2000 Subaru Legacy GT Limited 83333 Miles Came on while I was doing 80 on the highway. Added gas this morning (about 50 miles prior), the gauge was a little above half when the light came on. Code was pulled at Advance Auto Parts. Went home disconnected battery, reconnected, light still on. Drove for 5 minutes, shut car off for 5 minutes, drove back home, light still on. Pricing for O2 Sensors at the Auto Parts Store was $150-200!!! Help?
12-15-2006, 05:22 PM | #2 |
Member#: 116636
Vehicle:2003 impreza black |
i think we charge about 115 at out shop for them
12-15-2006, 05:24 PM | #3 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
12-15-2006, 05:29 PM | #4 |
Member#: 102673
NESIC
Im asking if there is a way for me to get around replacing the sensor.
12-15-2006, 08:18 PM | #5 |
Member#: 134593
Vehicle:2001 Outback |
12-15-2006, 08:48 PM | #6 | |
Member#: 102673
NESIC
EDIT: Is this it right here? http://catalog.eautopartscatalog.com...eccatalog.com/ Part C5010-113986 by Bosch? |
12-16-2006, 12:58 PM | #7 |
Member#: 134812
Vehicle:2006 2.5i Grey |
12-16-2006, 02:06 PM | #8 |
Member#: 89233
South East
Vehicle:99 RS Aspen White 2014 Outback SWP |
Try blowing out the sensor with low pressure and cleaning it with some carb cleaner. This helped me for almost a year before I had to replace mine.
12-16-2006, 03:22 PM | #9 |
Member#: 102673
NESIC
Which side is Bank 1? Is it the side with Cylinders 1 and 3?
12-16-2006, 03:40 PM | #10 |
Member#: 102673
NESIC
Hmm I only found 1 o2 Sensor? Right behind the cat (I think it could even be in the Cat)
EDIT: I went to the store to buy Carb Spray and a Socket, and the light shut itself off..WTF Random Last edited by BLK REX; 12-16-2006 at 04:16 PM. |
12-16-2006, 04:22 PM | #11 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
There's only one 'Bank', but there are 2 sensors. Your code O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) is the FRONT sensor, which is the one the ECU uses for closed loop AFR control.
It sounds like you may have found the rear O2 sensor (way back in the exhaust - and only used for emissions monitoring). The one you want is ahead of any cats, right where the LH and RH exhaust manifolds merge. |
12-16-2006, 11:57 PM | #12 |
Member#: 112757
I'm in the same boat... my CEL came on, then went off randomly. Now it's back on and staying on. Same code as yours plus p0420. I can't get my front O2 sensor to budge though... tried everything I can think of short of taking the cat off of the car.
12-17-2006, 01:35 PM | #13 |
Member#: 116636
try an o2 socket?
12-17-2006, 03:35 PM | #14 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
That is your front 02 sensor, BEFORE The cat
the one after the cat is bank1 sensor 2 you need to replace the front oxygen sensor. You cant just put a similuator in there that sensor is what the ecu uses to calculate air/fuel ratio when they get old they ''slow'' down. that legacy only has one ''bank'' because they only use one upstream sensor. |
05-30-2007, 11:12 AM | #15 |
Member#: 139955
NESIC
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
12000 miles later it came back on..right as Im getting ready to trade the car in too..
05-30-2007, 11:30 AM | #16 |
Member#: 2272
BAIC
Did you replace it with an OEM sensor or something else?
05-30-2007, 12:05 PM | #17 |
Member#: 139955
NESIC
I never replaced it in the first place..it just shut off..
05-30-2007, 03:16 PM | #18 |
Member#: 139955
NESIC
It decided to just shut itself off..
...is there any connection between this CEL and the gas cap? My (female) friend forgot to put the cap on after refueling and drove it for a minute or so until i realized it.. |
05-30-2007, 03:56 PM | #19 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
No, that would be an evaporative emissions CEL.
P0133 Front O2 Sensor Slow Response | familytruckster | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 11-09-2005 02:27 AM |
Diagnose...CEL: Rear O2 sensor circuit slow response | MF-DIF | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 10-05-2005 01:17 PM |
Stock 04 WRX, CEL - O2 sensor, slow response... | Spectre186 | Service & Maintenance | 4 | 06-22-2005 06:06 AM |
CEL: P0133 front O2 sensor | Aaron Hoag | Service & Maintenance | 3 | 08-15-2003 12:00 AM |
P0139 Rear O2 sensor slow response? | Baluchitherium4 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 01-18-2003 04:34 PM |
