08-12-2010, 01:10 PM | #951 | |
Member#: 209630
Vehicle:2002 WRX / V7 STI 3.9USM6 / PSM |
08-12-2010, 08:17 PM | #952 |
Member#: 143993
E. Canada
Vehicle:2011 wrx white |
this weekend if it doesnt rain im going to go to the strip most v7's ive seen do die off above 7200rpm, i do have stock manifold and stock v7 heads (good but nothing beats a nice porting job and some 272's)
08-13-2010, 12:35 AM | #953 | |
Member#: 4568
Vehicle:10.7 @ 136, '02 WRX 12.8 @ 112, '09 spec.B |
def |
08-13-2010, 11:33 AM | #954 |
Member#: 120237
Vehicle:2004 WRX WRB |
Peoples thoughts of putting a full-race gt30r twin scroll kit on a stock v7 ej207, tune on e85? What injectors and fuel pump should I run? Any preferences on how to tune it? Or any other parts you guys would like to see me put on this set up. Thanks guys
08-13-2010, 12:03 PM | #955 |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
You will need the utec so you can get speed density for that setup. Some of us where running GT30Rs 6 years ago on those motors. So search around.
C |
08-13-2010, 12:13 PM | #956 |
Member#: 120237
Thanks Clark, I searched quite a bit so far. I sent you an email also. Do you think there's a better option for spool and horsepower wise then this set up? I'm looking for like 400whp on e85. Thanks for the help, I been reading as much as possible.
08-13-2010, 12:25 PM | #957 |
Member#: 178047
SWIC
There are lots of options. To many to even discuss. Just get what you like
C |
08-20-2010, 07:28 PM | #958 |
Member#: 188598
alright so it looks like i have blown a piston ringland on my v7 ej207. my question is, should i just get new pistons/if so what kind/size? or can i just replace the ringland with a new?
custom rotated holset hx40 44mm ewg 850cc injectors turboxs frontmount walbro 255 and many other mods |
08-21-2010, 03:19 AM | #959 |
Member#: 178426
Vehicle:2010 S4 Gray |
Aight guys. My timing belt skipped and blew my brand new engine. What timing belts you guys running? Any issues with skippage? I need to figure out the issue so I can avoid the problem.
08-21-2010, 04:58 AM | #960 |
Member#: 10854
SCIC
Vehicle:'02 WRX; '08 OBXT; '08 G37 (S/C'd); '09 XF |
^ i've had pretty good luck with Gates timing belts.
08-21-2010, 10:22 AM | #961 | |
Member#: 54060
Vehicle:Now: 16 FXT/04v8 207 Then:JRTuned fastest td04 |
My v8 was banged up a bit in transit and the timing belt was nicked. I replaced with a stock belt and haven't had any problems in the 15,000 miles since. |
08-21-2010, 11:03 AM | #962 | |
Member#: 178426
It was a Gates. |
08-21-2010, 01:19 PM | #963 |
Member#: 178047
SWIC
Use a factory STI timing belt. Also make sure to adjust the timing belt guides and make sure they are in place. Its not a bad idea to buy the cosworth belt guide. Its $50 and makes sure the belt cant jump.
C |
08-21-2010, 01:32 PM | #964 |
Member#: 188598
[quote=OppositeLock;31662603]The ringland is part of the piston. Its the groove machined into the cast or forged metal to hold the ring in place.
so your saying i would have to get a new piston? haha is there a place i can just buy one piston or would i have to get the whole set? |
08-21-2010, 01:35 PM | #965 |
Member#: 178047
SWIC
You need a new short block or 4 new pistons, rings, and then have the short block rebuilt and honed.
C |
08-21-2010, 01:57 PM | #966 | |
Member#: 188598
andrew |
08-21-2010, 02:20 PM | #967 |
Member#: 178047
SWIC
2.5 crank, Piston and rod set to match crank.
C |
08-21-2010, 03:26 PM | #968 |
Member#: 178426
08-23-2010, 12:21 AM | #969 |
Member#: 148756
E. Canada
A bit side tracked, but how similar are the parts (gaskets, belts etc) on the JDM compared to the USDM engines? I'm debating between a v7 and a USDM 2.5 for a track car project.. I just don't know if I want to get into a JDM engine/ECU and worry about parts down the road.
Lastly, what do you all you V7 owners do for your exhaust, would it be the same exhaust as the regular USDM wrx? Ryan Last edited by mcandrewsr; 08-23-2010 at 12:31 AM. |
08-23-2010, 01:53 AM | #970 | |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
08-27-2010, 01:53 PM | #971 | ||
Member#: 122654
NESIC
Vehicle:2002 v8 STI w/ GT30R 2013 GTR & M-Sport 335xi |
Why do you think that happens - power drop-off above 7200 rpm? What is the bottle neck? P/s: Mine does it too. Cheers. Gerald. |
08-27-2010, 02:27 PM | #972 | |
Member#: 4568
def |
08-27-2010, 02:29 PM | #973 | |
Member#: 122654
NESIC
In which order would you prioritize that for a stock v8 EJ207 block? Also, is the stock exhaust manifold restrictive? Last edited by gling; 08-27-2010 at 03:59 PM. |
08-27-2010, 03:50 PM | #974 | |
Member#: 249983
Vehicle:99 |
My V7 Spec C engine (out of limited with same engine code) is still out and can be upgraded. V8 Spec C cams? What about the intake manifold? Lay it on me with some suggestions! Going to use the stock turbo VF30 for now. Car will be a track/autox and not a dyno queen so looking for relevant upgrades. Thanks! I want to get the swap running smoothly before I do a significant power upgrade, but I have the engine out. Stuck between which I want to do. Decisions, Decisions... |
08-27-2010, 04:00 PM | #975 | |
Member#: 122654
NESIC
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
