06-28-2010, 06:16 PM | #1 |
Member#: 233060
No spark
I have a 95 subaru imprezza l 1.8L. One day may car was running and then it stopped and wouldn't start. I replaced the coil pack and still none of the plugs are getting spark. I would greatly appreciate some help with this, as it is my daily driver.
07-02-2010, 12:12 PM | #2 |
Member#: 236927
NESIC
Vehicle:2015 BRZ 86 GL Hatch 1984 BRAT |
You could have bought a bad coil pack. Check you igniter, make sure that it is getting power. Make sure your wires are in good condition also. If everything checks out OK, then you might have a bad ground somewhere. Bad grounds are such a joy to find.
07-02-2010, 12:26 PM | #3 |
Member#: 130489
MWSOC
Vehicle:02 WRX Wagon (WRB) 98 OBS-T, 91 Legacy SS |
Ignitor, cam position sensor, crank position sensor. The three most common culprits to no spark issues.
Check voltages and grounds from there. |
07-02-2010, 12:55 PM | #4 |
Member#: 155358
Vehicle:2008 Forester Steel Silver |
^^ this
07-02-2010, 02:11 PM | #5 |
Member#: 107430
NWIC
Vehicle:1993 Impreza Seafoam |
Did you check the timing belt?
Also, if you can, pull the trouble codes. To do this you connect the two green connectors under the driver side dash, then the CEL should start flashing. Long flashes are a 10 and short flashes are a 1. So long, short, short would be 12 and long, long, short would be 21. |
Similar Threads | ||||
no spark & no fuel = no start | Annoying Eric | Normally Aspirated Powertrain | 10 | 11-29-2017 07:39 PM |
96 brighton 1.8l impreza 1-2 spark 3-4 no spark | WRXR1A10 | Normally Aspirated Powertrain | 6 | 12-28-2007 02:52 PM |
Ignition Issues - No spark, no timing? | Logannz | Electrical & Lighting | 0 | 03-13-2007 05:37 PM |
EJ22 Swap - No Spark... no ground for fuel pump relay?? | Subarutex | Subaru Conversions | 5 | 01-22-2007 12:14 PM |
There's just no spark... no electricity... | Hypernoodle | Off-Topic | 32 | 07-06-2006 02:14 PM |
