01-12-2015, 08:31 AM | #201 | |
Member#: 408401
Vehicle:2014 WRX STi Limited |
I'm pretty sure RadioShack sells one but I can't find it on their website.
01-12-2015, 03:49 PM | #202 | |
Member#: 344521
Vehicle:2013 STi DGM |
01-12-2015, 05:22 PM | #203 |
Member#: 408401
For an item like this it might be better to shell out a few more bucks and get something that will work correctly. I'd take a trip to your local RadioShack and see what they have. It's been a minute since I worked there, but I remember them having numerous different cellphone/tablet chargers and lots of adapters.
01-13-2015, 07:28 AM | #204 | |
Member#: 344521
01-17-2015, 07:43 PM | #205 | |
Member#: 408401
They might've changed it since 2013 but when I worked there, the policy was the above PLUS 90 days for any RadioShack brand items that are/become defective. I bought an Auvio (R/S brand) bluetooth speaker that retails for $150 but the battery died 62 days in. Returned it with no problem because I had the original receipt and it was a RadioShack brand. |
04-21-2015, 06:45 PM | #206 |
Member#: 342819
Confused on how you got the sound to play to the speakera with the aftermarket harness with amplifiers in the car
04-21-2015, 07:18 PM | #207 |
Member#: 344521
04-22-2015, 03:00 AM | #208 |
Member#: 342819
Yes please
04-22-2015, 08:06 AM | #209 |
Member#: 344521
This is how I did it. Basically the 3.5mm of the nexus, plugs into a headphone amp (for easy volume control). Then that gets converted to an RCA cable, which is then split and plugged into the amp. Let me know if this is what your looking for.
04-22-2015, 01:53 PM | #210 | |
Member#: 342819
I have a two channel amp right now so this wouldnt work with it.. I need an amp with 2 iinputs for rca Only thi g i can find is this. With only 2 rca not 4 http://www.amazon.com/Mediabridge-3-5mm-Male-2-Male-Adapter/dp/B004YEBK66 |
04-22-2015, 02:40 PM | #211 | |
Member#: 344521
04-22-2015, 11:02 PM | #212 |
Member#: 416861
What offline Navigation did you use?
04-28-2015, 02:07 AM | #213 |
Member#: 419855
Seems like alot of work, but looks really good.
05-03-2015, 08:25 PM | #214 |
Member#: 420274
I agree I really like this . Keep up the good work !
10-25-2015, 03:36 PM | #215 | |
Member#: 342819
10-25-2015, 05:39 PM | #216 |
Member#: 431964
I would reccomend against using the above. Keep it simple and just buy a new bluetooth capable amplifier. You will have ZERO wires to run for audio, only for power.
Running via Bluetooth will achieve much better sound than a 3.5mm cable would provide plus you will lose the complexity and unwanted noise floor that added components bring. There are several amps that run on bluetooth signal these days. |
10-26-2015, 09:54 AM | #217 | |
Member#: 344521
Edit: And even with running a long 3.5mm jack the audio quality is loads better than OEM radio. |
06-19-2016, 12:54 PM | #218 |
Member#: 206751
Vehicle:2017 WRX Premium LBP 2007 WRX OBP (sold) |
Nice write up! Realizing this is an old thread bump, I am attempting to do something similar in my truck. My plan is to utilize an after market single din head unit that supports AOA 2.0 and mount it a couple inches deep inside the double din mount, leaving enough room to slide in a tablet that will sit flush with the trim and still have the appearance of the tablet being the head unit. This setup up would provide better sound quality using usb to output audio to the head unit instead of a bluetooth setup. I would also still be able to utilize steering wheel controls and have the scalability of using the head unit should I choose to.
