Brakes & Suspension Forum sponsored by The Tire Rack |
07-03-2009, 03:09 PM | #1 |
Member#: 137631
Vehicle:2006 WRX Red |
need to confirm what are the parts lacking for my upgrade (urgent)
Hi,
I drive a 06 wrx edm and in the midst of buying a version 8 04 usdm sti front aluminum control arms. I would like to check what needs replacement / procurement in view of the new arms? Is a direct bolt on and reuses the same parts right? Ive a RCA, that should be find i hope?
07-03-2009, 04:27 PM | #2 | |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
sorry - don't know what you're asking Last edited by UkNuck; 07-03-2009 at 04:59 PM. |
07-03-2009, 10:29 PM | #3 |
Member#: 7958
Vehicle:09 GH B+ |
if the arms come w/ ball joints you'll be fine, if not you'll need the sleeves/"cones" as mentioned above and you can re-use your existing ones (might be a good time to get new ones anyways)
do you mean ALK? the rear bushing? if so yes you can reuse the rear bushing (or ALK) |
07-04-2009, 12:48 AM | #4 |
Member#: 137631
Nah, i meant roll center adjust (RCA).
It came like these: So, do i still need the "cones" for my application? What abt the "black bolt"? Which part is it exactly? Can i reuse that from my steel arms? Anyhow, this is what im getting, let me know if theres any short fall or things that cant be reused from my existing car. Thanks! |
07-04-2009, 11:22 PM | #5 |
Member#: 7958
Vehicle:09 GH B+ |
looks like you need the "cones", part #'s are floating around- you can them from the dealer
the ball joints will not work w/o these, and the steel arms don't have them the black "bolt" is where the rear bushing is attached (attached to the aluminum arm via two bolts- your arms have them |
07-08-2009, 01:21 PM | #6 |
Member#: 137631
may i check wat is the part number (assuming whiteline) for the forward lower control arm bushing for 04-06 usdm sti?
07-11-2009, 07:22 AM | #7 |
Member#: 137631
need info. appreciate it.
07-11-2009, 09:18 AM | #8 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Part number is W52837. We normally stock them but I think we are out currently.
Tony |
07-11-2009, 01:01 PM | #9 |
Member#: 137631
Thanks Sir!
need to confirm what are the parts lacking for my upgrade (urgent0 | jacky599r | Brakes, Steering & Suspension | 1 | 07-03-2009 03:44 PM |
need help choosing the right turbo for my upgrade! | calistisun | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 01-10-2006 11:40 AM |
What is the part number for the piece next to the cup holder? | ezparts | Interior & Exterior Modification | 5 | 02-24-2005 12:27 AM |
what are the part numbers for | bhorton | Brakes, Steering & Suspension | 1 | 04-22-2003 04:38 PM |
What are the part #'s for these? | [freeman] | General Forum Archive | 0 | 07-09-2000 03:47 PM |
