10-14-2008, 01:14 AM | #1 |
Member#: 176016
Vehicle:2002 2.5rs impreza dark blue |
How do you adjust the light on the DIY projector bugeye?
projectors are in, do you still use the stock adjuster to adjust the light?
10-14-2008, 01:17 AM | #2 |
Member#: 149730
Tri-State
Vehicle:2002 Impreza WRX PSM |
we did it on a friends car with the stock adjuster and it worked fine!!!
10-14-2008, 02:29 AM | #3 |
Member#: 29355
NWIC
uhh...
i can't use the stock adjuster on my DIY bugeye projector because i replaced the oem rear housings with ebay covered with oem fronts and made my own adjustment system. that said, my lights kick ass and are aimed pretty well(not perfect, but safely usable and legal). however if you mounted your projector to the stock optic reflector structure, you can adjust x(height) and y(left/right) axis with the stock adjustment screws. if you mounted yours differently, or need to adjust z axis or are misaligned outside the physical limits of the stock adjustment, you'll need to remount or readust with a different mechanism or method. you did not include NEARLY enough information to get a definitive answer. |
Similar Threads | ||||
How do you post your logs on the forum? | plus plus plus | UTEC | 9 | 08-27-2009 11:26 AM |
Besides forums and youtub and like sites, how do you spend your time on the internet? | lag | Off-Topic | 19 | 07-30-2009 08:21 PM |
How do you get fog lights on with parking lights on only... | Phreaker | Impreza Forum | 10 | 01-30-2008 03:03 PM |
('93-'01) how do you adj. head lights on a 2.5RS? | wop | Impreza Forum | 4 | 07-12-2001 02:36 PM |
How do you raise boost levels on the WRX? | mastervic27 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 04-02-2001 06:04 AM |
