01-15-2002, 11:28 AM | #1 |
Member#: 11301
Vehicle:2002 impreza WRX midnight black pearl |
help with dual stage boost control
for starters I have done a search and came up with nothing, so I've decide to post and see if anyone of my fellow I-clubbers can help.
Heres the problem. I can set the boost level on stage one to whatever PSI I want it to be at but I can't adjust the 2nd stage at all. It doesn't matter how many times I back the screw out the pressure is still the same as the first stage. Has anyone else had this problem? Any thoughts on this? thanks in advance, Mike
01-15-2002, 11:31 AM | #2 |
Member#: 11301
BTW it's a turbo XS dual stage boost control.
01-15-2002, 11:49 AM | #3 |
Member#: 11756
Vehicle:2001 WRX Sedan Black |
I don't have one of these, but I think there are two possible problems;
[list=1][*]You should be screwing the valve in for stage two, not out.[*]Your electrical circuit is not switching to the second controller properly.[/list=1] Hope that helps. Duncan |
01-15-2002, 11:53 AM | #4 |
Member#: 11301
Ducan, thanks for the input. In the directions it says to have both stages screwed all the way in and to back the first one out 3 turns and the second stage 2 turns and to increase the pressure you keep backing out the screws. as for not having the circut switching, it's possible but I can hear it click when I flick the switch. (look at that I can rythme )
01-15-2002, 02:30 PM | #5 |
Member#: 11301
bump, anyone else have any ideas?
TurboSmart Dual Stage Boost Controller | silvercharged | Car Part Reviews | 1 | 04-18-2010 10:19 PM |
Grainger Dual Stage Boost Controller? | sick1.8t | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 09-10-2002 09:42 PM |
TurboXS dual stage boost controller | WRXWES | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 03-06-2002 03:55 PM |
FS: Dual stage boost control | Donnie | Mid West Subaru Owners Club Forum -- MWSOC | 5 | 12-19-2001 07:33 PM |
Turbo XS Dual Stage Boost Controller | 128d | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-20-2001 10:01 PM |
