10-17-2001, 04:41 PM | #1 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
Does the Subaru boost gauge interfere with steeing wheel tilt travel?
I've been told that it does. Is this true, those of you who have them?
Oh, don't bother suggesting aftermarket gauges...I'm a factory guy, thanks. Kevin
10-17-2001, 04:50 PM | #2 |
Member#: 10433
Vehicle:1942 Kettenkrad WR Blue Pearl |
Mine was factory installed and when I got the car the wiring was routed over the top of the steering column. This DID interfere with the tilt. I couldn't get it to tilt all the way up so the top of my speedo was not visible.
Solution: This is REALLY technical so bear with me... I pushed the little wires over to the side and the wheel tilted all the way up. FIXED. Sorry for the long explination... |
10-17-2001, 06:10 PM | #3 |
Member#: 6320
Vehicle:2002 WRX Wagon Silver |
Nope
I bought the gauge and installed it myself. I put the wires and hose along the side of the steering column (like ryball) with just enough slack that I can move the column all the way up with no problems.
-Lyle |
10-17-2001, 06:48 PM | #4 |
Member#: 4825
Vehicle:2013 BRZ CBS |
I also installed the factory boost gauge on my own and there are no problems, the steering wheel tilts all the way up.
10-21-2001, 02:26 AM | #5 |
Member#: 6954
RMIC
Vehicle:05 FXT Pre: 02WRX, 98RS, 99RS |
Is the factory boost gauge very hard to install... for a newbie? I've looked through the instructions at subaruparts.com, but everything can look easy until you get into it.
10-21-2001, 01:44 PM | #6 |
Member#: 7146
It's pretty easy to do. I installed it myself without any difficulty. The only part I felt uneasy about was pulling the panel covering the stereo off. Make sure you protect the dash with electical tape before prying the face off.
10-21-2001, 06:10 PM | #7 |
Member#: 4825
My dog has better mechanical skills than I do, and I was able to do it. I have to admit, it was a little scary, getting the T-valve on the hose was a beyotch. And the look of my dash completely off was nerve-wrecking, but in all, I had a blast! Who knew that DIY modifications could be so much fun!?! But deep inside, I still worry about my engine blowing up because I tinkered with it.
10-21-2001, 07:02 PM | #8 |
Member#: 5553
E. Canada
Vehicle:2002 impreza wagon silver |
Our's doesn't interfere with the steering cloumn, it nice cause you can still see all your gauges. It's easy to install, just follow the instructions and you'll be fine.
10-21-2001, 09:05 PM | #9 |
Member#: 9531
Vehicle:2002 WRX Sport Wagon Aspen White |
doesn't get in the way...that would be a liability for subaru incase of causing an accident.
you can get install directions from www.subaruparts.com and they will soon be on my site. jim www.angelfire.com/ego/wrx182 |
What units does the stock turbo gauge use to measure boost? | Sublime5260 | Electrical & Lighting | 1 | 02-11-2003 04:34 PM |
does factory boost gauge come with warranty? Dealer says NO | starks_25 | Southern California Impreza Club Forum -- SCIC | 1 | 12-20-2002 03:00 PM |
Cheapest Place to order the OEM Boost Gauge and the OEM Gauge panel | Schleppy | Interior & Exterior Modification | 4 | 03-04-2002 10:36 AM |
('93-'01) Does the subaru stock gauge pod house 52mm or 60mm gauges? | WRXMod | Impreza Forum | 6 | 08-02-2001 09:53 PM |
buzzing from Subaru Boost gauge on boost? | Cosworth | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 06-29-2001 11:47 AM |
