07-11-2001, 10:46 PM | #1 |
Member#: 6467
Vehicle:1999 Impreza 2.5 RS silver |
fog light question/problem
i just swaped out the foglights on my MY99 with the fogs on my freinds totaled MY01 (mine where all pitted from road salt and whatnot his are nice and clean : ) the only problem is that no matter how i aim them the beams dont match like they did before, if you look a foot or so in front of the car on the ground youll see a cresent made be the light. on my car they will not match up evenly no matter what i do. aiming the light with the little screw to change the angle of the reflector does nothing, the beam doesnt even move. IF ANYONE KNOWS WHAT CAUSING THIS PLEASE PLEASE PLEASE HELP!!!! thanks in advance.
07-12-2001, 12:36 AM | #2 |
Member#: 3231
RMIC
Vehicle:88 626 Turbo white |
well dogg.... are the bulbs good? are they in decent condition?
Brat |
07-12-2001, 01:01 AM | #3 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
The other thing you can do is slightly unbolt the fogs and see which way you have to tip them to make them straight. When you find that out, put some washers between the plastic tab and the bumper cover as you put the bolts back in, so that the washers will foce the fogs to maintain the pattern you desire.
Brian AIM: captaindamorgan ICQ: 84483950 http://www.northursalia.com You and the Captain make it happen! |
07-12-2001, 01:05 AM | #4 |
Member#: 3231
RMIC
damn brian hahah thats my name thats a good idea man! and ya have good taste in alcohol. good suggestion.
Brat |
07-12-2001, 02:16 AM | #5 |
Member#: 6467
yes the bulbs are good and i think ill do the washer thing but it just bothers me that they arnt straight, theres no reason for them not to be, my car was never hit and the old ones where fine. thanks for the help guys
07-12-2001, 04:23 AM | #6 |
Member#: 4706
Vehicle:2001 2.5rs silverthorn metalliac |
It may be possible that due to the impact from him totaling his car the metal reflectors are not lined up properly and cuasing this.. If this is the case probably nothing you can do :/
07-12-2001, 04:31 AM | #7 |
Member#: 6467
his car slamed into a tree from the side, the front bumper and everything on it was in no way affected by the crash
07-12-2001, 04:37 AM | #8 |
Member#: 4706
a few things fall into play there man
objects in motion staying in motion. and vibration due to an impact and the vibration it can cause those very fragile elemnts to move.. |
07-12-2001, 04:40 AM | #9 |
Member#: 6467
i c this kinda makes sense...the one giving me trouble is on the same side as the hit. you think i could take the fog apart and rebuild it?
07-13-2001, 01:55 AM | #10 |
Member#: 4706
its is a very hard process to take theme apart and then even if you do ge5t it apart without chiping and cracking the glass... you cannot touch the reflector on the inside.. It is made of a special material that cannot be cleaned or else it will scratch.. so you can not touch it because it will leave oil spots
fog lights installation problem | facs | Normally Aspirated Powertrain | 5 | 01-03-2002 02:53 AM |
fog lights installation problem | facs | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 01-02-2002 05:00 AM |
fog lights installation problem | facs | Vancouver Impreza Club Forum -- VIC | 2 | 01-01-2002 11:51 PM |
fog light installation problem | facs | Warranty Issues & SOA Problems | 0 | 01-01-2002 09:51 PM |
('93-'01) fog light question/problem | NateDogg | Impreza Forum | 0 | 07-10-2001 07:37 AM |
