10-04-2012, 03:29 PM | #1 |
Member#: 334145
Interior clock ('02)
I checked the fuses and replaced with brand new ones it's still not working. Wasn't sure if it's the wiring, but had that checked out and it looks good. No clue what the problem is. What else should I check for?
10-04-2012, 06:56 PM | #2 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
There is a small resistor/circuit on the back of the clock that probably has a break in it. If you are adept at soldering, you could attempt to fix it.
10-04-2012, 07:25 PM | #3 |
Member#: 178811
MAIC
Vehicle:2011 White Corolla Over 400hp |
Even if you're hamfisted it's rather easy if you have the right tools. First time I ever soldered something was to repair the clock in my '02. There's an older thread about exactly which resistor is prone to breaking the solder connection; search for it OP.
10-04-2012, 07:50 PM | #4 |
Trust no one
Moderator Member#: 11170
Tri-State
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Please use the search, there are a bunch of threads about the clock and how to repair it.
