01-24-2008, 06:10 PM | #1 |
Member#: 157692
Vehicle:2004 WRX "Big Red" |
Need a CR estimate!!
Can someone help me estimate the CR on a 2.2 with Phase I DOHC hydraulic lifter heads+the old metal 96 headgaskets?????? stock pistons.
and then what would the same build with EJ22T pistons offer???
01-24-2008, 06:22 PM | #2 |
Member#: 157692
Why does it seem like no one can help me with this question?????!?!
i know atleast one of you knows!!!!!! |
01-24-2008, 06:54 PM | #3 |
Citizen Mick
Member#: 27646
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
12 minutes is not enough time for a response.
You also need to supply far more data to do a CR calculation. Search for the other threads on similar topic and you will see what other data is needed |
01-24-2008, 07:18 PM | #4 |
Member#: 145145
Vehicle:2006 wrx STi |
About 3......
You need to give us 1. the chamber volume of the heads, 2. the volume of the piston/above the rings, and 3. the compressed thickness of the head gasket. Otherwise there is not too much we can do to help you. |
01-24-2008, 09:51 PM | #5 |
Member#: 157692
well like i said earlier we're assuming its all stock, and I'm just looking for some kind of rough estimate.
01-25-2008, 01:35 AM | #6 |
Member#: 29201
Vehicle:BMW M3 Honda S2000x2 |
Some things that might help:
http://www.wac.addr.com/auto/obs/turbo/ejcalcs.html http://www.csgnetwork.com/compcalc.html |
01-25-2008, 02:14 AM | #7 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
9.00:1 Cr for the stock ej22 pistons, 7.50:1 w/ EJ22T pistons.... but thats with a 1.5mm HG (.060'') which is the stock EJ25D HG, I think its also the same thickness as the ej22t, it is, just checked.
~Josh~ |
01-25-2008, 03:01 AM | #8 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
I think it will be around 8.9:1 based on stock EJ22E pistons, 1.37mm head gasket thickness and 46cc volume of the clover-style combustion chambers of the heads.
Similar Threads | ||||
Body Repair Guys: Need a ROUGH Estimate | REX8 | Service & Maintenance | 1 | 10-16-2009 05:50 PM |
I need a rough estimate | greenman | Off-Topic | 23 | 07-07-2009 09:41 AM |
I Need A Repair Estimate... | 02CWRX | North West Impreza Club Forum -- NWIC | 11 | 05-04-2009 04:23 PM |
What CR pistons needed to drop Hybrid CR | Twiztidunreal | Built Motor Discussion | 8 | 03-16-2008 02:48 PM |
Need external CR-D (possibly DVD-R) kit for laptop | Cosworth | Off-Topic | 14 | 04-01-2004 05:42 PM |
