10-23-2008, 08:42 AM | #1 |
Member#: 67535
South East
Vehicle:2014 WRX Hatch Dark Gray Metallic |
Please review my logs
Hey, I'm new to all this OS Tuning and would like someone to take a look at my logs. I just ditched my Cobb, tried to get a protune which was horrible, so now I got a tactrix and am attempting to get it done myself. I used Mater2192's (R.I.P.) 04 WRX Stage 2 map off of osecuroms. My mods are as follows:
Uppipe Catted DP Catback K&N Typhoon Samco I/C hoses 50/50 BOV Adjusted WG arm ACT Steetlite FW It was about 45 degrees this morning when I did these on my way to work. Please review and let me know what you think. I'm a little worried about the 101% IDCs at high rpm but I know they're not running static. Please reply. Thanks - Rich HTML Code:
Time A/F Cr A/F Ln Load RPMs I T T I D C K C A PSI MAF PWDC T O A (mph) 0 0 0 1.71 2602 13.5 27.2 10 8.13 73.31 87.84 100 33 238 0 0 1.9 2704 11.5 32.3 10 10.59 85.5 87.45 100 34 481 0 0 2.13 2786 10.5 39.01 10 12.62 96.81 87.45 100 34 729 0 0 2.18 2883 9.5 43.06 10 14.36 105.2 86.67 100 36 960 0 0 2.15 3026 9.5 44.55 10 14.8 108.67 86.67 100 36 1201 0 0 2.2 3086 9.5 47.31 10 14.95 112.23 86.27 100 39 1443 0 0 2.18 3227 9.5 49.57 10 15.09 117.7 86.27 100 39 1680 0 0 2.24 3346 9.5 52.12 10 15.24 124.73 86.27 100 42 1918 0 0 2.29 3438 9.5 55.81 10 15.38 131.41 86.27 100 42 2160 0 0 2.36 3575 9.5 59.48 10 15.96 140.71 86.27 100 44 2399 0 0 2.39 3702 9.5 62.39 10 16.4 147.65 86.27 100 44 2639 0 0 2.37 3818 10 63.7 10 16.4 152.03 86.27 100 47 2876 0 0 2.35 3976 10.5 66.17 10 16.54 157.46 86.27 100 47 3116 0 0 2.39 4058 10.5 69.26 10 16.54 161.34 86.27 100 50 3358 0 0 2.43 4178 10.5 72.23 10 16.69 167.29 84.31 100 50 3595 0 0 2.45 4300 11 75.23 10 16.83 175.55 82.75 100 54 3837 0 0 2.5 4454 11 79.81 10 17.12 183.6 81.96 100 54 4077 0 0 2.56 4542 10.5 82.37 10 17.56 192.11 80 100 57 4317 0 0 2.52 4673 10.5 85.73 10 17.7 195.1 75.69 100 57 4559 0 0 2.51 4792 10.5 86.89 10 17.7 200.33 67.45 100 60 4804 0 0 2.55 4886 11 88.59 10 17.7 205.8 61.18 100 60 5038 0 0 2.49 5037 11 91.33 9 17.41 209.4 54.9 100 63 5280 0 0 2.48 5095 11.5 91.3 9 16.69 211 49.02 100 63 5517 0 0 2.47 5179 12 91.71 9 16.25 212.6 48.24 100 67 5758 0 0 2.42 5346 13 93.51 9 15.96 215.4 50.98 100 67 5996 0 0 2.36 5450 13.5 94.18 9 15.53 214.2 57.25 100 70 6237 0 0 2.35 5568 14 96.21 9 15.24 217.8 62.35 100 70 6480 0 0 2.37 5630 15 97.29 9 15.24 222.69 69.8 100 73 6718 0 0 2.35 5729 15.5 99 9 15.24 224.4 76.47 100 73 6955 0 0 2.35 5814 16.5 99.22 9.5 15.09 226.95 75.29 100 76 7199 0 0 2.31 5928 17.5 99.91 9.5 14.8 228.66 73.73 100 76 7439 0 0 2.27 6053 17.5 102.01 9 14.65 229.09 72.94 100 79 7677 0 0 2.24 6082 16.5 99.92 8 14.22 228.66 71.37 100 79 7917 0 0 2.21 6224 20 100.91 8 14.51 229.09 70.2 100 81 8158 0 0 2.18 6281 20 100.5 8 13.93 230.37 69.41 100 81
10-26-2008, 08:16 AM | #2 |
Member#: 67535
South East
It seems like my intake is throwing off my K&N Typhoone short ram is throwing off the MAF. Does anyone know how to tune for this intake?
10-26-2008, 05:58 PM | #3 |
Member#: 118112
Start by using the MAF tab on romraider and drive around for a good while. It is a great way to scale in your MAF.
Also your Turbo Dynamics seem to be off a bit. |
10-26-2008, 08:12 PM | #4 |
Member#: 11205
NWIC
Vehicle:2015 WRX WRB |
From what I have heard from other s the K&N generally needs to increase your MAF numbers. (They like to make HP numbers with there intake by leaning out and advancing timing through MAF manipulation) This would not explain your high IDC numbers. The one thing I recommend is to clean your MAF. I have seen dirty MAF's cause cars to run rich and lean. It is always due to the use of a oiled air filter. If you ever run a oiled air filter try to clean it at every oil change.
Just remember to clean the MAF and not the IAT sensor. Both sensors are on the MAF sensor and the MAF is the one hidden in the tube not the big obvious one,That one is the IAT. |
10-26-2008, 08:57 PM | #5 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
maybe log different parameters to give a better idea of whether anything is going wrong and all is ok
Try the following (with laptop connected to your car): 1. Download the Learning View Tool (HERE), extract it and open it. 2. Choose the correct com port for your openport cable 3. Select "Connect", then "Update" and finally "Save" and save the Learning View Tool's csv file somewhere you'll find it. 4. Open RomRaider Logger (if you don't have the latest release of RomRaider, rc4, then uninstall your current version, delect the romraider folder, and reinstall the rc4). 5. In RomRaider, select the correct com port for your openport cable, select "dashboard" tab and then do a 3rd gear 2000-redline log with the following parameters (if at any point you spot something dangerous, ie lots of knock etc, then stop the log): AFR Sensor #1 (or WB02 if you have one) Engine Load Direct Engine Speed Feedback Knock Correction Fine Learning Knock Correction Throttle Mass Airflow Injector Duty Cycle 6. After the log, in RomRaider, click the red cross to disconnect from the ecu 7. Open the Learning View Tool and select "Update" and then "Save" and save the Learning View Tool's csv file again. 8. Post a link to the 2 Learning View Tool csv files and the 3rd gear 2000-redline log csv file in here. The info in those three files will be more helpful Last edited by wrxsti.l; 10-27-2008 at 04:20 AM. |
10-26-2008, 09:02 PM | #6 |
Member#: 132400
Vehicle:2006 WRX |
whats the difference between feedback knock correction and fine learning knock correction?
10-26-2008, 09:32 PM | #7 |
Member#: 156973
International
Basically (and I mean very basic):
Feedback Knock Correction = knock that has just occurred and as a result timing is pulled Fine Learning Knock Correction = corrections based on knock that are stored (learnt) and then applied to where the knock was occurring (load and rpm range). For details information about Subaru's knock control strategy, please read THIS thread. |
Can someone please review my logs? | dlh1999 | Commercial ECU Reflashes | 0 | 06-24-2007 05:46 PM |
Please evaluate my log, first timer!!! | BBBsti LTD | Engine Management & Tuning | 4 | 03-19-2007 10:49 AM |
Someone please analyze my logs...I think I am detonating badly... | JayD707 | AccessPort | 9 | 01-13-2007 02:48 PM |
Please check my logs from today | MidRex | UTEC | 15 | 04-14-2006 10:38 PM |
Please Analyze my Logs | Need BB | Engine Management & Tuning | 4 | 08-05-2005 02:34 PM |
