11-19-2002, 09:14 PM | #1 |
Member#: 3773
Vehicle:2002 WRX Sedan 2006 Outback 3.0R |
WRX valve adjustment
I tried searching here and found nothing. And I can't find any mention of it in the owner's manual either.
The WRX has solid lifters. At what mileage is it recommended that they be adjusted?
11-19-2002, 09:33 PM | #2 |
Member#: 14178
E. Canada
Vehicle:2002 WRX Sedan Platnium Silver Metallic |
I couldn't find any time frame listed in the service manual, althugh they give you detailed specs on the min/max values.
11-19-2002, 09:35 PM | #3 |
Member#: 10615
iirc, the valve in the wrx are hydraulics and does not require adjustment, however, it can be shimmed.....chances are, this is not going to be required for a long time, if ever
11-19-2002, 09:46 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
The lifters are solid. The service manual contains an adjustment procedure although no service interval is specified. I have seen reference posted to an interval of 105K miles but I don't have any links to back that up.
11-20-2002, 08:11 AM | #5 | |
Member#: 3773
I was thinking more along the lines of 60K miles. |
11-20-2002, 10:05 AM | #6 |
Member#: 6436
Vehicle:1998 Impreza 2.5RS BDP |
for EJ25D
The official word for EJ25D is a *check* of valve clearances at 105k miles. No adjustment interval is specified. Perhaps EJ20 is similar....
11-22-2002, 09:59 PM | #7 |
Member#: 3773
Does the EJ25D have solid or hydraulic lifters?
11-23-2002, 08:27 PM | #8 |
Member#: 8225
My EJ25
don't know about the D has solid lifters. My advice is to have them checked if they get noisy(er). I've had mine checked/adjusted in association with some other work for $96.
'02 WRX Valve adjustment? | silence2-38554 | Service & Maintenance | 71 | 07-13-2016 08:05 AM |
valve tick or valve adjust? | ali dashty | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-06-2008 06:15 PM |
Are '02-'03 wrx valves adjustable or fixed? | hobbzz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-15-2003 11:14 PM |
Has anyone done valve adjustments | MY99 2.5GT | Normally Aspirated Powertrain | 2 | 06-27-2001 05:55 PM |
Valve adjustment | Pinoy | Southern California Impreza Club Forum -- SCIC | 0 | 06-13-2001 10:42 AM |
