04-30-2013, 01:59 AM | #1 |
Member#: 307286
Vehicle:05' EJ25 - Stock Metallic Gray |
my 2005 STI reached 104000+ mile
I've been meaning to post this for quite sometime. My STI reached 100000+ miles. So far the car runs great and had no problem with it whatsoever. Bought the car brand new and NEVER went back to the dealearship after that nor had any engine repairs done at any car shop. I did all the maintainance by myself. I never trusted the dealership or any local shops to do it.
I used to drag race quite a few times when it was still below 30000 miles. after that, its mostly spirit driving and some highway pulls. The fastest I went with the car was 148mph...Today, the car still pulls like a beast to 100+. Some history with the car: Car got broken into twice and the ignition console was ripped out but the car thief was unable to drive the the car far enough (maybe beacuse of the auto kill switch installed, maybe?). Insurance took care of it, and it was all fine and dandy. You guys might hate me for this but...I had been using the same K&N typhoon filter since it was at 18000 miles, just cleaning and washing it occasionally... and never had a problem with it. I promise I will change it sometime this year. I have yet to change my transmission fluid since I bought the car and its still shifting smoothly. Again, I will also change it sometime this year. Same clutch. same rotors I just recently change the spark plugs a week ago with NGK LFR6aIX-11 (first time) Brake pads changed twice ( i switched to ceramic brake pads. (less dust). Bled the brake once. Rear diff oil changed once at 50000 miles (Valvoline 75w-90 systhetic). Oil change every 5000 miles with Mobile-1 5w-30 super systhetic. AC and Alternator belt changed once at 70000 miles (OEM) That covered up about everything. I will take any type of advice and criticism as I really wanna hold on to this car for as long as it runs. I really love my car and this is the only car that lasted with me this long and I'm hoping that it will keep going for another 100000+ miles more. Thanks
04-30-2013, 02:13 AM | #2 |
Member#: 190405
SCIC
Vehicle:1991 Legacy Turbo Pearl White |
lol mobil1... you should don the flame suit immediately.
But in all seriousness, congrats on the longevity! It would behoove you to switch to a better oil (Rotella T6 Synthetic 5w-40 or something similar) before you spin a bearing with that Mobil stuff. It has a reputation for ruining Subies. |
04-30-2013, 02:13 AM | #3 |
Member#: 190405
SCIC
Double post... drat. Double drat. I'll use it to remind you that the timing belt is due at 105k.
Last edited by cartwheels4amile; 04-30-2013 at 02:14 AM. Reason: double post -__- |
04-30-2013, 02:13 AM | #4 |
Member#: 285248
SCIC
Vehicle:2014 PBP GR WRX 2006 STi - SOLD :( |
Threads like this really raise my confidence in my STi. I bought it in December with 95k and its a beast. I'm about to do the water pump/timming change. Congrats on your long life with your car!
04-30-2013, 02:18 AM | #5 | |
Member#: 307286
04-30-2013, 02:18 AM | #6 | |
Member#: 341113
SCIC
Vehicle:2013 WRX Dark Grey Metallic |
04-30-2013, 02:31 AM | #7 |
Member#: 278763
Vehicle:2004 WRX Silver |
That's good to hear, I know way too many people that are convinced they won't hold up. I bought my nearly 300whp WRX with 98k miles on it, it's at 119k now and it's been modded since 60k miles or so. Runs like a champ, only had to do timing belt and clutch
04-30-2013, 02:37 AM | #8 |
Member#: 234485
Vehicle:2004 STI Rally Blue |
121k with my 04 STi same timing belt and headgasket haha
04-30-2013, 06:12 AM | #9 |
Member#: 94283
Vehicle:'19 Ascent |
If you don't do what NASIOC tells you to do for maintenance, your car will explode and you will die! Either that or nothing bad will happen and your car will run fine.
04-30-2013, 10:29 AM | #10 |
Member#: 11356
Vehicle:2012 WRX STi Hatch DGM |
04-30-2013, 10:33 AM | #11 | |
Member#: 307286
When there's a problem, Nasioc is always there to the rescue!!!.....and youtube. haha. But in all seriousness, thank you all! Anyway, Just ordered my New K&N air intake filter replacement, and gates timing belt kit!!! Just waiting for a perfect day to spend time in my garage. I also found that my Walmart sells Rotella T6 5w-40 for $21.95 woohoo! |
04-30-2013, 10:41 AM | #12 |
Member#: 340009
SWIC
Vehicle:2007 STi CGM 1990 Toyota Cressida 2JZ |
My 07 just hit 112k. Same clutch, Changed all fluids, plugs, timing belt, pullies, water pump, just regular maintenance really. Been stage 2 for about 20k miles with all grimmspeed gaskets, Invidia turbo back, K&N, EWG and loving it! When my turbo goes I have a VF48 Sitting on the workbench for me. Not an upgrade, but still new.
04-30-2013, 11:04 AM | #13 |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
I would follow Subaru's guidelines on changing fluids, however to go that long on trans and diff fluid is something. Make sure when you do change them to run a magnet through each fluid to look for metal.
04-30-2013, 11:24 AM | #14 | |||
Member#: 153088
Vehicle:2005 Baja Turbo 95&96 Sambar 06 Forester |
Subaru says 5w30. Mobile 1 has worked for you. Stick with it and continue doing what you do. Up until SOA started selling their own synthetic, all I had in mine was Mobile 1. NO PROBLEMS what-so-ever. If it was going to cause a problem like they are saying, probably would have shown signs by now. |
04-30-2013, 02:26 PM | #15 | |
Member#: 268310
SCIC
Vehicle:2011 SSM STI saloon Church! |
04-30-2013, 02:43 PM | #16 |
Member#: 262366
Vehicle:07 wrx-sold 06sti- sold 00rs-rip 05 GRP LGT |
+1. I've been using the same mobil 1 synthetic oil at 2,500 mile intervals and i'v had no issues. Congrats on the longevity. If mine turns out the same way I still have atleast 8 yrs to go...lol. By that time rust will probably be my #1 issue since I have no garage and live in the maic area.
04-30-2013, 02:47 PM | #17 |
Member#: 321634
SCIC
Vehicle:2005 Wrx 2.0 WRB |
The plugs with -11 at the end aren't set the right gap. I bought a set on accident and they were all gapped at .040" when they should be .028". Hope you gapped them before installing.
04-30-2013, 03:11 PM | #18 |
Member#: 309943
Vehicle:2012 STi OBP |
I really want to see you run the transmission fluid through a coffee filter when you finally change it.
04-30-2013, 03:29 PM | #19 |
Member#: 271097
SCIC
Vehicle:2014 Evo Gsr wicked white |
don't all boutique synthetic oils use the same base from 3m or basf or whatever then just use there own adds.
anyways just use whatever is working. |
05-02-2013, 01:03 AM | #20 |
Vehicle:OK buy Nates beans westcoastroasting.com |
im quite surprised it hasnt blowed up
05-02-2013, 08:55 AM | #21 | |
Member#: 263694
Vehicle:2002 WRX World Rally Blue |
05-04-2013, 04:29 PM | #22 |
Member#: 307286
Yeah I have to adjust the gap. It wasn't too bad. The wiring gapper came with the spark plug adjuster on it. Definitely worth the money.
05-04-2013, 05:40 PM | #23 |
Member#: 193206
Vehicle:2004 WRX Wagon Red |
Make sure you check and adjust the valves clearance, I just did it on my 04 WRX Wagon with 110K miles.
05-04-2013, 07:59 PM | #24 |
Member#: 289315
Vehicle:2006 STi "Frosty" |
Mobil 1 is fine if you don't drive the car hard. Once you get into higher rpm and with more heat it begins to shear. Since most people drive their car hard as most people on this forum. Mobil 1 is no bueno.
05-04-2013, 08:20 PM | #25 | |
Member#: 97135
Rule of thumb, don't buy m1. |
