12-19-2006, 11:37 AM | #1 |
Vendor Sales Rating: (61)
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
AccessPORTs v2 in stock + COBB deals = happy holidays
Happy Holidays all!! Right now I have A lot of stuff that we'd like to move out before the years up!
*AZ residents please read the note at the bottom The NEW AccessPORT by COBB Tuning is a powerful tool to use in your quest for maximizing the potential of your vehicle. The AccessPORT allows you the ability to upload pre-programmed maps to the Engine Control Unit (ECU) via the OBD-2 port in a matter of minutes, and requires no cutting, wiring, or other modification. Stay up-to-date with the latest map revisions or find maps best suited for your modifications by simply downloading them from the Internet into your AccessPORT. The AccessPORT can easily grow and adapt with your needs. Alongside other vehicle modifications, the AccessPORT can instantly unlock up to 50+ HP using off-the-shelf maps! Features: On-the-fly map switching Monitor vehicle sensor data and display in analog or digital format Vibrant color graphic display Rear/Clear engine trouble codes Preloaded with performance, economy and convenience maps Update via the Internet Measure 0-60 and Ό miles times Adjustable on-screen Shift Light functionality Estimates horsepower and torque Displays current and averaged fuel economy Drag race simulation with reaction time and time slip data Built in on-screen help mode function Multi-Language support RoHS compliant (Lead Free design) Can be custom tuned by our network of ProTUNERS (IA Performance is a Protuner/Dealer) $695 shipped to your door in 48 states, we have special pricing for the remaining 2 states as well as Export sales. Current Applications Subaru: 2002-2006 WRX, Sti, Legacy GT, Outback XT and Forester XT Coming Soon: Subaru: 2007 (est 1st quarter 2007) Mitsubishi: Lancer Evolution 8 and 9 (est Jan 4, 2007) Nissan: 350Z, Titan, Armada, Altima, Maxima, Xterra, Murano, Sentra (est 1st quarter 2007) Infiniti: G35, M35/45, Q45, FX35/45, QX56 (est 1st quarter 2007) Mazda: RX-8, Mazdaspeed6, Mazdaspeed3, CX-7 (est 1st quarter 2007) Incentive for AZ residents! No sales tax, that's right. We'll eat the 8.1% tax in order to continue delivering quality products at competitive prices. Locals that has already purchased a unit and paid tax are covered. We are offering the taxed amount in form of protuning credit. I.E. if you paid $56.30 in tax then you will have $56.30 in credit at your next protune visit. 12L spec C water tank. Genuine STI of Japan part. Fits directly behind the back seat and also includes mounting hardware. Intended for Impreza Sedans, may fit other vehicles. 12L in total holding capacity. Fits with rear tower bar installed. Tower bars we have tested w/ the tank in place: Whiteline, STI, Cusco. The tank is embosed with a large STI emblem on it. Homologated for N11 and N12 rally use. Light weight. Includes:
2 Left for $175 plus shipping Our revolutionary Double Adjustable Shifter ushers in a new generation of adjustability for one of the most critical links from driver to car with the ability to control both the height of the shifter as well as the throw. Designed using CAD technology, the COBB Blue anodized billet shifter body is CNC machined from 6061 Aluminum. Like our original design, the shift throw distance and shift knob height are independently adjustable and both can easily be adjusted with the shifter installed in the vehicle. Stainless Steel socket head screws are set in a counter bore for a flush mount and provide a clamping force that firmly holds the upper and lower slider shafts in place. This new design improves the ease of making adjustments while also being significantly stronger. Compatible with the factory shift knob or any aftermarket knobs designed to replace the factory unit Cobb Short Shifter for WRX 02+,RS,Legacy GT 05+, and 06 FXT $135.00 shipped system utilizes several unique features in an effort to maintain optimal flow for performance while minimizing turbulence that can cause engine management problems. From a custom conical cloth air-filter element, we use a CFD-designed velocity stack leading to an unique air flow straightener grid. This straightener grid is specifically designed to smooth the incoming air flow as it passes the Mass Air Flow sensor for precise readings. This eliminates the "dead spots" experienced by other aftermarket intakes due to turbulence. NO other aftermarket Subaru intake system utilizes these critical design elements. In order to provide a system that looks as good on the outside as the technical advancements happening on the inside, we utilize a one piece design constructed from a high temperature plastic composite. Not only does this save weight compared to the previous metal design, the plastic composite material offers much better heat rejection properties that help keep intake air temperatures cooler. In contrast, intake systems constructed using metal castings or piping can actually retain underhood heat and in turn heat the incoming air. The SF Intake System is available with a Black OEM-like finish. A powdercoated black support bracket is included for secure installation. The system is finished out with a custom designed COBB Blue cloth conical filter which has been pre-oiled. Our filter is serviceable (like a K&N) with an available cleaning/oiling kit and does not need to be replaced for the entire lifespan of your vehicle. $150.00 shipped Fits 02-06 WRX/STI CAD designed and CNC machined from billet 6061-T6 and hard anodized for a long lasting finish. Directly replaces the factory main pulley. Built to the factory diameter as to not underdrive your accessories. Drive belt surface precision machined EXACTLY to specifications provided by OEM belt manufacturer to ensure long belt life. Timing notch identical to factory pulley. Weighs 1.2lbs, over 4lbs lighter than the factory pulley for improved engine acceleration. Fits Subaru EJ motors from 99-2006. NA and Turbo applications included Cobb Light Weight Pulley Blue or Gold $135.00 shipped http://www.iaperformance.com/images/...XT_Catback.jpg ALL NEW DESIGN! Our new system is constructed entirely of high-quality T304 Stainless Steel, from the hangers to the flanges. The COBB WRX Cat Back Exhaust system replaces everything after the stock catalytic converter with smooth, 3" mandrel bent piping. The system is tastefully finished out with a specially designed, robotically welded Stainless Steel Muffler directing the exhaust gases out a double-walled 3.5" tip featuring an embossed COBB logo. The results are improved performance and a nice, sporty sound not obnoxious or buzzy. 100% Emissions Legal and Subaru Warranty Friendly. $645 shipped fits STI/WRX Greddy EVO2 Exhaust for Subaru Impreza STI 2004+ Inherent in its name, the EVO2 cat-back exhaust system is a huge step forward. In addition to the Greddy straight-through technology, offset tip design and large piping diameters of the original EVO, the EVO2 is now offered in full stainless steel providing improved looks, durability and corrosion resistance while maintaining the best qualities of the original such as fitment, sound and performance. Street legal polished stainless steel muffler Straight-through design produces more power and torque and a gives your car a deep-throaty sound Polished tip is embossed with the recognizable Greddy logo. One of the best exhaust systems available for your sport compact! Laser-cut, computerized mandrel bent aluminized tubing, thick flanges and OEM-style hangers. Larger piping diameter with round muffler, perforated tubing and non-corrosive stainless steel mesh meticulously designed for each application. Easy bolt-on installation using factory mounting hardware. Specific Impreza STI EVO2 Exhaust Features: 80 mm piping to enhance exhaust flow and add horsepower 115mm Stainless Tip design to add style to your car. Greddy has designed the EVO2 Cat Back Exhaust to bolt up to the Factory Catalytic Converter and remain 50 State Legal. For STI/WRX $568 plus shipping Helix SUS Series downpipes incorporate full SUS304 stainless steel piping for maximum durability and good looks. Only the finest materials and manufacturing processes are used to ensure a perfect product every time. Every vehicle application is extensively researched and tested before final designs are approved for production. Helix downpipes employ the finest features to ensure maximum performance characteristics. - 100% SUS304 Stainless Steel - CNC Mandrel Bent Piping - Robotic TIG Welding - Anti-Corrosion Mirror Polish $250 shipped STI/WRX, $399 shipped for high flow cat version If you have any question please feel free to contact Stephen or I Gabe Rios Sales www.iaperformance.com 4475 W. Ina Road #101 Tucson, AZ 85741 (520)882-2821 AOL AIM: iaperformance2
12-28-2006, 06:39 PM | #3 |
Member#: 25194
RMIC
we have just a few 2.5L AP v2 left in stock. Get them now while COBB is closed through the New Year!!
jsmithjr732- We have a 2007 Sti in the shop for a custom motor build, we too can not wait Drop us an email or PM and we can get you setup to receive one of the first 07 units. [email protected] or [email protected] Thanks ahead of time. Stephen |
Similar Threads | ||||
2010 WRX AccessPORTs are IN STOCK!!!! $1 menu BEST ACCESSPORT DEAL EVER!!!! | CygnusPerformance | Engine Management | 32 | 06-14-2010 12:51 PM |
We will BEAT any deal on the Cobb Tuning AccessPORT! Always in stock! | maperformance | Engine Management | 4 | 06-25-2009 10:52 AM |
V2 Cobb Accessports Back in Stock- get yours today! | EviL Performance | Engine/Power/Exhaust | 36 | 01-14-2008 12:24 PM |
Last 2.5L Cobb V2 in stock. Someone give it a happy home. Free Overnight Shipping | GreyMotorsports | Engine/Power/Exhaust | 1 | 10-24-2007 10:40 AM |
COBB Accessport V2 In box! | powerlabs | Engine/Power/Exhaust | 6 | 09-04-2007 10:58 PM |
