02-02-2012, 11:23 PM | #1 |
Member#: 286573
BAIC
Vehicle:2016 WRX STi limited Crystal White Pearl |
Very specific sti tmic to wrx question
Hey guys, I know there are a billion posts on this subject, but I could not find an answer to this question specifically. I have a 2006 wrx, and I am purchasing a 2004 wrx sti TMIC. From what I have gathered all is well after ordering a 2" 90 degree Elbow (yes its got the Y pipe on it). I believe I'm good to go, except for the splitter on this thing... Because it's an '04 sti I believe the splitter will be too tall (seller is including splitter)... So the question is, Will the 2004 sti tmic splitter fit? If it doesn't fit, does anyone recall some one modifying it to work properly? Or are the bolt patterns completely different?
EDIT: I found this question asked - But it never received an answer, so rather than revive the dead, maybe I can make this a fresh one.
02-03-2012, 03:28 AM | #2 |
Member#: 226359
W. Canada
Vehicle:2006 WRX obp |
find an '06-'07 sti splitter. the height of the '04 is less of a problem than the mounting issues. different hood + different scoop = different bolt locations.
you can get the splitter and bellows new at SGP, but if you can find a used '06-'07 on here it will be cheaper the wrx one will work if you leave it on, but it won't be as efficient. it will only direct air through about 2/3 of the intercooler experience: i have an '06 wrx with an '04 sti intercooler -sean |
02-03-2012, 03:59 AM | #3 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
i have a v7 sti tmic and v7 spec c splitter on my 06 with the stock scoop and it fit with just a bit of making it fit I had ALL the same parts on my 02 wrx that had the bugeye jdm sti scoop |
02-03-2012, 05:46 AM | #4 |
Member#: 226359
W. Canada
oh, good to know, thanks uncle scotty
OP: disregard everything i said previously, i have been bested haha -sean |
02-03-2012, 06:09 AM | #5 |
Member#: 16200
many of these parts are interchangeable...straight swap....or slight 'massage' required
even if they LOOK like they wont fit |
02-03-2012, 06:32 PM | #6 |
Member#: 286573
BAIC
lol hey thanks a lot uncle scotty, and sean... I value your guy's opinions so thanks, I'll post more on here when I get everything, and begin "massaging" my splitter on :P
02-09-2012, 10:57 PM | #7 |
Member#: 282455
Vehicle:2015 Wrx Galaxy Blue Pearl |
I am getting an sti tmic for my 02 wrx. Do you think a new scoop and splitter is the way to go or can i just cut or even remove the splitter so my tmic is in full efficiency
02-11-2012, 12:28 AM | #8 |
Member#: 286573
BAIC
Vvvvv
02-11-2012, 12:29 AM | #9 |
Member#: 286573
BAIC
The splitter, stock or sti, is designed to direct air precisely across the intercooler. Removing it completely would be kind of risky or would not help with cooling the air any more than before. You'd be better off leaving the stock splitter on there until you can pick up an sti splitter. The OEM sti splitter parts are online, and they should fit you 02. its like $90 for the splitter and $30 for the shroud.
02-18-2012, 08:19 PM | #10 |
Member#: 286573
BAIC
So I fitted the Sti TMIC and the splitter! Had to trim the splitter!!! But it works, and is all bolted in. the pattern of bolts was the same on the splitter. The height was much too tall, so I had to trim it down about an inch, then bend the mid divider the runs horizontally. That way the hood scoop was divided evenly, now I don't know much about the aerodynamics of the hood scoop, but I am assuming that I have been able to make the air flow evenly lol. Here's to hoping!
09-05-2012, 02:57 PM | #11 |
Member#: 327229
South East
Vehicle:2005 Wrx OBP |
i have a 05 wrx and bought a sti TMIC for it, but i dont have a atermarket y pipe. What do i need to buy for this sti intercooler to fit my wrx
SoCal WTB: Sti Y-Pipe, TB Coupler, Elbow for STI TMIC to WRX | DirtstyleWRX | Private 'Wanted' Classifieds | 6 | 05-17-2008 11:38 PM |
WTB: Y-pipe to install sti tmic to wrx. | sensesfail85 | SCIC Private Classifieds | 2 | 04-15-2008 09:41 PM |
Quick STi TMIC to WRX question. | ControlFreak | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 04-14-2006 05:55 PM |
fit STi IC to WRX? questions. | wrxcelent | General Community | 2 | 01-10-2006 06:38 PM |
STI TMIC to trade for stock WRX TMIC | wikidwrx | Bay Area Impreza Club Forum -- BAIC | 17 | 01-02-2004 12:47 PM |
