01-08-2012, 02:49 PM | #326 |
Member#: 254451
Vehicle:2007 Legacy GT Black |
These threads all look so awesome!! Wish I can accomplish this kind of a build sometime.
01-08-2012, 06:16 PM | #327 |
Member#: 260868
South East
Vehicle:2011 STI White |
Well the AOS is finally installed. Took about 3 hours. I thought it would be faster since I did do half the work yesterday but then returned everything back to OEM since I got stuck. The Dom is really tight to the intake manifold and makes getting the crank case breather hoses out and back in real difficult. The hoses from the AOS are really thick and make putting everything back together difficult as well but it can be done. The pipe from the bottom of the AOS to the crank case is slightly shorter than what is seen in the install instructions and videos but does work. Also, being a newbie like me i did not know coolant would shoot out of the coolant reservoir to turbo hose when I removed it to reroute it to the AOS. I had to go get more coolant because i lost so much of it.
Also, if anyone has the Perrin inlet hose, you need to get a 5/8"x1/2" coupler. The vent hose from the AOS to the inlet hose comes in 5/8" size. The perrin nipple is 1/2". This was my last connection and I couldn't believe I didn't see this. Coupler: Installed: Finished: Last edited by jockeygolfs; 05-22-2012 at 07:41 AM. |
01-08-2012, 06:17 PM | #328 |
Member#: 260868
South East
01-09-2012, 12:12 PM | #329 |
Member#: 260868
South East
01-09-2012, 12:54 PM | #330 |
Member#: 35081
NESIC
Vehicle:2012 WRX WRB |
^ Nice, I'm debating on a system myself!
01-09-2012, 07:46 PM | #331 |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
Look at Jockey spreading the knowledge!
01-09-2012, 08:30 PM | #332 |
Member#: 260868
South East
I don't have much of it but what I do have I don't mind passing along!
01-11-2012, 07:10 PM | #333 | |
Member#: 260868
South East
01-11-2012, 07:29 PM | #334 |
Member#: 306605
oh my, it's so beautiful. My friend has an 11 sti in silver, he has to see this!
Sadly for him, he went stage 2 and had the car flash tuned from Cobb, yeah well my guess it was a fail, he ran way to rich and now his car is knocking and barely moves. He will be putting it back to stock and getting it all fixed, then modding it RIGHT the second time around lol. |
01-11-2012, 07:50 PM | #335 |
Member#: 260868
South East
You live and learn lol. Pro-tune all the way but crap happens. He might have a leak somewhere or something too. These cars are nuts but I guess it is all part of being a Suby owner.
01-11-2012, 11:04 PM | #336 |
Member#: 252294
Vehicle:08 Impreza Wrx Dark Grey Metallic |
dude sick car
01-11-2012, 11:55 PM | #337 | |
Member#: 283784
RMIC
Vehicle:2015 MUSTANG GT PP GUARD |
01-12-2012, 06:07 AM | #338 | |
Member#: 260868
South East
Never mind. I searched. Use gasoline or just let it burn up into the engine since additional oil should not be building up in there in the future. Last edited by jockeygolfs; 01-13-2012 at 06:07 AM. |
01-21-2012, 01:11 AM | #339 |
Member#: 293504
South East
Vehicle:2011 WRX Blue |
Sup Jockey? Long time. Build looks insane. I gotta meet up with you one day or swing by your place or something to check it out. Hope all is well with you and the fam
01-21-2012, 06:39 AM | #340 |
Member#: 260868
South East
Hey buddy. Let me know when you want to come by. I'll be more than happy to give you the tour. Hope all is well.
01-21-2012, 11:25 AM | #341 |
Member#: 299305
Quality parts and nice build. hope to have my subie by the time I come down to FL in April. That way can see this beast and the other ones down there.
01-21-2012, 11:06 PM | #342 | |
Member#: 290057
I havent read through your post past here, but if nobody helped you which I beilieve is unlikely what I did is ran it through the port behind the DP, where your engine harness comes out of, along with my wideband, alarm and stereo power. And for the sensor, your best bet is to take off the alternator, unplug the worthless stock one that tells you when it's to late, and use the galley plug thats already there for your new sensor, I went with defi. Of course I learned the hard way after trying to use the other one underneath the manifold, both the stock sensor and the defi would not fit, maybe if you got something like the AMS style plug that has an 18" extension. Good luck on your build, just curious though, was there a reason you didn't assemble your block yourself? and how much did you have to pay someone to do it for you? |
01-21-2012, 11:19 PM | #343 |
Member#: 290057
Currently I'm running Perrin Fuel Rails, but not for much longer than a week I've found a solution that uses no dampners, what I did was take the quick disconnects off the feed and return, bought ss line, and fed the rails parrallel returns parralel back to the Turbosmart FPR, and finally the actual return on the bottom of the fpr is to the bottom line at the firewall. I used AN-6 line and Russell fittings, the split for the feed is a regular -6 T. Again, the entire design and install was done by me myself and I, theres pics on my build page, I'm going rotated, with new internals on a Full-Race kit I've had since november in about a wekk, so I'll be switching to cosworth rails and DW 1300 CC injectors.
Bottom line is by taking the balancer, dampers which you have no use for because they are emission control devices that make your fuel supply kind of surge, not necessarily the correct terminology, but you can't tune it out completely, after doing this, I've obtained confirmation from some builders who told me that my idea was all the way right. Hope this helps |
01-22-2012, 07:18 AM | #344 |
Member#: 260868
South East
Thanks for the info. I'll check it out. I try keeping the car above 3k RPM's to avoid the hesitation. I was thinking of going with Aeromotive FPR and rails. I think that would eliminate the dampeners.
I did not build my own block because I do not own the necessary tools. The cost of the tools would probably be equivalent to the cost of having a pro assemble it. I will probably take a shot at it when I get my stock block pulled. I plan on building that block up as well. Last edited by jockeygolfs; 01-22-2012 at 07:45 AM. |
02-02-2012, 12:40 AM | #345 | |
Member#: 283784
RMIC
02-04-2012, 06:53 AM | #346 |
Member#: 260868
South East
Howerton two tank system has finally been ordered for the meth injection kit. I can't wait to receive it. I am estimating that everything will be installed within the month. Fingers crossed.
In the meantime I'm waiting to get an 05' STI FPR to swap out my current FPR. I already have dampers from an 07' STI. Hopefully this will eliminate the hesitation. This swap will happen on Monday most likely. |
02-04-2012, 03:38 PM | #347 |
Member#: 249068
South East
Damn jockey the build is moving fast. What was ure hp goal again?
02-04-2012, 08:57 PM | #348 |
Member#: 260868
South East
Hey there Rob. On my current turbo and fueling setup I'm aiming for 400 whp with 50/50 water and meth. I think I will be done with power mods for a while. When the block decides to go then I'll swap it. I don't think I want to go with a bigger turbo, this one is quick and fun as is so there is no real rush to get another turbo.
02-05-2012, 08:07 AM | #349 | |
Member#: 249068
South East
02-05-2012, 08:46 AM | #350 |
Member#: 260868
South East
E85 is not available around Palm Beach County. The closest station is about 30 minutes away. I know I could probably swap maps to go back to 93 when I run out but that seems like a real pain just to go and get E85. Plus, E85 cuts your vehicles range by half I believe. Ron (Phatron) has recommended injection and has never had an issue on his car.
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan | btr22 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 42 | 07-08-2016 02:26 PM |
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** | Forged Performance | NASIOC Project Cars | 462 | 07-06-2016 08:06 PM |
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! | IMPORTIMAGE | Vendor Announcements | 4 | 05-02-2011 09:50 PM |
Comparing 2011 STi Sedan to 2011 WRX Sedan | DasWRX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 12-21-2010 07:09 AM |
new with a question about 2011 STI sedan vs. previous STI sedans | tommygsubie | Newbies & FAQs | 37 | 11-02-2010 12:16 PM |
