01-21-2004, 02:25 PM | #1 |
Member#: 18709
fuel pressure regulator and stock injectors?
okay, what if i up the fuel pressure on the stock injectors. would i be able to run a bigger turbo? i was thinking of doing the free fuel pressure regulator upgrade thingy, however, what effect will this have if i keep the stock injectors. say i get a VF30, could i run it off the stock injectors + higher fuel pressure? any suggestions?
01-21-2004, 02:41 PM | #2 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
I wouldn't risk the integrity of the car with those upgrades when you can modify the stock injectors to flow 720cc for free. Do the injector mod, get a fuel pump and leave the FPR alone. You do have engine management right?
01-21-2004, 02:59 PM | #3 |
Guest
Member#: 43667
clamdip, you can run a VF30 on the stock injectors with NO fuel system mods. you just need a REALLY GOOD tuner.
01-21-2004, 03:08 PM | #4 | |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
01-21-2004, 03:09 PM | #5 | |
Member#: 21980
NESIC
01-21-2004, 03:14 PM | #6 | |
Guest
Member#: 43667
01-21-2004, 03:36 PM | #7 |
Member#: 7922
Where is your EGT tapped. Is it in your uppipe? Those are very very low EGTs.
01-21-2004, 04:37 PM | #8 |
Guest
Member#: 43667
those numbers are from Delta Dash, so yeah, I know they're lower than what an EGT gauge would read if tapped into the exhaust manifold.
the point is that the car is tuned around the stock fueling. i know it's not making it's full potential (but still a huge improvement over stock), probably not even close to what it could do with upgrading the fuel, but it's a work in progress, and it can be done. p.s. sorry for hijacking your thread Clamdip. |
01-21-2004, 05:09 PM | #9 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
VF30 @ 18psi on pump gas Stock WRX injectors with no mods to them Max 90% IDC Please tell us what you haven't told us yet. Like... that you're running water injection or something. |
01-21-2004, 05:33 PM | #10 |
Guest
Member#: 43667
it's an automatic, and I'm pretty sure that's where the difference is.
01-21-2004, 11:01 PM | #11 |
Member#: 18709
cool, thanks for the replies guys! yeah, i heard that you can run the VF30 on the stock fuel system, however, your IDC's will be a bit high. also, about the "free mod" for stock injectors, i would need some type of tune for that. i guess i just have to buy STi injectors. thanks again guys.
01-21-2004, 11:45 PM | #12 | |
Guest
Member#: 43667
01-22-2004, 06:20 AM | #13 | |
Member#: 5961
South East
Vehicle:2005 STi CGM |
What free fuel pump (not injector) mod are you talking about...must of missed it.
VV Quote:
01-22-2004, 10:09 AM | #14 |
Member#: 21980
NESIC
You will need a tune for either the stock modded injectors or STi injectors, dont think you can plop them on the car and have it run OK.
01-22-2004, 10:20 AM | #15 | |
Member#: 15194
Vehicle:2004 Lightning, 2001 BMW 330ci |
He is talking about modding the stock FPR. http://forums.nasioc.com/forums/show...hreadid=480255 http://forums.nasioc.com/forums/show...ighlight=rrfpr |
01-22-2004, 10:29 AM | #16 | |
Member#: 5961
South East
OK, Thanks...hadn't heard it referred to that way
VV Quote:
Adjustable Fuel Pressure Regulator faq? (i read the injector faq) | JDMFLCL | Newbies & FAQs | 5 | 11-04-2020 10:24 PM |
BDL fuel rails and fuel pressure regulator | living4surf | Engine/Power/Exhaust | 2 | 09-29-2007 09:38 AM |
Fuel Pressure Regulator and/or Fuel Rails? | mav1c | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 01-19-2003 03:23 PM |
New observations about our fuel pressure regulators and RRFPR's! | Eric SS | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 06-10-2002 10:57 AM |
Fuel pressure regulator alternatives for those not wanting to deal with injectors | RiftsWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 31 | 10-03-2001 04:43 AM |
