07-01-2006, 01:49 AM | #1 |
Member#: 91996
Vehicle:2009 Audi R8 06 WRX Ltd. - Sold |
Is the STi BOV different than the WRX BOV?
Simple question, just want to know if I put an STi BOV on my 06, will I get better flow? Have the Bosal Exhaust+Spt Intake+Sti TMIC???
Let me know, the answer to this question would involve searching 8milliion threads, of which I still might not the right answer. Thanks.
07-01-2006, 02:19 AM | #2 |
Member#: 62595
SCIC
Vehicle:04 WRX Cobb S2 World Rally Blue |
its actually not a BOV, both cars come with a BPV (Bypass Valve) and to answer your question.
No, it will not change a thing because they are exactly the same.... now if you had a JDM STi BPV, it'd be a slightly differnt story. |
07-01-2006, 02:46 AM | #3 |
Member#: 60130
Yes they are different. The sti is able to holp more psi than the wrx. Some people have modded there wrx one to work the same as the sti.
07-01-2006, 02:59 AM | #4 | |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
07-01-2006, 02:30 PM | #5 |
Big Ron
Super Moderator Member#: 18062
USDM STi BPV = WRX BPV
Modded STi/WRX BPV = holds more boost JDM STi BPV = holds more boost |
07-01-2006, 02:37 PM | #6 |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
I've got a JDM BPV sitting on my desk at work, if I remember next week, I'll snap some shots comparing the two.
07-01-2006, 03:05 PM | #7 |
Big Ron
I did a ghetto visual side by side comparo and didn't notice a difference except the round flat part had some numbers on the JDM version. The killer is my reaching inside to push the spring down. The USDM one is a real bitch to actuate by your finger. The JDM one can easily be actuated.
07-01-2006, 03:06 PM | #8 |
Member#: 6971
NWIC
I noticed that too.
07-01-2006, 05:05 PM | #9 | |
Member#: 48199
Vehicle:06 WRX WRB |
07-01-2006, 06:56 PM | #10 | |
Member#: 23676
NESIC
Vehicle:. |
Yeah you are 100% dead wrong. Its the EXACT same valve. Please dont post bad info. A modded WRX valve holds a TON more than a stock USDM sti valve. (because they are the exact same valve, which means a modded STI valve will hold the same as the modded WRX valve. The JDM v7 STI valve however is different and able to hold more. Unabomber, look at the JDM v7, that passage that you block off on the modded one, is already blocked off on the jdm v7. And the JDM v7 top portion is vented, just like the modded one. And it has the softer spring to prevent the minor surge that comes with the modded one (although its not bad enough surge to cause problems) |
07-02-2006, 02:59 AM | #11 |
Member#: 91996
So, there is really no point in investing for JDM BPV unless I am running at least a 20g with a FMIC?
Thanks for all the info again, i love this place. |
07-02-2006, 03:02 AM | #12 |
Member#: 78118
unless you are running more psi than the stock one can handle then nope
07-07-2006, 05:03 PM | #13 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
bump...
07-07-2006, 11:06 PM | #14 |
Member#: 119570
bump muhfukkkkaaaaaaaaaaaaaaaaaaaaaah
07-08-2006, 01:58 AM | #15 |
Member#: 29961
South East
Vehicle:2008 Honda Element 1975 Triumph Spitfire |
It's bigger because it's faster
07-08-2006, 02:13 AM | #16 |
Member#: 88618
SCIC
It's called "Anti-hydrolock" instead of "Anti-lag" these days.
Is stock STi exhaust better than stock WRX exhaust? | MDRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 08-31-2004 02:51 PM |
Is the STI structurally different than a regular Impreza? | Dale_K | Newbies & FAQs | 14 | 06-15-2004 12:08 PM |
Does the STI weigh less than the EVO? | Triple S | STi Forum Archive | 7 | 08-08-2003 03:40 PM |
Is the STI blue different from the '03 WRX blue? | RA29 | STi Forum Archive | 9 | 05-27-2003 02:36 PM |
Are Sti seats different than 04 WRX (besides looks) - material, design? | ImportVenom | STi Forum Archive | 3 | 05-09-2003 11:37 AM |
