11-22-2005, 08:41 PM | #1 |
Member#: 87370
Vehicle:2005 WRX,Soon to be EVO9-94 toyota4x4 project |
just went stage 2, 16.7 PSI in 3rd gear!
Just flashed Cobb stage 2 cal 91 ocatane 1.30. I'm hitting 16.7 PSI in 3rd gear and it hasnt even learned yet . Is this normal? Is my car just healthy?
thanks in advance, Steve
11-23-2005, 06:02 AM | #2 |
Member#: 64974
Vehicle:1995 WRX,APEXi,HKS,$ Faded, Stonechipped Red |
Hell yeah but what would I know??? We ALL run that poundage standard!!!LOL!
From what I can gather, that sounds pretty good. Although over here std setups can push about 25 Psi with no other mods other than an ECU!! Cheers Sixpack Subaru |
11-23-2005, 10:27 AM | #3 | |
Member#: 35273
Vehicle:2005 Saab 9-2x Aero Stage 2 |
Just keep an eye on it to make sure no knocking or boost spiking occurs. You may want to run some logs on it to be sure. |
11-23-2005, 10:42 AM | #4 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
When it does learn it will probly lower boost down, as it should be 15.8 PSi for it's target.
11-23-2005, 12:13 PM | #5 |
Member#: 85035
Vehicle:2017 Forester XT KTM 690 Duke |
Wow, that's great, the highest I've seen (on AP, not gauge) is 16.4 (w/ STi TMIC) in 4th but it it never changed from 1st day.
11-23-2005, 01:13 PM | #6 |
Member#: 56321
NESIC
Vehicle:2006 Honda El Camino Green |
Boost is not learned- fueling and timing are learned in the ECU, however, boost is a dynamic system.
Target boost is 15.8 +-.5 psi. The maps are set up for those levels. If you are running outside that range, you may be having timing pulled or something. |
11-23-2005, 01:44 PM | #7 |
Member#: 30252
RMIC
Vehicle:2005 996GT3,'16 3500 04 Ducati 749R #249 |
i have hit 18.1 psi on cobb stage 2, also runing c16 race gas, but our stock ecu is very flexible and will lean out the ratio until it's just right, don't worry about it..
11-23-2005, 01:52 PM | #8 | |
Member#: 56321
NESIC
For example, in the stock ECU mapping, there are spots set up to run 9:1, however, with stock boost levels, you will never hit them. Throwing an MBC on the car for instance, will cause you to hit them. You are running more boost, insanely rich and possibly making no more power. If you want to run more boost, I highly recommend a custom tune. Mike |
11-23-2005, 02:29 PM | #9 |
Member#: 30252
RMIC
thanks for the suggestion, not running any of that anymore, now 18g, utec, etc... but agreed it was crazy rich and not much more power than a normal stage 2 setup, but good for the road course, no knock, ping, etc...extremely safe..
21.5 PSI in 3rd gear | TSINightFall | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 09-17-2007 09:34 PM |
Just went stage 2 and wow! | Jaredm83 | Commercial ECU Reflashes | 0 | 12-13-2006 12:44 AM |
i just went stage 2!!! | chris-man | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-07-2006 09:52 PM |
Just went stage 2.....dp hitting | rallytim888 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 06-24-2006 04:52 AM |
Just went Stage 2 | Driving_Miss_Daisy | Southern California Impreza Club Forum -- SCIC | 2 | 12-31-2005 12:26 AM |
