11-18-2006, 09:33 AM | #1 |
Member#: 2532
South East
Vehicle:2001 2.5RS-T BRP |
Couple of questions about building RS turbo block
Hey all,
I've got an RS turbo and I'm trying to round up some parts for the bottom end and I have a couple questions and could use some feedback. I like the feel of the motor with the high compression pistons when compared to an STI so I don't want to lower the compression too much. I just want to make it stronger and run a little more boost. First off has anyone compared the STI pistons to RS pistons? I know the STI rods are shorter and the pistons taller, but I'd like to know where the extra piston height comes from. If it comes from more material above and between the rings they should be stronger (det wise), and it would be better for me to run the short rods and STI style pistons. If the difference is between the oil ring and wrist pin it wouldn't matter. Except I can get the shorter rods for half what a set of RS length rods cost. I'm trying to avoid custom pistons for cost reasons and I'm also trying to avoid using thinner head gaskets and milling to bring the more common 8.5:1 pistons up over 9:1 because cam sprockets for these motors are non existant. I've read on here that some of you guys are running high compression STI motors. How did you get the compression up? Also how tight can you squeeze these motors? I know .040" is a safe number but what about .030"? I know the tighter you run the squish the less chance for det so I want to get it as tight as I can without having to do the job more than once. Your thoughts are greatly appreciated, DaveW
11-18-2006, 09:41 AM | #2 |
Member#: 82741
NESIC
Vehicle:2007 350Z Silver |
If your talking about high compression hybrid motors, the 205 heads coupled with 257 block OEM pistons/OEM headgasket will raise the CR w/o any machining done.
As far as squish(do you mean quench?) is concerned, thats beyond my knowledge. |
11-18-2006, 10:04 AM | #3 |
Member#: 2532
South East
From what I gathered from other posts here I would be at 8.9:1 with the SOHC heads and aftermarket 8.5:1 STI pistons and STI gaskets which are .030" thinner than stock RS gaskets. My concern is that the extra machining to get to 9.5:1 coupled with the thinner gaskets will throw the cam timing way off.
11-18-2006, 10:11 AM | #4 |
Member#: 102682
Vehicle:... ripper's sister. |
Machining the heads for a hybrid shouldn't have any noticeable effect on CR. I wouldn't feel comfortable using a gasket do change my compression, I'd sooner change out internals. Some builders swear by the .40 Cometic. I've heard mainly because you will get less detonation due to shotty pump gas . If it plans on seeing a big turbo with lots of boost, upgrade your headbolts. I know plenty of guys running BIG turbos on OEM HG, you just have to tune accordingly.
11-18-2006, 10:15 AM | #5 |
Member#: 2532
South East
11-18-2006, 10:18 AM | #6 |
Member#: 102682
11-18-2006, 11:18 AM | #7 |
Member#: 2532
South East
I see what you're saying. If going for a flat surface I always lap the parts on a granite surface plate so the minimun amount of material is removed. But 9:1 STI pistons don't seem to grow on trees.
11-22-2006, 08:26 AM | #8 |
Member#: 2532
South East
So, custom pistons it is I guess.
Couple of questions about the stock oil pressure sender... | Impreza Rider | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 06-26-2003 07:43 PM |
Had a couple of questions about insurance and buying a WRX | Dr.Puls | Newbies & FAQs | 3 | 09-28-2002 12:01 AM |
A couple of questions about body kits. | quickdraw | Interior & Exterior Modification | 4 | 01-05-2002 12:21 PM |
('93-'01) Couple of questions about STi seats... | fellfrosch7 | Impreza Forum | 1 | 10-11-2001 12:20 AM |
A couple of questions about the up-pipe | dannyboy7 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-14-2001 05:05 PM |
