03-24-2001, 03:17 PM | #1 |
Member#: 2024
NESIC
Vehicle:2005 Legacy 2.5i Atlantic Blue Pearl |
Sick of alarm making you deaf after ECU reset?
A trick I figured out the last time I had my battery disconnected:
When you're ready to reconnect the battery: 1. Put the key in the ignition and turn to the "on" position. 2. Connect the battery 3. Take the key out 4. Tighten the bolt on the battery connection. This keeps the alarm from going off when the battery gets reconnected. (At least it does on my alarm system, and I'm not sure if my alarm is OEM or aftermarket because I bought the car used)
03-24-2001, 07:24 PM | #2 |
Member#: 3198
Vehicle:2005 GT LTD Wagon Garnet Red |
03-24-2001, 08:08 PM | #3 |
Member#: 391
Vehicle:2004 STi Blue/Gold 2000 RS BRP |
OK, so who here has already tried the MRT method and actually gotten results?? Do you have to remove panels or anything to get to the plugs??
JJ |
03-25-2001, 12:09 AM | #4 |
Member#: 2024
NESIC
Actually, I had the battery disconnected because I was swapping my bumper beam and bumper, and didn't want the airbags going kablooee while I did it.
But I might as well ask: what makes that way the right way? |
03-25-2001, 02:15 AM | #5 |
Member#: 1021
Vehicle:1999 2.5 RS Blue :) |
Err. Couldnt you just set the alarm to valet mode before you disconnect the battery?
03-25-2001, 07:36 AM | #6 |
Member#: 102
OK not sure what kinda alarm you guys are using. But all I have to do before disconnecting the battery is to either set the thing to valet mode or dissarm the alarm. Never had it wail on me upon reconnecting the battery.
03-25-2001, 10:21 AM | #7 |
Member#: 2024
NESIC
It freaks out unless I follow the steps above. Yes, I've disarmed it first; yes, I've put it in valet mode first. No, it doesn't make any difference. Maybe I should roll my eyes at you guys with alarms that don't care if someone is messing w/ your battery?
03-25-2001, 11:29 AM | #8 |
Member#: 3198
Well, it's the right way for a few reasons.
1) You aren't disconnecting your battery and setting off your alarm/losing your radio presets/clock settings/any other electrical pre-sets. 2) When you do the battery method, you're pretty much playing a crap shoot that you've left the battery disconnected long enough to discharge the caps that are designed specifically to avoid an ECU reset when the power is disconnected temporarily. Personally I'd rather do it in a way where I get positive feedback that the reset has been successfu. |
03-25-2001, 09:38 PM | #9 |
Member#: 1447
Vehicle:2000 Impreza 2001 Dodge 2500 |
skywalker- I was just going to say that, but I usually use a t-shirt.
03-26-2001, 12:23 AM | #10 |
Member#: 1990
Really simple solution...
Stuff a few paper towels in the horn for the alarm before you reconnect the ECU. It will quiet it down or even just shut it up sometimes. |
alarm siren malfunctioning after ecu reset | yeos | Car Audio, Video & Security | 1 | 09-26-2008 08:16 PM |
Keyless entry- reset after ECU reset? | sir_aspen_white | Electrical & Lighting | 1 | 04-22-2003 08:24 PM |
cammed cars--- slower after ECU reset? | ColinL | Normally Aspirated Powertrain | 18 | 04-11-2001 12:06 AM |
Stock Alarm problem after ECU reset | Longitude | Car Audio, Video & Security | 6 | 01-10-2001 12:20 AM |
Idle problem after ECU reset | Spectre23 | Technical Forum Archive | 1 | 05-19-2000 12:42 AM |
