02-01-2008, 12:31 AM | #1 |
Member#: 129979
Vehicle:2006 WRX TR vf39/ewg Black 310whp 360wtq |
Which OEM diffuser to buy??
Subaru Genuine Parts has the 06^sti rear diffuser but there is one with the weld on mounts and one without. Which one should i get?
02-01-2008, 12:37 AM | #2 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
well, they are both the same diffuser
you can get the one with mounts or get the one without and make up your own mounts. i chose to get the one with oem mounts and bolted tha bad boy up. |
02-01-2008, 01:46 AM | #3 |
Member#: 29355
cusco makes one too and it's a brace...
02-01-2008, 02:23 AM | #4 |
Member#: 136766
Vehicle:2011 STI Sedan SSM |
OR you can drill through the spare tire well (with spare tire out of course) and put carriage bolts through, thats what I did.
02-01-2008, 08:19 AM | #5 |
Member#: 92141
Vehicle:2014 GT-NC-PRHT Zeal Red. |
do you have access to a welder and welding skills?
or have a friend who matches this description? if not the weld on brackets will be paperweights in your house somewhere. I got the brackets and had my buddy weld them on for me. it's a bit of a fiddly job, but worthwhile (to me). |
02-01-2008, 08:29 AM | #6 |
Member#: 123843
Vehicle:2016 STI LTD CWP Let LED's light your way! |
To recap, you have three choices:
Diffuser w/drill & bolt on brackets Diffuser w/weld on brackets Diffuser w/Cusco frame bar -- no drilling or welding. All use the same factory diffuser. The only other difference is that the first two utilize all 5 mounting points on the diffuser. The last uses only 4 mounting points -- it does not use the center one. This is not a problem at all -- I have the Cusco kit. Good luck on your choice. Happy Motoring! |
02-01-2008, 10:52 AM | #7 |
Member#: 82767
02-01-2008, 05:31 PM | #8 |
Member#: 110153
Vehicle:2007 STi OBP |
FWIW the bolt on one is easy-peasy to install, and looks nice.
Similar Threads | ||||
which atp turbo to buy for 350 to 400 at the wheels? | hatrick32000 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 09-02-2008 10:01 PM |
Which Tow Hook to Buy, and Where To Install It ??? | george3 | Interior & Exterior Modification | 5 | 02-10-2008 12:21 PM |
DVD experts: which DVD player to buy if i want to play DVD's from Asia? | YinUCSD | Off-Topic | 19 | 12-06-2004 12:37 PM |
DVD experts: which DVD player to buy if i want to play DVD's from Asia? | YinUCSD | Off-Topic | 1 | 12-05-2004 05:18 PM |
OT help! Im heading to Frys here in a few and need to know which tv tuner to buy! | [27] | Off-Topic | 14 | 08-16-2004 02:10 AM |
