10-01-2012, 09:47 AM | #1 | |
Member#: 73805
Ford, GM Team Up to Develop Nine and 10 Speed Transmissions
10-01-2012, 10:22 AM | #2 |
Member#: 95901
10 speed slush box? Getting the market ready for CVT's
10-01-2012, 12:27 PM | #3 |
Member#: 119958
Vehicle:1992 SVX LS-L |
"GM shall bear a nine-geared transmission! Not four, or five, or seven, but NINE! ...which he will wield on all wretched customers, customers just like you, sir, there..." This is getting comically ridiculous. I'd rather they produce a transmission that is actually robust enough that one doesn't have to worry about it needing to be replaced @~100K miles. |
10-01-2012, 02:56 PM | #4 | |
Member#: 138000
BAIC
Vehicle:Buy Nate's coffee west coast roasting |
I had no idea that this was a concern. and this is comically ridiculous why? |
10-01-2012, 03:12 PM | #5 |
Member#: 206332
10-01-2012, 03:14 PM | #6 |
Member#: 119958
9 or 10 gears?
How big of a transmission are we talking about? If it is a FWD transaxle, there is much more limited space. How big are each of the gear sets? are they robust enough to not wear out or shed gear teeth after years of use? How often is this thing going to hunt and peck for the right gear ratio, and how much time spent shifting between 9 or 10 gears? How narrow is the engine's power band? That is the only major reason for many gear ratios. A wide power band, which the new DI & Turbocharged engines are supposed to have, should require LESS shifting, not more. How many bands, hydraulic circuits, and moving parts are vulnerable to failure, and trashing the rest of the gearbox? How much is a 9 or 10 gear gearbox going to cost to replace, or have rebuilt? My family has had all sorts of different brands of cars that have required transmission re-builds. Chrysler, Ford, GM, and Subaru. Hondas are known to have potentially delicate transmissions. CVTs from all brands have reliability issues and seem to have higher repair rates after warranty expiration than automatics or manuals. I don't trust efforts to introduce more complexity, and more un-proven parts, when they have yet to prove definitively that the transmissions are rock solid. What brand is known for transmissions that *DON'T* need repairs beyond the regular maintenance fluid change service, and are more than capable of coping with any driving style, and any amount of power than the engines put through it. |
10-01-2012, 03:31 PM | #7 |
Member#: 282204
Vehicle:2011 5 Door STi Plasma Blue Pearl |
Actually i look forward to it.. cruising at idle... ahhh..
10-01-2012, 03:40 PM | #8 |
Member#: 119958
Any car with a tall overdrive and a reasonable final drive ratio can do that.
the only thing required is enough latent torque to pressurize the hydraulics to down-shift when the accelerator is pressed. Most cars don't stay in top-gear if the driver presses the accelerator, anyway. A 3 speed automatic can do that, if the third gear ratio is ~0.65:1 or so. it is just a matter of how many gears, at what interval, are between lowest and highest gear ratios. |
10-01-2012, 04:08 PM | #9 | |
Member#: 72042
South East
Vehicle:2002 V7 Impreza WRX The Blue Mammoth |
Eh who cares.
Are you a CEO or engineer. No need to get upset, lots of other things in the world to get pissed off at. Quote:
10-01-2012, 04:17 PM | #10 |
Member#: 873
TXIC
Vehicle:2020 JEEP / RAM Datsun 71 240Z & 68 2000 |
In all fairness to the cesspool that is union controlled GM.
GM has always made a pretty darn good transmission. |
10-01-2012, 04:43 PM | #11 |
Member#: 89821
Vehicle:2015 STI LE |
Why not just perfect the CVT and be done with it? Subaru already has a CVT that doesn't drone too badly and somewhat mimicks an auto if you want. Change it from six to ten and call it good .
10-01-2012, 05:01 PM | #12 |
Member#: 95600
Vehicle:2003 WRX wagon Silver |
Why is it that people ignore the thread point which is GM and Ford are both working on this 10 and 9. Surely if 9 is bad 10 must be terrible. Anyway if they can make it cheap, robust, then it is a great thing. If they can't then...
10-01-2012, 05:29 PM | #13 |
Member#: 142447
AKIC
Vehicle:2019 Audi S3 |
Cheap and good seems kind of a stretch.
10-01-2012, 05:31 PM | #14 |
Member#: 119958
10-01-2012, 07:08 PM | #15 |
Member#: 95600
Yeah I don't mean "cheap" so I should change the word to say something else such as.
"Cost effective" That would be a better term. I don't need it to be cheaper or even as cheap as 5 speed alternative. Just that it pays for the gas savings quickly and will not break. Quickly like in 1-2 years. |
10-01-2012, 07:39 PM | #16 | |
Member#: 138000
BAIC
Numbers from AAMCO and other chain transmission repair shops showed a continuous drop in transmission replacement from 1990 onwards. I would take hard facts over anecdotal evidence. |
10-01-2012, 08:03 PM | #17 |
Member#: 142447
AKIC
I'm just not sure what about this news is worthy of an angry rant. Time marches on.
10-01-2012, 10:48 PM | #18 | ||||||||
Member#: 232940
10-03-2012, 12:59 PM | #19 |
Member#: 21293
Vehicle:05 OB Black Bean 1969 W-30 |
Mine goes to 11..................
Honestly GM makes some great transmissions. My family has a few of them and they all did over 200K with standard maintenance. I don't see how you could tow with a CVT. That must be where they are going to apply this. Also, I wonder if they will use same Allison design in the units. Peace, Greg |
10-03-2012, 08:40 PM | #20 |
Member#: 7887
Vehicle:2023 Tangerine 2023 3 Cylinder |
The AT in our '97 Yukon was replaced 3 times before it was sold in '02.
/one data point |
10-03-2012, 11:15 PM | #21 |
Member#: 232940
^ 4L60E of that era had known problems with kickdown solenoids and 2-3 clutch packs...
10-04-2012, 01:22 AM | #22 | |
Member#: 82470
CVTs suck to drive, have little to no mileage benefit, and are unreliable. They're the worst transmission choice you can make. I'd rather have a two speed powerglide. |
10-04-2012, 10:10 AM | #23 |
Member#: 194216
W. Canada
Vehicle:2022 Fast POS |
10-04-2012, 10:58 AM | #24 |
Member#: 89821
10-04-2012, 11:07 AM | #25 | |
Member#: 153088
Vehicle:2005 Baja Turbo 95&96 Sambar 06 Forester |
There are several things that make the new Impreza have 30% better mpg than previous Imprezas, but the number one thing is the CVT; so how does it have "little to no mileage benefit"? Subaru's Lineartronic CVT has proved to be reliable. As for sucking to drive....well....that is preference. I think they are fine. |
